Old 10-09-2009, 08:47 PM   #1
Equilibrium Tuning
Member#: 26933
2006 STI
CGM
Default EQ Stage 1 Shortblock, EQ Stage 2 Heads, VF39 + 91 Octane = 279whp/333ft-lbs!
Event: Custom Tune/Road Dyno
Ambient Temp: 80 degrees Fahrenheit
Elevation: 200ft above
Weather: Sunny
Car: 2005 Subaru STi
Tuner: ED @ EQ Tuning
Peak HP at RPM: 279whp
Peak Torque at RPM: 333ft-lbs
Target Boost: 19psi peak
Fuel: California 91 Octane
Engine/Power Modifications:
- EQ Tuning Stage 1 Shortblock (CP Pistons, ACL Bearings, Forged STI Rods, Balanced/Polished Forged STI Crank, Balanced & Blueprinted to our strict specs)
- EQ Tuning Stage 2 Heads (5 Angle Valve-Job, Bowl Blend, Stock Cams)
- Invidia Catless DP
- Greddy 3" Catback
- GT Spec UEL Headers
- Hallman MBC
- Walbro Fuel Pump
- RPS Max Series Street Clutch
- Stock VF39, Stock Inlet, Stock Intake Box, etc
- EQ Tuning Custom Tune using Cobb AP V2
This is a really simple setup on one of our nice built engines and performed extremely well for the simple setup. It took tons of timing with no hint of knock and made ridiculous torque for the fuel and boost levels. This is the first time we ran one of our built blocks and heads on a stock turbo, and its really nice to see the head work doing its job. This is one of the smoothest driving STI's I've ever tuned!
*** Standard Dyno Chart Disclaimer ***
This software reads low and should be compared to the lower reading mustang dynos. Here are some proven numbers and trap speeds for reference:
Stock WRX - 155-165whp
Stock STI - 215-225whp
265-275whp - 107-108mph traps
300-310whp - 112-113mph traps
325-335whp - 115-116mph traps
380-390whp - 120-121mph traps
*** End Disclaimer ***
Thanks
-- Ed
Equilibrium Tuning is offline   Reply With Quote
Old 10-09-2009, 09:20 PM   #2
nation1979
Member#: 192914
06 sti
importimageracing is #1
i cant wait for the stage 1 block/stage 2 heads on my setup.maybe throw in a little E85 for good measure
nation1979 is offline   Reply With Quote
Old 10-10-2009, 04:51 AM   #3
achavez
Member#: 139320
2006 RA 1-4 5mt
wrx obp needs a e85 tune
great numbers. EQ ftw!
achavez is offline   Reply With Quote
Old 10-10-2009, 01:05 PM   #4
renosubby
Member#: 152576
2009 GTR 10.7@ 133
Mayhem Tuning!!!!!
WOW..Ed that's crazy power for 91 oct... I am still trying to get there. hopefully the student can get some where near the master.
renosubby is offline   Reply With Quote
Old 10-10-2009, 03:51 PM   #5
BUILTSTI
Member#: 204644
2005 STi 10.7 @ 125
FPRED PUMPGAS 93oct
Good stuff for 91..
I believe it
BUILTSTI is offline   Reply With Quote
Old 10-10-2009, 04:15 PM   #6
verc
Member#: 41754
03 wrx
gt35r, 2.5L, meth
that's a good graph - really hammers home the point: all that matters in the end is the airflow restrictions at a given rpm. Lots of torque early on from letting the turbo flow everything it can, with limiting factor being turbo and cams up top...
verc is offline   Reply With Quote
Old 10-11-2009, 03:01 PM   #7
subenerd
Member#: 72630
2004 STi
This is the kind of engine build I would want if my motor were to fail... (*crosses fingers*).
Ed, how much more power do you think this setup would yield with a stock location 3071 (and injectors/IC)?
