Old 10-11-2009, 09:12 AM   #1
jrduck1
Member#: 226483
Default 1999 Legacy Limited Outback Wagon PO440 trouble code
I have a code that keeps coming up n my 1999 limited outback 30th anniversary wagon, code is PO440 = Evaporative emmision control system malfunction. When I take the gas cap off there is no pressure, is there suppose to be pressure at the gas cap on 1999 30th anniversary model wagon?, I have a 1997 and had 1998 that did have positive pressure when you took the gas cap off, but the 1999 doesn't. I checked canister and all vacume lines that I can get to, no leaks found yet, I tried to pressurize tank and lines, but it won't pressrize with 5psi of air. I'm going to do a smoke test this week on it. Checked purge solonoid valve - working OK, when does that valve open. Checked gas cap, lets air in to release vacume on tank, but doesn't let pressure out. I have a rough idle also, but I have 21psi vacume at the throttle body where it hooks to the evap line going back to gas tank. but the purge valve is closed while ideling, I looked at the service manuals and this is a one year only design for the evap system.
Thanks James
jrduck1 is offline   Reply With Quote
Old 10-13-2009, 09:19 AM   #2
jrduck1
Member#: 226483
Default Smoke test results for post.
Leak at filler neck, 2" below cap, took cover out of rear fender well, filler neck rusted thru and fillier valve ate thru, plastic cover that protects filler neck was full of mud and road salts, only leak found on evap system so far, ordered new neck and valve, going to rhino line new parts, then install or just leave cover off, at least I can wash out the fender wells in the spring time, bad design idea by Subie, went to junk yard to pull one, this is a one year only design for 1999. 126.00 for neck and 78.00 for valve. Will post results and let you know if PO440 code comes back or if this fix resolves problem.
Old 11-15-2009, 12:41 AM   #3
viperrf16
Member#: 126470
1999 Legacy Outback
White/Sand
How did it work? O just bought a slightly used 99' outback. Doing alot of work to it. Have you had any other issues? So far I'm just working on corrosion, lighting and body work....
viperrf16 is offline   Reply With Quote
WTB: PA 1998 or 1999 legacy gt black wagon 5spd phate1229 Private 'Wanted' Classifieds 5 05-28-2011 06:55 AM
06' 2.5 i Limited Outback Wagon 5-SP Button Outback Forum 0 09-19-2006 11:55 AM
wanna see a '98 legacy limited outback sedan pleez dingo dave Member's Car Gallery 4 04-13-2004 08:06 PM
How hard is it to find a '98 Legacy limited outback sedan? dingo dave Legacy Forum 8 04-13-2004 03:00 PM
Oil leak question for 1999 Legacy Limited Edition ericb49 Legacy Forum 4 09-23-2003 10:24 AM
