Go Back   NASIOC > NASIOC Chapters > New England Impreza Club Forum -- NESIC
Old 10-08-2009, 12:17 AM   #1
SubieNeeks21
Member#: 178661
05 3500 cummins
bullydogged
Default Walbro 255 Fuel Pump Install
Mods, I made this thread here because if it is anywhere else i never get a response.
I got a Walbro 255 fuel pump with no install kit. I remember seeing somewhere that you can re use the hoses from the oem fuel pump. Has anyone done this? and if i do need other materials what will they be?
SubieNeeks21 is offline   Reply With Quote
Old 10-08-2009, 12:18 AM   #2
xilles
Member#: 147056
7 sti
you can reuse everything from the stock fuel system
xilles is offline   Reply With Quote
Old 10-08-2009, 07:06 AM   #3
Geeoff
Member#: 106439
06 WRX TR
'05 Matrix XRS
Yes, you can just swap the pumps.
Geeoff is offline   Reply With Quote
Old 10-08-2009, 07:24 AM   #4
wit2003
Member#: 104395
2007 Element/99 GMC
1500/87MC-SS/00 Mirage
uninstall the stock pump and replace it with the walbro, you will know what you need to reuse.
wit2003 is offline   Reply With Quote
Old 10-08-2009, 09:17 AM   #5
mattminer
Member#: 90642
WKD Everything
exactly as above, jsut reuse all your stock parts for best luck
M@
mattminer is offline   Reply With Quote
Old 10-08-2009, 09:29 AM   #6
bren wrx
Member#: 59454
'10 E92 M3 M-DCT
brentuning.com/blog
yeah you dont need the install kit, you can just the big rubber plug washer in half to make room for it.
bren wrx is offline   Reply With Quote
Old 10-08-2009, 10:49 AM   #7
SubieNeeks21
Member#: 178661
05 3500 cummins
bullydogged
thanks for the help guys!
now to start the install!
Old 10-08-2009, 11:55 AM   #8
SubieNeeks21
Member#: 178661
05 3500 cummins
bullydogged
install went very well. took about an hour. thanks for the help!
FS: brand new walbro 255 fuel pump with install kit. olsonauwrx NWIC Private Classifieds 3 07-21-2009 03:44 AM
FS: brand new walbro 255 fuel pump with install kit. olsonauwrx NWIC Private Classifieds 0 07-20-2009 10:30 PM
*NEW* Walbro 255 Fuel Pump w/ Install Kit / NGK Plugs LFR7AIX STL06WRXSTi Engine/Power/Exhaust 8 06-14-2009 04:57 PM
FS: (FL) - Walbro 255 Fuel Pump + Install Kit, $75 Shipped REX_22 Engine/Power/Exhaust 1 10-16-2008 03:35 PM
Walbro 255 fuel pump install kit needed? Twiztidunreal Factory 2.0L Turbo Powertrain 2 04-14-2006 10:16 AM
Message Board Statistics All times are GMT -4. The time now is 07:47 PM.
