Old 10-09-2009, 05:21 PM   #1
Equilibrium Tuning
Member#: 26933
2006 STI
CGM
Default EQ Stage 1 Shortblock, EQ Stage 2 Heads, ATP 35R Stock Location, 91 + Meth = 450whp!
Event: Custom Tune/Road Dyno
Ambient Temp: 84 degrees Fahrenheit
Elevation: 200ft above
Weather: Sunny
Car: 2005 Subaru STi
Tuner: ED @ EQ Tuning
Peak HP at RPM: 450whp
Peak Torque at RPM: 421ft-lbs
Target Boost: 25psi peak
Fuel: California 91 Octane + 50/50 Meth Injection
Engine/Power Modifications:
- EQ Tuning Stage 1 Shortblock (CP Pistons, ACL Bearings, Forged STI Rods, Balanced/Polished Forged STI Crank, Balanced & Blueprinted to our strict specs)
- EQ Tuning Stage 2 Heads (BC S2 Cams, BC Titanium Springs/Retainers, 5 Angle Valve-Job, Bowl Blend)
- EQ Tuning Prototype Split Pulse Header/Uppipe
- ATP Stock Location 35R w/ Integrated Tial 44mm EWG (routed back into DP)
- TurboXS FMIC
- EQ Tuning Blow-Through MAF Kit for TurboXS/SSAC FMIC
- EQ Tuning Short Ram Intake Kit for Blow-Through Application
- Greddy Type RS BOV
- Invidia Catless Downpipe w/ custom flex EWG dump tube
- Invidia Catback
- EQ Tuning Baffled Oil Catch Can
- Deatschwerks 850cc Injectors
- EQ Tuning Dual Walbro Setup
- Perrin Fuel Rails
- Custom Oil Cooler
- Coolingmist Water/Meth Injection modified with all braided lines, S-HSV, and nozzle
- Grimmspeed Phenolic Spacers
- Hallman Pro RX MBC
- RPS Max Series Clutch / ACT Streetlight Flyhweel
- EQ Tuning Custom Tune on 91 Octane + 50/50 Meth/Water Injection @ 25psi peak
This is another project we recently wrapped up. It turned out to be quite a beast for a stock location setup and 91 Octane!
Here's the chart:
*** Standard Dyno Chart Disclaimer ***
This software reads low and should be compared to the lower reading mustang dynos. Here are some proven numbers and trap speeds for reference:
Stock WRX - 155-165whp
Stock STI - 215-225whp
265-275whp - 107-108mph traps
300-310whp - 112-113mph traps
325-335whp - 115-116mph traps
380-390whp - 120-121mph traps
*** End Disclaimer ***
Thanks
-- Ed
Equilibrium Tuning is offline   Reply With Quote
Old 10-09-2009, 05:38 PM   #2
blkscooby
Member#: 44422
2008 G8 GT
Burnouts on Central!
Wow, looks well sorted and a beast! Wonder what it would do on higher octane.
blkscooby is offline   Reply With Quote
Old 10-09-2009, 06:07 PM   #3
juanmedina
Member#: 133146
07 FPgreen 7.37@95
WRX VF39+E85 12.0, 121mph
wow really nice, and BC S2 Cams suck idiots.
91oct+meth=??
The spool is awesome
Do you have any details on this part? I may need one.
Old 10-09-2009, 06:24 PM   #4
Steve.804
Member#: 68647
07 STI
Rotated 35R Jorge Tuned
Damn Ed, that's probably a what...126-127mph car on meth? Not bad at all!! I'm really falling in love with these stock location big boys
Steve.804 is offline   Reply With Quote
Old 10-09-2009, 06:31 PM   #5
downsti
Member#: 63179
2006 Stock Turbo STi
11.7@113mph-115.6mph VF39
this is ****ing sick, man only if i had that power, haha 10s for sure
congrats to the owner,
and major props again to Ed.
downsti is offline   Reply With Quote
Old 10-09-2009, 06:43 PM   #6
Illusive
Member#: 90436
2005 STI
Obsidian black pearl
yummy
Illusive is offline   Reply With Quote
Old 10-09-2009, 07:15 PM   #7
Phatron
Member#: 36033
CEO PhatBottiTuning
2006 STi GTX3582 + Meth
is the up pipe 2 separate pipes?
what are the idc's with the 850's?
did you do a straight 91 oct tune? if so what were the idc's then?
im heading towards one of these atp35's.....but trying to wait until the twin scroll version is released.
** waits for 30 psi c16 tune and 8000rpm redline **
Old 10-09-2009, 07:16 PM   #8
Wrbimprezasti
Member#: 115505
2005 Sti
Stock VF39 12.4@109
errr stupid government computer cant see the chart haha! BUT GOOD JOB ED I'm sure its some crazy numbers because you do work miracles hahaha. Bet the customer's happy with the setup. Cant wait til i get back from my deployment next summer =) You'll be hearing from me hehe
Wrbimprezasti is offline   Reply With Quote
Old 10-09-2009, 08:22 PM   #9
renosubby
Member#: 152576
2006 STI 10.8@ 129
www.Mayhemtuning.com
HOLY S**T...talk about a fast car!!! PICS PLEASE!!!
renosubby is online now   Reply With Quote
Old 10-09-2009, 08:55 PM   #10
Equilibrium Tuning
Member#: 26933
2006 STI
CGM
91oct+meth=??
