Alaskan Impreza Club
Old 10-06-2009, 08:16 PM   #1
Marlons101
Member#: 137569
WRX Twinscroll
Dez in yo mouth!
Default ? for meth users...
How much are you guys going through during the winter time per fill up opposed to summer use? I dont know if my setup is spraying too much or what... Im using the windshield tank res. thats a Gallon I believe... and I go through that like its nothing in 2fill ups maybe one...
Marlons101 is offline   Reply With Quote
Old 10-06-2009, 08:18 PM   #2
Brando5185
Member#: 189926
2006 Jeep GC Limited
It's a HEMI!! Yee-haw
Depends on how many matches they let me buy.... ohhh... meth for your car. Nevermind.
Brando5185 is offline   Reply With Quote
Old 10-06-2009, 08:27 PM   #3
fishAK
Member#: 177680
'03 GMC Denali
White light w/flicker
Sorry, I have no answer for you Marlon, but that might be the best thread title ever.....lols
fishAK is offline   Reply With Quote
Old 10-06-2009, 08:29 PM   #4
tribalwrx
Member#: 32993
vf39 Best trap 110
Best ET 12.54 Dale tuned
i usually go through that washer tank every to fill ups on gas, now since i've had that #10 nozzle in if i stand on it all the time it goes quick so does my tank of gas otherwise i don't go through it that much
tribalwrx is offline   Reply With Quote
Old 10-06-2009, 08:46 PM   #5
Marlons101
Member#: 137569
WRX Twinscroll
Dez in yo mouth!
yaa I guess it all depends on how throttle happy I am at the time...but seems I can only get like 2gas fill ups per gallon of meth at the most?.... I have a .7 on mine...soo may mess with the sprayer on how much it sprays...but eh I was thinking the cold had something to do with it...but maybe not?
and damn the thread title didnt even dawn on me till you guys....damn funny
Old 10-06-2009, 09:08 PM   #6
tribalwrx
Member#: 32993
vf39 Best trap 110
well even in the winter its gonna depend on how much right foot input you give, when i had a #7 in my car i would get about 3 tanks of gas to each tank of meth roughly, i can make it last if i need to
Old 10-06-2009, 10:29 PM   #7
greenspeed
Member#: 151248
00 Impreza 2.5RS
Whore Door
can't you still disarm the system manually and re-map a little richer tune to compensate for no meth and just switch it on when need be?
greenspeed is offline   Reply With Quote
Old 10-06-2009, 11:53 PM   #8
Carter
Member#: 156708
2009 Cessna 172SP
G1000
Carter is offline   Reply With Quote
Old 10-07-2009, 12:54 AM   #9
fishAK
Member#: 177680
'03 GMC Denali
Oh. Wow.
Carter, put your dentures back in....
Old 10-07-2009, 12:58 AM   #10
Marlons101
Member#: 137569
WRX Twinscroll
Dez in yo mouth!
hahahhah
Old 10-07-2009, 02:05 AM   #11
Carter
Member#: 156708
2009 Cessna 172SP
G1000
Ahaha... Pwnt.
Old 10-07-2009, 02:20 AM   #12
06gtleg
Member#: 197928
95 Outback
Green
why would you post a pic like that??? that **** is gross!!!!
06gtleg is offline   Reply With Quote
Old 10-07-2009, 03:11 AM   #13
Boomer907
Member#: 217740
2008 Dodge ram 1500
Maroon
Marlon first you ask where to get some good meth, now you're askin how much we use....
Terrible...
Boomer907 is offline   Reply With Quote
Old 10-07-2009, 04:06 AM   #14
hostile blizzard
Member#: 114949
03 wrx
Sonic Yellow
what meth system do you have>?...i think i have the SMS...
hostile blizzard is offline   Reply With Quote
Old 10-07-2009, 01:33 PM   #15
TurboSetch
Member#: 192358
MANY P3 Import Auto
907 355 6655
With a 50/50 mix meth/water you should be using 5%-10% max mix with fuel.
In other words if you burned 10 gallons of gas during meth spray you would use up to 1 gallon of water. You most likely are standing on it a lot.
FYI...Last check on your car your injectors were max and the water was your extra fuel. Turning it down could be bad, don't do it without a wideband to watch.
TurboSetch is offline   Reply With Quote
Old 10-07-2009, 02:30 PM   #16
tribalwrx
Member#: 32993
vf39 Best trap 110
ok first, carter that photo was down right WRONG...
marlons what size are your injectors? your running a vf43 with sti cams correct? you need to be running a #10 nozzle, i ran a #7 with my setup and it would only handle so much timing and boost and it was maxing out my injectors(by meaning around 95% idc's or more) right now with the #10 my idc's are around the mid to low 80% and an afr of 11.4-11.5, yes i metered that with a wb02 not the front afr sensor. i am also using the smc meth kit and have had this same system for over 5 years or so
Old 10-07-2009, 03:26 PM   #17
Marlons101
Member#: 137569
WRX Twinscroll
Dez in yo mouth!
what size injectors are you running tribal? I have 550s and they are maxed as seth said. I got the size 10nozzle in my closet. But didnt think I would need it for this setup...my afrs were around 11.1-11.3-5ish.. soo ya maybe try the #10 but would I be turning the spray down still as thats gonna spray more already?
Old 10-07-2009, 03:34 PM   #18
TurboSetch
Member#: 192358
MANY P3 Import Auto
907 355 6655
What does this #10 and #7 translate to in actual flow rates and at what pressure.
I use another vendor whos nozzles are rated in ml/s
Old 10-07-2009, 03:50 PM   #19
Marlons101
Member#: 137569
WRX Twinscroll
Dez in yo mouth!
.7 .4 1.0 mm size nozzles
Old 10-07-2009, 04:44 PM   #20
tribalwrx
Member#: 32993
vf39 Best trap 110
i'm running the sti blue injectors aswell, as for flow rate the smc nozzles are either a # 7 or a #10 hugo nozzle , believe those run liters per hour, what kit are you running marlons?
Any nitrous AND meth users here? japslapr Water/Methanol Injection, Nitrous & Intercooler Cooling 2 11-23-2007 07:19 AM
DFW Meth users....I need your help texas05sti Texas Impreza Club Forum -- TXIC 17 07-09-2007 09:30 PM
meth user in need of help big16gwrx Mid Atlantic Impreza Club -- MAIC 13 05-25-2007 10:52 AM
meth users that track your car kinger Water/Methanol Injection, Nitrous & Intercooler Cooling 8 08-13-2006 09:52 PM
Hello, I'm a new meth user... POPOFF Water/Methanol Injection, Nitrous & Intercooler Cooling 6 04-26-2006 09:17 PM
Message Board Statistics All times are GMT -4. The time now is 12:06 PM.
