Go Back   NASIOC > NASIOC General > Motorsports > Autocross
Old 10-07-2009, 12:12 PM   #1
09rexwagon
Member#: 216135
2011 Civic SI
STX #66, 06 S2000 STR 180
Default Stage 1 puts you in SP or is STU ok?
Right now I'm trying to figure out if I can compete in STU with my stage 1 09 WRX (otherwise, I'll be in ESP). The verbage in some rules makes it seem that if you are not running stock boost, then you can't be in STU (or any other ST_ class) but then I see this in the SCCA solo rules for ST_:
"F. The engine management system parameters and operation may
be modified only via the methods listed below. Any and all
modifications must meet or exceed the applicable EPA tailpipe
emissions standards for the year, make, and model of the car.
These allowances also apply to forced induction cars, except that
no changes to standard boost levels, intercoolers, or boost
controls are permitted. Boost changes indirectly resulting from
allowed modifications are permissible, but directly altering or
modifying the boost or turbo controls, either mechanically or
electronically, is strictly prohibited.
1. Reprogrammed ECU (via hardware and/or software) may be
used in the standard housing
. Traction control parameters
may not be altered. Altered engine controllers may not alter
boost levels in forced induction engines."
The bold says that if you adhere to the italics, then you are ok. So an AP reflash should be ok in STU, however, I want to run this by more experience autocrossers. Seems a lot of people compete in STU with non stock boost levels.
09rexwagon is offline   Reply With Quote
Old 10-07-2009, 12:19 PM   #2
Chiketkd
Member#: 71634
In hibernation...
Stage 1 is not legal for STU as it intentionally raises boost.
If you add a legal downpipe (catted) & exhaust and get a legal protune, you'll probably end up making more power than a Stage 1 anyway. Boost creep resulting from a legal mod (catted downpipe) is ok. From my understanding, you can even tailor the timing and fuel in your protune to account for this boost creep. You just cannot intentionally raise the boost levels in your tune.
At the local level anything is possible. However, in national competition, there's a lot more at stake if you bring an illegal car.
Chiketkd is offline   Reply With Quote
Old 10-07-2009, 12:30 PM   #3
J-Rod 555
Member#: 209231
2008 WRX, 95 leggy
White to the both of them
with an 08/09 wouldn't we be in STX due to the 2.5l engine???
J-Rod 555 is offline   Reply With Quote
Old 10-07-2009, 12:57 PM   #4
09rexwagon
Member#: 216135
2011 Civic SI
It's a 2.5L Turbo, so that puts us in STU. An N/A 2.5L would be STX or a turbo 2.0L (bugeyes).
Old 10-07-2009, 01:44 PM   #5
J-Rod 555
Member#: 209231
2008 WRX, 95 leggy
good to know...
Old 10-07-2009, 01:56 PM   #6
Caelaorn
Member#: 88141
01 White Canyonaro
01 stook,loud broken kart
Technically I think you'd get thrown in to BSP, not ESP. There was a lively discussion about this, and the new body style wrx's got moved into BSP.
I believe only 02-07 are in ESP now.
Caelaorn is offline   Reply With Quote
Old 10-07-2009, 02:08 PM   #7
09rexwagon
Member#: 216135
2011 Civic SI
Interesting, any links on this? I can see maybe the 09 going to DSP (08 staying in ESP), but BSP that's a BIG jump.
Old 10-07-2009, 02:21 PM   #8
Caelaorn
Member#: 88141
01 White Canyonaro
Looks like i may have misread, I can only find reference to it being out for member comment in the fast tracks(http://www.scca.com/documents/Fastra...ack-july.pdf):
STREET PREPARED
- In conjunction with the related Tech Bulletins (#10 and #11) in the June 2008 Fastrack, the following correction to the previously-
published class listing change regarding the Subaru WRX is submitted for member comment:
- Move the Subaru non-Sti WRX (’08-’09) from ESP to BSP onto the same line as the ’08-’09 WRX STi and the ’09 Impreza GT.
