Old 10-09-2009, 07:47 PM   #1
CALBANO1833
Member#: 223125
2008 Impreza WRX
Default Hella Supertones on a 2008 WRX
Ok i looked up and down the forumn and i found some awesome tutorials on how to install these bad boys. But nothing i saw was generation specific .. i have encountered a problem onj my 2008 .. i followed all the steps but ran out fo sunlight and had to stop my installation .. the only thing i have left to do is ground the hellas .. i thought that i would give it a whirl and see if they work with out the ground .. but they dont .. i realized that the horn norise is coming from under my cold air box .. does it make a difference what horn i unplugged or after i ground them should they work .. i dont know too much about wiring and i followed all the steps so hopefully all i need to is ground them ..
i think what im getting is the horn that i used (right on the center beam by the radiator) is that female connector what i need to connect or do i have to find the lower horn. lol im not sure if im making sence .. if im no im sorry .. please help!!!!
CALBANO1833 is offline   Reply With Quote
Old 10-09-2009, 08:04 PM   #2
20wrx09
Member#: 207417
2009 WRX
td06sl2-20gtx 413/423
there are two horns on the car, there is one on the right side of the car near the airbox, unplug it. use the horn wire that is connected to the radiator support for your hellas (it gets used for the relay). once you got that ground it and you should be good to go. if you need any pics or something i can pm you them so i dont clutter up the page
20wrx09 is offline   Reply With Quote
wiring hella ff1000's on a 2003 wrx distorto Electrical & Lighting 4 03-17-2010 07:11 AM
hella supertone on teh cheap nolanator Private 'Wanted' Classifieds 3 02-28-2010 05:52 PM
Where do you mount Hella Supertones on an 07 WRX?? Zerro0713 Newbies & FAQs 13 01-04-2010 09:10 PM
hella supertones on a 08 Sedlmeier101 Electrical & Lighting 3 02-20-2008 12:34 PM
Hella Supertones on a BD - wicked custom install!!!one!1 Patrick Olsen Legacy Forum 33 12-22-2005 04:45 PM
