Old 10-04-2009, 10:44 PM   #1
beaviscih
Member#: 123362
'93 Crapcan, '98L
Sold, '04 STi - Sold
Default EJ20G Rebuild - Looking for Suggestions
While I recently completed an EJ20G swap into my '98L I'm picking up another EJ20G (couldn't pass up the deal... http://forums.nasioc.com/forums/show....php?t=1854408). This will be my first engine tear down / rebuild. Goals are pretty simple, a fresh engine that I'm comfortable pushing the boost to 20-22psi. Budget is under $2k (I will do all the work excluding porting/polishing). Before I dive off in this I would appreciate some suggestions / opinions (I know - that's asking for trouble ). Here is what I'm thinking...
EJ20K Heads - just stock, no porting, possible deal pending
Forged Pistons - what type? Can I use these? http://forums.nasioc.com/forums/show...hlight=pistons
ACL Bearings - still looking for the part number
EJ20G Head Gaskets - (I'm having trouble finding the part number in the system - but still looking)
ARP Head Studs - need to find the part number
TDO5 Turbo - send it off for a port/polish
USDM Oil Pump - ported
DW 650cc Injectors - from my EJ20G
Ider Pulleys / Belts / Seals / Gaskets - Duh
LinkG4 Ver1-6 EM (currently running my EJ20G)
Anything else I'm Missing?
Thanks in advance.
beaviscih is offline   Reply With Quote
Old 10-05-2009, 06:00 AM   #2
Audioexcels
Member#: 104824
1996 EJ20G OBS
Thumbs up
Thanks in advance.
Matt M has some pistons that he said will work for the block, though you might be able to use the ones you have and just use new rings:
http://www.japanparts.com/db/partsli...=034-026-12033
You can also make a #3 thrust on the crank (maybe it was USDM crank mentioned though I thought it was the phase 1 crank mentioned) and use USDM Forged Pistons.
I saw a complete and I mean complete gasket set from a UK seller, though Rallitek has Gaskets for the EJ20K Heads.
Bearings Part Numbers and Makes=http://www.aclperformance.com.au/SubaruEJ20G.htm
Head Studs I'm almost positive are: 260-4701 used for EJ20/EJ22/EJ25/etc. engines
Head porting with the heads I have will net you as much or more flow than EJ207 heads which are considered the best heads out there so that'll be a major upgrade.
Maybe go with an 18G since it will net some major gains over the ported TDO5 or even a big 16G, while not being much different in terms of spool/lag. You can find a solid used 18G for $400-$500 or buy a new Evo III Big 16G from Blouch for I believe $650 right now.
Maybe some DW 790's since they are really cheap and practically a trade for the 650's you have. Larger never hurts.
Some photos of the closed block I was telling you about in case you wanted a freshly pulled one to work on along with freshly pulled heads.
Hopefully others will be in here for assistance, though Matt is definitely a guy of great knowledge in this arena as is Marnix.
Audioexcels is offline   Reply With Quote
Old 10-05-2009, 10:13 PM   #3
beaviscih
Member#: 123362
'93 Crapcan, '98L
Thanks for the information. Send me pictures of the heads after you get them off the block.
Old 10-06-2009, 02:16 AM   #4
Audioexcels
Member#: 104824
1996 EJ20G OBS
Sure will do.
And definitely email Matt Monson and Marnix. These two really know their stuff parts wise with pretty much all the engines, but especially a great database with the JDM stuff.
Doing EJ20 rebuild, looking for manual with information mtm584 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 12-08-2007 10:04 PM
Looking for suggestions for a personalized plate... dr_wheel Off-Topic 28 10-22-2005 09:20 PM
beginner: ej20g swap, looking for starters tips shatowz Subaru Conversions 3 06-14-2004 08:34 AM
Looking for suggestions for wheels carlm Brakes, Steering & Suspension 8 03-25-2003 09:46 AM
Minnesotans: We're looking for suggestions for a meet! midlifecrisis Mid West Subaru Owners Club Forum -- MWSOC 15 08-11-2002 01:08 AM
