Welcome to the North American Subaru Impreza Owners Club Saturday September 24, 2016
Old 10-10-2009, 08:08 PM   #1
thenexlevel
Member#: 226449
Default 98 Legacy Outback - Temp Sensor Overheats and No More Cabin Heat???
Hey guys,
Just picked up a 98 legacy outback yesterday for the winter dd and it was driving fine until today I noticed that the coolant temp sensor all of a sudden shoots up to H and stays there. I pulled the car over and popped the hood and didn't see any smoke or leaking anywhere...so I'm guessing this is a sensor issue? But whats weird is cabin heat no longer works wither...turned it up all the way with heat and its just blowing cold air.
Are these two things related somehow or totally different? Any suggestions for me?
thenexlevel is offline   Reply With Quote
Old 10-10-2009, 09:30 PM   #2
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
If you're lucky it's a stuck thermostat, if you're not it's a head gasket. Either way don't drive it any more until it's diagnosed and fixed.
Old 10-11-2009, 12:00 AM   #3
Degenerate
Member#: 226469
Get it diagnosed...
Degenerate is offline   Reply With Quote
Old 10-11-2009, 10:18 AM   #4
Charlie-III
Member#: 30669
1998 Legacy 2.5GT
Silver Sleeper Wagon
+ a bazillion.
I would almost bet you have 1 or 2 bad head gaskets (AKA, "HG's").
I have been through 2 sets in my 98 Legacy GT and one set in my wifes 99 Impreza L (I know, I know, "The 2.2L's NEVER blow HG's").
I would first research "burping the coolant system" and see if that fixes your issue.
If that won't help, you can try and replace the thermostat in the water pump.
But in the end, I feel you will need to either do HG's or a junkyard engine (or rebuilt if you have the money).
Old 10-11-2009, 06:50 PM   #5
thenexlevel
Member#: 226449
I spent a good amount of time with this, drained oil and did not see coolant, looked in the overfill bottle and coolant was gone....strange. I flushed out the radiator and drained what came out from the theromostat and replaced it...made sure to burp the system and same thing.
The car will heat up to a certain point while idling and it won't move until I start driving the car...then it heats up really fast and overheats. While its idleing and the temp is 1/2 way on the gauge there is no heat...
Something interesting I found out, after the car heated up, I squeeze the upper radiator hose and its hot and expanded but when I sequeeze the lower radiator house, its not hot and hardly full at all. This makes me think there isn't coolant being circulated into the engine and it sounds like its the water pump. If the water pump failed, would this be the situation?
I'm debating if i should try to replace the water pump/timing belt tonight.
Old 10-11-2009, 09:21 PM   #6
Charlie-III
Member#: 30669
1998 Legacy 2.5GT
I have yet to see a Subaru water pump fail.
Normally, when ANY vehicular water pump fails, it leaks through the shaft seals and drops coolant on the ground, it does NOT stop circulating coolant.
I still say, sorry, that you have a failed HG.
Old 10-11-2009, 10:35 PM   #7
thenexlevel
Member#: 226449
I come from other cars where if there is a blown head gasket, you will see coolant mix with oil. You'll see it either in the oil pan or in the coolant overfill, the coolant has to go somewhere if the head gasket is going bad.
So can someone explain to me how a blown head gasket can casue my overheating problem if the coolant isn't flowing somewhere its not? Where else can the coolant be flowing then?
Old 10-11-2009, 11:00 PM   #8
69subaru360
Member#: 159682
1995 WRX
2015 F150
Exhaust gas pushes into the coolant. It's extremely common. Most of the 96-99 Outbacks blow the head gaskets eventually. Only use the latest part number gaskets from a Subaru dealer to fix it or you will be doing it again.
Old 10-11-2009, 11:15 PM   #9
thenexlevel
Member#: 226449
So what happens exactly? The coolant doesnt' leak but exahust gas gets into the coolant? So it creates air pockets or does it overheat the coolant?
Old 10-11-2009, 11:42 PM   #10
69subaru360
Member#: 159682
1995 WRX
2015 F150
It heats up the coolant, pushes it out the overflow and makes air pockets. So yes to all of the above.
Old 10-12-2009, 02:32 AM   #11
iluvdrt
Member#: 46248
82 Brat
Tan
If it is a 2.5, you have a blown HG. Mine did this on every occasion the HG was blown. I bet after driving it for a few miles (10) the over flow bottle is full too.
iluvdrt is offline   Reply With Quote
Old 10-12-2009, 03:22 AM   #12
Charlie-III
Member#: 30669
1998 Legacy 2.5GT
Yep, all mine did it as well as my wifes (like I listed before).
None of them had oil in the coolant or coolant in the oil.
All of them would push coolant into the overflow, it would overfill and dump on the ground (when hot) and then the radiator would show up low later when cool.
I would have temp spikes, a cold heater, loss of coolant, etc.
This is VERY common on the phase-1 2.5L NA engines.
The later (~1999+) phase-2 engines also had HG issues, but those just leaked coolant on the ground.
98 Legacy Outback and SUS parts nojokesniper Legacy Specific Parts 21 05-09-2009 11:46 AM
WTB 98 or 98 legacy outback wheels. d0n Private 'Wanted' Classifieds 0 03-03-2008 02:55 PM
98 Legacy Outback crankshaft position sensor Beestieboy Outback Forum 4 08-18-2007 10:40 PM
98 Impreza exhaust fit a 98 legacy outback? IllNastyImpreza Normally Aspirated Powertrain 2 09-09-2006 12:47 PM
98 Legacy Outback front bumper 98legacygt117 Interior & Exterior Modification 0 12-06-2001 02:43 PM