(ref. 09-093, 09-125)
Internet fight about it: http://sccaforums.com/forums/thread/340803.aspx
Old 10-09-2009, 08:54 AM   #9
dingakasteve
Member#: 217274
2009 WRX
Rally Blue
if thats all you have for mods, if you have a AP I would detune before the race and run DS.
dingakasteve is offline   Reply With Quote
Old 10-09-2009, 09:15 AM   #10
09rexwagon
Member#: 216135
2011 Civic SI
Short shifter ....however, someone told me that the very fact that you can get an SPT short shifter as a 'factory' installed option, that it opens up the possibility of an aftermarket SS in stock class.
And get this, I think the OEM boost level for the 09 WRX is supposed to be 14.X but there are some non flashed 09s out there that are getting as high as 15.7psi with 0 mods. So with that said, let's say I get a down pipe and get a protune and have them make me a couple maps, one being an OEM boost level map.....what would I tell them to set it at?
Old 10-09-2009, 09:53 AM   #11
KC
Member#: 442
16 SS
00 S2000
No. Only the one installed as a port-installed option. Not aftermarket.
KC is offline   Reply With Quote
Old 10-09-2009, 10:16 AM   #12
09rexwagon
Member#: 216135
2011 Civic SI
Wow, how ironic that a short shifter bumps you out of stock class and yet you generally shift once or maybe twice during a given solo run. Anyway, I don't plan on doing DS anyway.
Old 10-09-2009, 11:04 AM   #13
J-Rod 555
Member#: 209231
2008 WRX, 95 leggy
WTF are you kidding...I have been running dstock all year with a short shifter, but my shifter is modified slightly lol. It is right near the steering wheel.
Old 10-09-2009, 12:20 PM   #14
Calamity Jesus
Member#: 44501
1984 That's *Sir*
Weinerlicks of Douche 2u.
If you're using an AccessPort and running STU, use the Stage 1 base flash and when you get to the autocross use the Realtime flash to go back to stock. This will return you to the stock boost map while keeping the better throttle mapping.
What's ironic is that no matter how much you shift, a "short shifter" doesn't make you any faster.
J-Rod's got the right idea for improving a shifter.. but is very much illegal for a stock class.
How is it you've been running all year and couldn't be bothered to read the rules just once? You can download them for free: here.
Old 10-09-2009, 01:03 PM   #15
GrantC
Member#: 94477
2005 WRX Stg2/STX
That should be "legal enough" for local stuff...
But I thought things like WGDC were in the base map, so your car would still not be STU legal.
GrantC is offline   Reply With Quote
Old 10-09-2009, 10:47 PM   #16
steveRS
Member#: 180430
2008 335i
I would talk to your tuner first and mention you need an SCCA STU legal tune. If one doesn't know what that is, go find someone who does.
steveRS is offline   Reply With Quote
Old 10-09-2009, 10:49 PM   #17
steveRS
Member#: 180430
2008 335i
You realize that is actually illegal to do.
Old 10-10-2009, 08:02 AM   #18
Calamity Jesus
Member#: 44501
1984 That's *Sir*
Obviously I didn't realize that. Is that because of the WGDC?
Old 10-10-2009, 04:47 PM   #19
tuskenraider
Member#: 65699
15 WRX
WR Blue
STU map has to be a base map, then have a real time street map allowing boost mod.
tuskenraider is offline   Reply With Quote
just put my new mods on/ is it ok to drive it to get dyno tuned? vpr88 Newbies & FAQs 6 05-20-2010 09:28 PM
06 WRX Ltd.--Prodrive DP--Do I NEED Accessport v2 or is v1 OK? platnumn AccessPort 8 02-21-2009 04:28 PM
Mechanic put 10w-20 in my STi, is that OK? Enchantor Service & Maintenance 24 04-26-2007 05:20 PM
is it stupid in here, or is it just you.. NWS material Fish Off-Topic 47 12-27-2004 04:36 PM
What class will x-drilled put you in? wastgate Technical Forum Archive 7 09-08-2000 06:17 AM
