Old 10-06-2009, 07:50 PM   #1
vien
Member#: 221538
2003 wrx/ylw wheels
darkness.................
Default bolt ons on 03 wrx safe for now or tune?
ok so im slowly working on my 03 wrx and im on a serious budget to get the car up and running, the car had a valve issue so that was fixed and this is what i have done so far
fresh oem head gaskets, fresh oem head bolts, worx tuning recirc valve, perrin tmic hoses and perrin bpv hose, godspeed tmic, ichiba dp, cobb replica 3 inch exhaust, perrin airfilter, oem replacement exedy clutch kit and resurfaced flywheel, and thats about sums it up for now. so my question is would i be ok for now on the stock tune? and i plan on getting a ichiba uppipe as well when i put that on would it really be ok? ive heard that the 02-03 wrx are mod friendly with no problems.
vien is offline   Reply With Quote
Old 10-07-2009, 10:58 AM   #2
thorne
Member#: 130063
2003 WRX
Silb
They are not mod friendly any more then a 04/05 they all run very similar ecu's. You need to get a tune on the car. Unless you just want to break it.
Buy a Tactrix cable or a Vagcom cable and get the terminator . And run a OTS stage 2 map. If you want to do this and can by the cable I can help you get it urnning .
My take on these type of things is why risk the motor? The car is going to make more boost then before and push itself into non tuned load cells.
thorne is offline   Reply With Quote
Old 10-07-2009, 11:00 AM   #3
MIKE DD
Member#: 106818
2003 Truck
I say it'll be fine, and I will be in the majority on this.
MIKE DD is offline   Reply With Quote
Old 10-07-2009, 11:13 AM   #4
Bug-Rex
Member#: 190935
02 Slam'd Bugeye
LOL member accnt. points
Yeah, you will be fine. A tune will reap all the benefits from your mods, but the car will be fine without one.
Bug-Rex is offline   Reply With Quote
Old 10-07-2009, 02:01 PM   #5
vien
Member#: 221538
2003 wrx/ylw wheels
i see i know that i would reap the benefits by having it tuned but i dont have the mney right now for a tune hence thats why i asked if it would be ok to drive home or to work and what not untill i get it tuned, now as far as the up pipe goes ive heard you have to do some type of mod for it to work if not you get a cel but i thought that was only for the 04-05 models tho?
Old 10-07-2009, 02:11 PM   #6
Agkelos
Member#: 58163
2002 Stage 2 WRX
World Rally Blue
All the exhaust stuff will be fine w/o a tune.
Blow off valve answer is same as always.
Only concern I have is the TMIC, it won't hurt you, but you may get some changes in throttle response. Actually it may increase depending on the pressure drop.
The 02/03 ECUs are NOT the same as the 04+.
Agkelos is offline   Reply With Quote
Old 10-07-2009, 02:29 PM   #7
vien
Member#: 221538
2003 wrx/ylw wheels
so i would be ok with the uppipe mod then?
Old 10-07-2009, 02:34 PM   #8
Agkelos
Member#: 58163
2002 Stage 2 WRX
World Rally Blue
Yes, you will
Old 10-07-2009, 02:41 PM   #9
vien
Member#: 221538
2003 wrx/ylw wheels
Yes, you will
fair enough kool
WTB: JDM sti grill for 03 WRX, JDM hood scoop, or JDM OR EDM headlights teg_09 Private 'Wanted' Classifieds 0 05-30-2009 02:22 PM
vf 43 or vf 48 install on 03 wrx sonic03dz Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 11 05-07-2009 09:46 AM
17 or 18 in on 03 WRX sackytar Tire & Wheel 1 04-24-2008 09:06 PM
How safe without EM or tuning? scooby-stu Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 14 04-16-2005 11:50 AM
I guess my checkbook is safe for now :-[ rao Mid West Subaru Owners Club Forum -- MWSOC 1 04-06-2001 04:04 PM
