#1 |
Member#: 157229
RMIC
Vehicle:02 WRX PSM |
My windshield wipers have started to go too far on the windshield when wiping. About once every 100 wipes the drivers side wiper will go so far that it goes off the windshield and gets stuck on the antenna mount.
This is super annoying, and I don't even know what to do here. I tried getting an inch shorter wipers on the drivers side, but still happens. Any suggestions from you guys?
#2 |
Member#: 200008
RMIC
Vehicle:85 AE86 01XJcrawler02WRXsold |
Same thing happened on my bugeye. I just put in a new wiper assembly and it worked fine after that, it seems to be pretty common with these cars. I have a full assembly from an impreza that might work...
#3 |
Member#: 157229
RMIC
What do you by full assembly? new motor and such?
#4 |
Member#: 200008
RMIC
Wiper linkage, arm, and motor.
#5 |
Member#: 174533
RMIC
Vehicle:0694 WRXLtd/LegWagon WRB/Pure White |
Have you tried just taking the arm off and reseating it?
#6 |
Member#: 158534
RMIC
Vehicle:99 2.5 Wagon |
mine just slap back and forth... they hit the pillar and the bottom every time, and make tons of noise. suuuuuper annoying.
#7 |
Member#: 143703
RMIC
push car off cliff?
JK Hope you get that fixed, sounds annoying. |
#8 |
Member#: 157229
RMIC
#9 |
Member#: 125937
RMIC
Vehicle:03 WRX I do not like your tweed, chap. |
Mine have been doing the same thing. :P
Balls. |
#10 |
Member#: 157229
RMIC
#11 |
Member#: 43128
Vehicle:92 RWD, 96 FWD 05 AWD |
As stated before, it is the wiper linkage. I doubt you will need a new motor, but you will need to replace both sides of the linkage. Its a bitch to get to and change also!
Rick |
#12 |
Member#: 157229
RMIC
Are you 100% sure? Because I don't want to order the parts, then have it not fix the problem. And I need both linkages?
#13 |
Member#: 43128
Can you grab onto the wiper arm and move it? if there is play, the linkage bushings are ****ed. You can get just the new linkage bushings, someone did a write-up using autozone bushings, but I would just buy the whole new assembly from Subaru.
You can also check the bushings by taking the motor off, which will allow you to see into the firewall and you can reach in and feel if it is messed up, there might be another inspection plate somewhere else on the firewall too...I cant remember. And Subaru allows you to take back parts as long as they are new in box, just don't rip them out of the package until you know you are going to need it and it is going to fit. You will love the new linkage anyway, nice smooth action of the wiper arms, makes the car feel like new again lol. Edit. And putting the new "cups" onto the balls takes a lot more force than you think is needed, I thought I was going to break it trying to pop it on. |
| Thread Tools | |
| Display Modes | |
| Where to get my windshield wiper blades rebuilt? | jdmimpreza | Southern California Impreza Club Forum -- SCIC | 21 | 11-06-2007 06:29 PM |
| random q: i found an ace playing card on my under my windshield wiper...? | White 2.5rs | Off-Topic | 45 | 07-03-2005 11:03 PM |
| My windshield wipers just don't work over 85 | Sordid Philosopher | General Community | 18 | 11-20-2002 09:45 PM |
| Who left up my windshield wipers at Home Depot ? | PKduck | Bay Area Impreza Club Forum -- BAIC | 2 | 12-27-2001 02:23 AM |
