Old 10-11-2009, 12:45 AM   #1
Pinned
Member#: 152707
Default Timing belt cover and checking the timing belt
So I have the replace my left timing belt cover as it has a hole in it. While I'm doing this is there a quick or easy way to check out the timing belt just to make sure it is OK? Should I do a visual inspection? If so what should I look for?
It's a 2004 WRX engine by the way.
Thanks for any help.
Pinned is offline   Reply With Quote
Old 10-11-2009, 11:01 PM   #2
Unabomber
👌 Big Ron 👌
Member#: 18062
on car parts so PM
me b4 j00 buy
You don't "check" the timing belt. You replace it at 105k....that's it.....replace.
Old 10-12-2009, 02:10 AM   #3
Pinned
Member#: 152707
Alright, thanks. I was just a bit worried about premature wear since there is a small hole in the rear left timing belt cover, possibly exposing the belt to the elements more than normal. I was told it wasn't a big deal, but I figured it would be better to double check.
Old 10-12-2009, 08:57 PM   #4
slc ya
Member#: 226671
since you will have the cover off anyways, it can't hurt to take a good look at it. If you see any fraying or cracks then you should replace it. Timing belts are tough so unless you see something out of the ordinary then I wouldn't worry about it. How many miles do you have on your car?
slc ya is offline   Reply With Quote
Old 10-13-2009, 02:30 AM   #5
Pinned
Member#: 152707
The engine was custom built, blew a road bearing and was then rebuilt. The block has about 70,000 on it, but I'm not really sure about the timing belt.
Old 10-22-2010, 09:36 AM   #6
c10seth
Member#: 258526
2014 WRX Limited
I'm in the same boat. The engine in my 02 WRX wagon was rebuilt by the previos owner and he claimed the motor only has about 70k on it. not sure on the timing belt. I think I'll just freakin change it for peace of mind.
Seth
c10seth is offline   Reply With Quote
Old 10-25-2010, 01:00 PM   #7
rkramer
Member#: 118209
2015 WRX Limitec
to add to that, its also 105 months, which is what 02's are starting to fall into now. Even if you have an '02 with under 105k miles, its time to replace!
Old 10-27-2010, 12:47 PM   #8
c10seth
Member#: 258526
2014 WRX Limited
Question
Thanks for the info guys. Now, this is going to be a horribly trivial question, but I wanted to ask before I try. Can I remove the left side timing belt cover to inspect? I want to see the belt before I make another trip to my local dealer and spend another *** load of cash. Thanks for your help and patients. This has been an awsome forum for all my scooby noobie questions ^_^.
Seth
Old 10-29-2010, 10:02 AM   #9
c10seth
Member#: 258526
2014 WRX Limited
Seth
Update: I said screw it and decided to have the dealership install a new timing belt and idler pulley. The peace of mind is worth the $700 bone.
Seth
Old 11-04-2010, 10:22 AM   #10
X Mon
Member#: 156443
2006 WRX Wagon WRB
2001 Forester S, EJ205/5m
If it's the rear cover that's broken, you'll need to pull both of the cam gear pulleys to change it anyway. This means the belts coming off regardless, and as such, I'd recommend replacement. I just did this the other night, and it was around 2 hours round trip. Make sure you find a hardened 10mm for the pulley bolts.
Update: I said screw it and decided to have the stealership install a new timing belt and idler pulley. The peace of mind is worth the $700 bone.
Seth
Fixed. I just threw up a little in my mouth. Sounds WAY high. I'd shop around for a good indie, or find someone local to give you a hand.
X Mon is offline   Reply With Quote
Old 11-04-2010, 10:28 AM   #11
c10seth
Member#: 258526
2014 WRX Limited
Stealership is right even though I'm happy I did it if that makes any sense. My wagon is my only car and the dealership may charge out the ***, but they do a good job, on time, have a good loaner car and I trust the tech who does the work on my car. The idler pulley was loose and the belt was begining to eat into the bracket. I'll post some pics up later.
Seth
Old 11-07-2010, 01:22 AM   #12
Pinned
Member#: 152707
Thanks for the advice, but I had the timing belt done and the cover repaired nearly a year ago.
Also, $700 isn't bad if it included the tensioner and water pump. If it didn't, then I absolutely agree with you.
Old 11-08-2010, 10:17 AM   #13
AZP Installs
Member#: 40160
Also when doing the timing belt you should do the idler pulleys as well.
We do a service for $850 which includes the Idlers, Tensioner, Belt, Water Pump, T-stat, and the WP and TS gaskets, and of course a coolant flush. When done in conjunction with the 90k service it drops to $750.
-mike
AZP Installs is offline   Reply With Quote
Old 12-27-2015, 06:42 PM   #14
chef818
Member#: 432540
Can you just replace the driver's side outer timing belt cover without taking the belts and pulley off?
chef818 is offline   Reply With Quote
Old 12-28-2015, 12:09 AM   #15
CosmoTheCat
Member#: 3409
98 My FMIC
Is bigger than yours.
Yes. Depending on the engine it'll either be three or four bolts that hold it on. You may need to pull the coolant overflow bottle.
CosmoTheCat is offline   Reply With Quote
WTB: Camshaft Gears, timing belt cover and other parts. NFJ79 Private 'Wanted' Classifieds 1 01-19-2008 12:55 PM
WTB: 2.2L Timing Belt Covers and Throttlebody Erconcepts Private 'Wanted' Classifieds 1 01-13-2008 12:00 AM
WTB: 2.2L Timing Belt Covers and Throttlebody Erconcepts NWIC Private Classifieds 1 01-12-2008 02:57 PM
02 front timing belt covers and overflow bottle skate enjoi Private 'Wanted' Classifieds 9 04-02-2007 03:21 PM
WTB timing belt cover and cam gears kellygnsd Private 'Wanted' Classifieds 4 07-18-2005 12:16 PM
