Old 10-05-2009, 10:56 PM   #1
moore.jeff54
Member#: 218149
2009 Impreza 2.5i
Default Tire pressure light is on...
So I checked all the tires and their pressure is right where it should be but my light is still on. Why won't it go off? It's starting to get very annoying.
moore.jeff54 is offline   Reply With Quote
Old 10-05-2009, 11:35 PM   #2
mikeythejew
Member#: 141672
I would see if there's a way to disable it. TPMS hasn't matured enough yet to make it worthwhile imo.
mikeythejew is offline   Reply With Quote
Old 10-05-2009, 11:38 PM   #3
Andrew2.5
Member#: 186965
2001 2.5 RS
i dont believe the dealer can disable it but they should be able to raise it a little if you prefer... I work at nissan so we deal with this daily. Also is it a solid light or flashing? if it flashes that means there is a stored code and it would require you to bring it to the dealer to be cleared.
Andrew2.5 is offline   Reply With Quote
Old 10-05-2009, 11:39 PM   #4
Gigabelova
Member#: 81409
2004 Impreza WRX STi
Platinum Silver Metallic
I would just have it sent to the dealer to fix it. Just disabling it is a band aid fix.
Gigabelova is offline   Reply With Quote
Old 10-06-2009, 01:03 AM   #5
moore.jeff54
Member#: 218149
2009 Impreza 2.5i
its just solid
Old 10-06-2009, 01:32 AM   #6
Andrew2.5
Member#: 186965
2001 2.5 RS
then maybe just try to go a little above the recommended spec. Also of course you do have to drive it down the road after to let the sensors read.
Old 10-06-2009, 02:04 AM   #7
moore.jeff54
Member#: 218149
2009 Impreza 2.5i
its been on for a few days worth of driving
Old 10-06-2009, 02:40 AM   #8
Gigabelova
Member#: 81409
Come to think of it, either your pressure gauge is not reading right or the sensor is going bad.
Old 10-06-2009, 07:33 AM   #9
blackfang
Member#: 131347
2007 Legacy 2.5i SE
98 Z/28, VN 900 custom
Did you really need to make 3 threads on this?
No we can not disable it.
Yes we can adjust the PSI as can the OP. We set ours around 33-35 psi. Remember it is Fall. The cooler weather at night is here and this could drop your psi and turn the light on.
blackfang is offline   Reply With Quote
Old 10-06-2009, 08:59 AM   #10
scubywagon
Member#: 65967
2004 WRX WGN 2.5
Java Black Pearl
take it to the dealer....should still be under warranty so it shouldn't cost anything.
scubywagon is offline   Reply With Quote
Old 10-06-2009, 11:04 AM   #11
blackfang
Member#: 131347
2007 Legacy 2.5i SE
Not necessarily true. What if he has a nail or something in the tire?
Old 10-06-2009, 01:28 PM   #12
moore.jeff54
Member#: 218149
2009 Impreza 2.5i
its a brand new car, so nothing should be wrong with the sensor.
and it made three because my internet was being sketchy and thought i clicked the button 3 times
Old 10-06-2009, 02:36 PM   #13
Zefy
Member#: 105104
1979 BRAT / 01 RSTI
99 2.5TS (DEAD)
does the spare tire have a sensor? My dad's vehicle does and he couldn't figure it out for the longest time.
worth a try.
Zefy is offline   Reply With Quote
Old 10-06-2009, 03:17 PM   #14
blackfang
Member#: 131347
2007 Legacy 2.5i SE
Just because the car is "brand new" doesn't mean something will not fail. If that is the case, there would be no need for a warranty.
No the spare tire does not have a sensor.
Old 10-06-2009, 03:28 PM   #15
2.5GTLegacy
Member#: 111219
Right, something "brand new" can still have manufacture defects.
Or that you have a nail in your tire.
Set the correct tire pressure, look at the drivers door jam for PSI specs.
Reset the light manually. I know that most Toyotas have a reset button. Not sure about the Subarus. Or may be the kinda that resets itself, just drive the car a bit.
When in doubt, take it back to the dealership.
2.5GTLegacy is offline   Reply With Quote
Old 10-06-2009, 04:33 PM   #16
blackfang
Member#: 131347
2007 Legacy 2.5i SE
Subaru's you drive the vehicle about a mile, if that. I normally get them reset still in the parking lot. I remember working for a Toyota dealer and they have a reset button and some models the spare had a sensor too.