Great job as always.
subenerd is offline   Reply With Quote
Old 10-11-2009, 04:06 PM   #8
pooster.online
Member#: 120461
2004 WRX STi JBP
does the additional headwork add any extra power as opposed to a stock head on the vf39 turbo?
pooster.online is offline   Reply With Quote
Old 10-11-2009, 05:01 PM   #9
renosubby
Member#: 152576
2009 GTR 10.7@ 133
Mayhem Tuning!!!!!
I would say around 330-350whp on eds dyno!
Old 10-11-2009, 05:32 PM   #10
verc
Member#: 41754
03 wrx
gt35r, 2.5L, meth
Well Ed's done a few 3071s that did something like 310-320whp, not quite a Green but better response. I'd guess a 3071 car with just headwork but no cams would do similar HP, but hit that peak earllier and have more torque down low.
You can see on this vf39 graph that peak hp and the top end is not any better than with stock heads, but the lowend is much freed up. It's all down to what the major airflow restriction is at a given rpm.
Old 10-11-2009, 05:52 PM   #11
renosubby
Member#: 152576
2009 GTR 10.7@ 133
Mayhem Tuning!!!!!
only reason I state this is cause on a 20g I made 322 on his dyno at 4500 ft elevation!
old but yea
had wiring issues so graph isn't to ed's liking either.LOL
Old 10-11-2009, 11:16 PM   #12
downsti
Member#: 63179
2006 Stock Turbo STi
[email protected] VF39
bad ass work once again ED,
and congrats to the owner for the new found power,
downsti is offline   Reply With Quote
Old 10-12-2009, 11:49 AM   #13
Equilibrium Tuning
Member#: 26933
2006 STI
CGM
With a good setup, the 3071 is capable of about 320-325whp on 91 Octane. The 3076 can do about 340-345whp. Good cams can add about 15-20whp on pump as well.
Thanks
-- Ed
Old 10-12-2009, 11:51 AM   #14
Equilibrium Tuning
Member#: 26933
2006 STI
CGM
This car did make very good power and held it very well considering its running a stock inlet and intake. I can't say that this is 100% attributed to the head work, but I do believe it helps to fill out the powerband and smooth the car out all around. With a larger setup, you'll find bigger gains from the head work.
This customer is planning on going bigger later... this was just the first step.
Thanks
-- Ed
Old 10-12-2009, 01:42 PM   #15
Scooby921
Merci Buckets
Member#: 88606
2016 Cayman GTS
Dark Blue Metallic
Please update the 1st post to reflect the newly required format as noted here:
http://forums.nasioc.com/forums/show....php?t=1858764
Scooby921 is offline   Reply With Quote
Old 10-12-2009, 01:59 PM   #16
STi Mikey
Member#: 114631
2009 GTR, 735whp
13' Benz, 15' WRX
Thanks
-- Ed
Headwork will help a vf39 set up on pump gas. With 272's, an sti was able to pick up 12 whp and 30ft lbs with no porting.
However, if the owner plans on doing a race gas tune before going bigger, you will still hit that 340ish whp wall.
STi Mikey is offline   Reply With Quote
Old 01-15-2010, 08:02 PM   #17
Equilibrium Tuning
Member#: 26933
2006 STI
CGM
updated!
EQ Tuning: 2003 WRX + Full JDM V8 Swap + 18g + 91 Octane = 308whp Equilibrium Tuning Proven Power Bragging 12 04-27-2010 05:17 PM
EQ Stage 1 Shortblock, EQ Stage 2 Heads, ATP 35R Stock Location, 91 + Meth = 450whp! Equilibrium Tuning Proven Power Bragging 28 01-20-2010 02:30 PM
EQ Tuning Stage 1 Shortblock + Blouch DOM 3.0R + 91 Octane + Meth = 384whp! Equilibrium Tuning Proven Power Bragging 34 03-19-2009 08:52 PM
93 stage 2 map with 91 octane omdwrx508 Commercial ECU Reflashes 7 09-12-2007 05:21 PM
Vishnu Stage 2 STi dynosheet 91 octane and racegas pio!pio! Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 0 09-10-2004 12:42 PM
