Closed Thread
Old 10-06-2009, 03:18 PM   #1
Don Nguyen
Member#: 188383
Default J's Graphics - Smoked/tinted tail light pictures
Yes, I do these too
In addition to doing all of the other graphic/vinyl work, I've been getting a lot of people who come by asking if I can do smoke/tint for their tail lights as well. I had the film and material available to me, so I decided to give it a shot.
Material is supplies from lamin-x, however, it is cut in house at our location, versus coming pre cut from lamin-x. This way I can have it come out the exact way I want it and how it should be. Some lamin-x pieces end slightly shorter than the actual tail light, leaving exposed areas around its edges. I have mine slightly oversized (~2mm), just enough to be able to wrap around the edges and give the user more working area/room. This gives it a cleaner/complete look, and helps prevents dirt from building up on the direct edges of the tail light.
Been slowly finding local cars to do it, so I can do some test fitments and get some pictures. Whatever pictures of the cars you see means that's what I have and what's available. New cars are always welcomed, if you're a local or in the area.
-Don
Don Nguyen is offline
Old 10-06-2009, 03:19 PM   #2
Don Nguyen
Member#: 188383
Pictures of on a black E60 from this weekend.
Don't mind the exposure of the picture, it was necessary in order to try and get the actual tint of the tail lights to come out how they were actually looking like at that moment.
I'll get the other pictures up once I edit/resize them. The tint was just perfect in person, and we had no problems laying it over even that small raised part of the corner of the tail light section.
-Don
Old 10-06-2009, 03:19 PM   #3
All4bSpinnin
Member#: 99102
09 135i 6MT FBO
Twin Turbo!
those houses look cool...
nice job on the tint...
All4bSpinnin is offline
Old 10-06-2009, 03:56 PM   #4
dlew308
Member#: 82747
2009 WRX
Have anything for the 08+ impreza clear rears?
dlew308 is offline
Old 10-06-2009, 03:56 PM   #5
Don Nguyen
Member#: 188383
Not yet. Want to be the first?
-Don
Old 10-06-2009, 04:15 PM   #6
glilly
Magic 8 ball says Ban
Member#: 7245
13 BRZ
08 Avalanche
seeing as y'all are discussing taillight treatments...
I did the red vinyl w/ cut out, then added another layer of dark smoke w/ cut out, ...then added a light smoke insert. 3 vinyls, I thought it turned out perfect.
Don, i've been using the Oracal transparent 8300 for a few years now, ...find it's alot easier to work with than the Lamin-X thicker films, ...however, there's no "protection", but who needs it on the rear anyway?
many companies are selling the pre-cut templates, ...I found this is very hard to do. It's so much easier and a much cleaner install to just apply it raw and trim as needed. This way you can tuck in to the edges and corners for a factory look, ....as you've obviously already found out.
Again, great work!
glilly is offline
Old 10-06-2009, 04:17 PM   #7
dye.sti
Member#: 136297
2012 WRX
OBP w/ Red and Flat Black
SERIOUSLY! HAHA
tinted tails look good to
dye.sti is offline
Old 10-07-2009, 01:37 AM   #8
Don Nguyen
Member#: 188383
Originally Posted by dye.sti View Post
SERIOUSLY! HAHA
Like you wouldn't know. He gets that from almost every time
-Don
Old 10-07-2009, 01:49 AM   #9
seanathanq83
Member#: 173241
2002 s256 twinscroll
now with one more gear
are the layers no thick enough to have a noticeable difference between the layers and the factory plastic of the lens??
seanathanq83 is offline
Old 10-07-2009, 01:52 AM   #10
Don Nguyen
Member#: 188383
It's always going to be raised up higher than the section/piece that you are applying it to. It's similar to clear bra, where it's only slightly raised up, and pretty much not very noticeable. This is of course if you are considering only wrapping part of the tail lights. Since if you were covering the whole thing, it'd be a non-issue.
-Don
Old 10-07-2009, 02:06 AM   #11
MrMakesitRain
Member#: 168333
2006 STi
CGM
i always wanted tinted tails the amount of the e60. looks good!
MrMakesitRain is offline
Old 10-07-2009, 09:46 AM   #12
Don Nguyen
Member#: 188383
Thanks. It's hard to take pictures to show you exactly how the tint looks. Since it's obviously always changing in different lighting, and just a little too much or too little exposure in the picture could cause it to go either way.
-Don
Closed Thread
J's Graphics - Vinyl Carbon Fiber Roof - Picture Thread Don Nguyen Member's Car Gallery 57 10-06-2009 11:47 AM
Has anyone here used window tint spray to smoke out tail lights? m4r10 Interior & Exterior Modification 14 09-05-2006 12:56 PM
FS: Smoked wagon tail lights! NewAtThis Private 'For Sale' Classifieds 11 05-07-2004 08:41 AM
Smoked Stock Tail Lights PumpsGOTAWD Interior & Exterior Modification 32 01-18-2004 10:35 PM
Anyone with those smoked Altezza tail lights or Cwest kit? GenMaster Member's Car Gallery 12 06-04-2002 07:48 PM