Old 10-15-2009, 02:07 PM   #17
Kyguy
Member#: 38705
'95 GM2 Rally Car
& '08 WRX
My '08 WRX is having this issue too - I talked to the dealer and they told me to bring it in to get recalibrated.
Kyguy is offline   Reply With Quote
Old 12-04-2009, 05:26 PM   #18
papafrito
Member#: 181280
2008 WRX-Prn STG 2.5
Dark Gray Metallic
Its the colder weather, my 08 wrx and my sisters 08 wrx TPMS both came on the exact same day. If it doesnt bother you then just wait for it to warm up. That is unless you really are losing pressure... Ours was 100% the weather, we went from 43 to 19 today. It will have an effect.
papafrito is offline   Reply With Quote
Old 12-04-2009, 11:09 PM   #19
SubeTek
Member#: 1714
1999 RS-T COUPE
Colorado has been in the single digit temps off and on the last few days. We seen numerous tpms lights on due to this. Tire pressure will decrease approx 1 psi per 10 degrees of temp, so doing the math if you start out at 32psi on a 60 degree day minus 50 degrees (5 psi) you get the tpms light on. All you have to due is set your tire pressures to approx 35psi and check them if you get big temp changes. Also generally speaking, the tpms light on constant means low tire pressure whereas a flashing tpms light means a sensor/system failure. Hope this helps.
Bret
Subaru Senior Master Tech
GO Subaru West-Golden,CO
SubeTek is offline   Reply With Quote
Old 12-05-2009, 01:18 AM   #20
krothery
Member#: 216615
2009 impreza 2.5i 5d
Bret
^ ^ this ^ ^
i had the same problem when i was in tahoe last week. in the manual it says to keep it at 35psi when under 35* or something like that.
anyways i did that and the light went away.
krothery is offline   Reply With Quote
Old 12-05-2009, 02:10 PM   #21
JJL330
Member#: 38672
2009 WRX 5dr
Mine came on too... PSI dropped from 35 to 30. I pumped the tires back up and it wouldn't go away for a day... doesn't go away immediately.
JJL330 is offline   Reply With Quote
Old 12-05-2009, 08:26 PM   #22
RexyGirl
Member#: 63616
1996 Volvo 850 Turbo
with mods :)
If there is a few pounds difference in the tire pressures, the light will come on. If the front tires have a difference of 3 or 4 lbs, the light will come on.
The light will also come on if the tires are over inflated. Make sure all the tire pressures are about the same, anywhere from 32 to 36 pounds.
You need to drive the vehicle over 20mph for a few minutes for the light to go out, if the tire pressures are okay.
RexyGirl is offline   Reply With Quote
Old 12-11-2009, 03:27 PM   #23
RacerGrrl
Member#: 175152
2009 '09 Impreza
I have an '09 Impreza and my yellow tire pressure light came on yesterday - temp 3 degrees whereas it hasn't been below 20 in 8-9 months. Its solid yellow; not flashing. It was on once before months ago in summer weather and I added air and was golden.
So assumption was the temperature drop reduced the pressure. However, I took the car in, had the pressure checked, and it was low 2-3psi. (6 degrees is far to cold to check and fill in my own unheated 1 car garage). They filled back to 35psi and I headed home. I have driven it about 15 miles now in 15 degree weather and the light is still on. Should i be concerned? I am taking to my local mechanic (who I have taken all my cars to for years and trust thoroughly) for an oil change tonight. Should I let him look into it, or take it to the dealer since its still under warantee?
RacerGrrl is offline   Reply With Quote
Old 12-11-2009, 04:11 PM   #24
SubeTek
Member#: 1714
1999 RS-T COUPE
If you've driven it for 15 miles it should have turned off if the tire pressures were set to proper levels. I'd return to the dealer to have them read the tpms code to determine the cause of the light. They should have checked the codes in the first place and then cleared them before you left.
Old 12-13-2009, 07:28 AM   #25
blackfang
Member#: 131347
2007 Legacy 2.5i SE
There could also be a nail in the tire as well.
tire pressure warning light is on DCsubieSTI Newbies & FAQs 6 12-29-2009 10:58 PM
Tire pressure light is on... moore.jeff54 Warranty Issues & SOA Problems 0 10-05-2009 10:56 PM
Tire pressure light coming on indoubt Tire & Wheel 4 09-08-2009 02:28 PM
new rims and tire pressure light on ornge04gt Newbies & FAQs 12 04-06-2008 10:33 PM