We've had very good luck with BC cams... not sure what problems others have had?
Our TXS/SSAC blow-through kit replaces one cold side and one hot side pipe. The cold side pipe is full 3" and mounts the MAF sensor in a convenient and strategic spot for consistent MAF voltages and lack of turbulance. The hot side pipe relocated the BOV to move it up stream and isolate it from the MAF. The kit comes with all necessary silicone couplers and clamps. Give us a call if you have any other questions: 707-425-2137.
Thanks
-- Ed
Old 10-09-2009, 09:00 PM   #11
Equilibrium Tuning
Member#: 26933
2006 STI
CGM
Yep, the UP is separated right until the turbo flange.
We're hitting 93% IDC on the 850's by 7500RPM and we're also injecting a decent amount of water/meth.
We never did a straight 91 tune... just made a safe backup map in case the meth runs out.
The customer is very happy with the current power levels and isn't planning on running race gas anytime soon. We have another car with a similar setup that will be running an AEM and that one will definitely be run on race gas
Thanks
-- Ed
Old 10-09-2009, 09:22 PM   #12
nation1979
Member#: 192914
06 sti
importimageracing is #1
saw this car in person.all their work is top knotch and and everyone pitches in to make sure the customer is 100% happy
nation1979 is offline   Reply With Quote
Old 10-09-2009, 09:44 PM   #13
2gnt2wrx
Member#: 123625
2002 wrx
vf34 Tuned at Cobb
So what fuel system do you guys suggest for this kind of setup?
2gnt2wrx is offline   Reply With Quote
Old 10-09-2009, 10:01 PM   #14
Duo
Member#: 38620
2005 Subaru WRX STI
World Rally Blue
wow, ed you always do awesome work. I cant wait till you get your parts on the open market so i can pick them up. Good work and keep it up.
Duo is offline   Reply With Quote
Old 10-10-2009, 11:26 AM   #15
rexworx
Member#: 103232
MY05 GDA, MY04 FXTI
2.5ltr,PPG,Front LSD,4.44
Great job Ed!!!
rexworx is offline   Reply With Quote
Old 10-10-2009, 04:09 PM   #16
achavez
Member#: 139320
2006 RA 1-4 5mt
wrx obp needs a e85 tune
any info on the header? its equal length right.. release date?..
achavez is offline   Reply With Quote
Old 10-10-2009, 06:51 PM   #17
traction issuez
Member#: 86559
2005 STi
how much does the block go for?
traction issuez is offline   Reply With Quote
Old 10-11-2009, 02:48 PM   #18
subenerd
Member#: 72630
2004 STi
Great looking power, doesn't look too laggy either.
subenerd is offline   Reply With Quote
Old 10-12-2009, 11:43 AM   #19
Equilibrium Tuning
Member#: 26933
2006 STI
CGM
850-1000cc injectors and dual walbro's. The rest is mostly optional.
-- Ed
Old 10-12-2009, 11:44 AM   #20
Equilibrium Tuning
Member#: 26933
2006 STI
CGM
It is equal length. This was more of a one off piece, so there's no release date scheduled yet. If you're interested, please give us a call.
Thanks
-- Ed
Old 10-12-2009, 11:46 AM   #21
Equilibrium Tuning
Member#: 26933
2006 STI
CGM
Here's a list of available packages:
http://www.i-club.com/forums/showthread.php?t=208768
-- Ed
Old 10-12-2009, 11:47 AM   #22
Equilibrium Tuning
Member#: 26933
2006 STI
CGM
Thanks! These bolt-ons really aren't all that laggy. Even the 35r hits 5-10psi very easily at low rpm's making for a very drivable and peppy setup around town. Of course you do have to downshift to get into the meaty part of the powerband, but that's what the 6 speed is for
-- Ed
Old 10-12-2009, 01:42 PM   #23
Scooby921
Thanks Sir Alex!
Member#: 88606
2011 GMC Sierra
1990 Miata
Please update the 1st post to reflect the newly required format as noted here:
http://forums.nasioc.com/forums/show....php?t=1858764
Scooby921 is offline   Reply With Quote
Old 01-15-2010, 08:07 PM   #24
Equilibrium Tuning
Member#: 26933
2006 STI
CGM
Updated!
Old 01-15-2010, 08:28 PM   #25
juanmedina
Member#: 133146
07 FPgreen 7.37@95
How much gains do you think the BC272 cams have on this built vs the same built with stock cams?
BNIB exedy stage 1 clutch 15804 $335 picked up Wannascooby SCIC Private Classifieds 19 07-15-2010 04:18 PM
[SOLD] 2004 WRX STI Stage 2 KIT,SPT Intake+Exhaust,Cobb AP,Custom Tune happyham SCIC Private Classifieds 3 06-09-2010 11:53 PM
Stage 2 or 3 clutch Garrek11 Private 'Wanted' Classifieds 10 06-08-2010 09:34 PM
[SOLD] 2004 WRX STI Stage 2 KIT,SPT Intake+Exhaust,Cobb AP,Custom Tune Socal happyham Engine/Power/Exhaust 4 06-06-2010 08:44 PM
2.2 heads on a 2.0 block chong74 Subaru Conversions 24 06-06-2010 03:41 AM
Message Board Statistics All times are GMT -4. The time now is 04:51 AM.
