Alaskan Impreza Club
Old 10-07-2009, 01:36 PM   #1
TurboSetch
Member#: 192358
MANY P3 Import Auto
907 355 6655
Default Does anyone sell studs for tires?
So I have a set of basically new winter tires with studs, but the studs are missing or worn to nothing. I was just going to sit down with them one night and pull the old studs out but I would like new ones to stuff back in the holes.Anything local around here where I can buy them?
TurboSetch is offline   Reply With Quote
Old 10-07-2009, 02:35 PM   #2
tribalwrx
Member#: 32993
vf39 Best trap 110
Best ET 12.51 Dale tuned
have you tried calling 6 robblies?
tribalwrx is offline   Reply With Quote
Old 10-07-2009, 02:42 PM   #3
TurboSetch
Member#: 192358
MANY P3 Import Auto
907 355 6655
Negative thought they were trailers only, will give them a call then.
Old 10-07-2009, 02:48 PM   #4
tribalwrx
Member#: 32993
vf39 Best trap 110
oh no they got more then just trailer stuff there
Old 10-07-2009, 03:01 PM   #5
KW900
Member#: 220013
2003 WRX
6 Robblees I think does, but you will need a stud gun to stud your tires.
Something like this:
http://www.myerstiresupply.com/shop/...&info=Stud-Gun
KW900 is offline   Reply With Quote
Old 10-07-2009, 03:23 PM   #6
TurboSetch
Member#: 192358
MANY P3 Import Auto
907 355 6655
Holes are already there. Not sure if gun will be required. Looks like it would make life easier though.
Old 10-07-2009, 03:47 PM   #7
KW900
Member#: 220013
2003 WRX
I don't think you can get them in without the gun. Sure the hole are there but the gun stretches the hole open so the stud will go into it.
Might be possible to do it by hand, but I sure wouldn't try to do it for 4 tires worth!
If I was still working at Sears I could probably pull some strings and do them for you, but I haven't work there in years.
Old 10-07-2009, 04:36 PM   #8
MrDubb
Member#: 181135
2006 Evo-R.I.P.
2003 Forrester
100 bucks and Alaska Tire will do it for you. Not sure if you can do it without a gun, the base of the stud is huge compared to the hole.
MrDubb is offline   Reply With Quote
Old 10-07-2009, 05:50 PM   #9
TurboSetch
Member#: 192358
MANY P3 Import Auto
907 355 6655
Hmm $100 might be worth if its for re-studding.
This year I should problably do a little less wheel spinning on dry pavement...lol
Old 10-07-2009, 06:02 PM   #10
MrDubb
Member#: 181135
2006 Evo-R.I.P.
2003 Forrester
I know what you mean, bought brand new Ipikes last year for the Evo and now will probably have to get them re-studded as well.
Not sure if you ever pulled old studs out, I've done it twice (too cheap to buy summer tires for my truck) and it sucks, dangerous too, those studs come flying out pretty fast. Don't bother pulling them out prior to re-studding, no need to do that.
Old 10-07-2009, 09:36 PM   #11
Arctic Assassian
Member#: 91875
91 legacy TD04
04 WRB/carbon fibre STI
Seth, you'll have to match the stud length with the amount of wear your tires have. If you go putting brand new studs that stick out past the tire, they'll come flying out with normal use. They sell different length studs to match the depth of the holes. And In my opinion, aluminum studs are superior to steel. Lighter at the circumference, (pick up a box of steel studs, then aluminum) about eight lbs for all four.
Arctic Assassian is offline   Reply With Quote
Old 10-07-2009, 09:53 PM   #12
kbeefy
Member#: 197417
no more subaru
mostly dirty
you don't want to use the existing holes, it's easy enough to drill new ones. Theres to good of a chance of a little rock or something being in there when you install the stud, when you drive on it theres a chance it will get pushed into the tire and cause a leak.
Don't think I'd worry about the unsprung or rotational weight difference of winter studs, I think it's pretty negligible compared to a whole tire. If you want aluminuim, do it to reduce road wear.
Edit: Oh yeah, stud gun would be mandatory. Unless you want to do a bunch, just pay someone to take care of it for you.
kbeefy is offline   Reply With Quote
Old 10-07-2009, 11:37 PM   #13
missiceblast
Member#: 142304
Setch check at the equipmnet rental places for a stud gun or someone should have one, maybe even a pawn shop
missiceblast is offline   Reply With Quote
Old 10-08-2009, 03:41 AM   #14
TurboSetch
Member#: 192358
MANY P3 Import Auto
907 355 6655
Gonna do the $100 option since I would spend that much in beer doing them myself it sounds like.
does anyone sell carbon fenders for an 02 wrx wrxburton Interior & Exterior Modification 2 06-29-2006 01:18 AM
does anyone sell pre-cut stone guard for 02 WRX fogs and headlights? caut10n Interior & Exterior Modification 4 09-30-2003 02:56 PM
Does anyone sell wiring harnesses for the stock HU? SC WRX Car Audio, Video & Security 1 03-14-2003 09:12 PM
Does anyone sell this for the WRX yet? Night Kid Interior & Exterior Modification 10 09-20-2002 06:06 PM
does anyone sell painted side skirts for a '01 RS auricom Interior & Exterior Modification 0 10-09-2001 03:28 PM
