Welcome to the North American Subaru Impreza Owners Club Thursday June 20, 2013
Old 05-10-2002, 09:51 PM   #1
Scoobie Steve
Member#: 2289
1998 11.87@112mph
Subaru L Ver 6 STi Type R
Default Haltech User's
Can some of you Haltech users out there send me your Maps. I got my car running ok based off of the wrx base map i found on a RX7 board. I had to richen up the fuel maps a little but i left the timing map alone. I would like to compare some numbers and see if i can get it running 100%. I have a stumble i cant get ride of no how.
Thanks,
Steve
Scoobie Steve is offline   Reply With Quote
Old 05-11-2002, 11:59 AM   #2
RallyNavvie
Member#: 7113
2008 Spec B
I dunno how well mine will relate to your seeing as I have a little different ignition system. I found a base WRX map and it wouldn't work with my car. One of the best things to do is to create a library map like the manual says and compare it to what your timing map looks like. My timing is still a bit retarded to be on the safe side.
When does the stumble happen? If it's on throttle tip-in you may have to adjust the throttle pump map.
~Garrett
RallyNavvie is offline   Reply With Quote
Verizon User's DILLIGAF Racing Mid Atlantic Impreza Club -- MAIC 44 05-03-2006 04:15 PM
Callin All S-afc 2 User's Help~! 98 Gt Turbo dingy Engine Management & Tuning 2 01-16-2006 03:05 PM
Handicap plate user's? Rock_Strongo Off-Topic 27 12-08-2005 12:42 PM
PC question... how to rename user's Document directory? Hazdaz Off-Topic 1 09-19-2004 10:58 PM
Stereo Recomendation - User's Experience? lavander Car Audio, Video & Security 16 12-01-2000 01:24 PM
Message Board Statistics All times are GMT -4. The time now is 05:24 AM.
