Alaskan Impreza Club
Old 10-11-2009, 11:52 PM   #1
kbeefy
Member#: 197417
no more subaru
mostly dirty
Default tinkering with my subaru this weekend...
Finally installed a boost gauge I bought from Klanner last summer.
Removed the intake silencer/snorkle from the fender.
Installed new air filter.
Cleaned MAF.
Springs didn't show up yet so I spent some time looking at some KYB boxes.
Installed a manual boost controller.
Pulled and regapped the plugs, they were WAY out. (.060-.075 instead of .028)
Bought supplies to delete the intake resonator, gonna try to build that at work tomorrow.
Installed additional front camber bolts, tires finally looking about right.
Rotated worn front tires to rear to try out the new camber settings.
I can say that the MBC has made this car a different animal. Guess I had it set a little high on the first test drive, when the boost came on it hit like a damn truck! First time this car has actually snapped my head back. Seems I was hitting 15psi briefly, got it turned down to 12 but am still having fueling issues, I'll get it down around 10 tomorrow.
Between the exhaust and intake mods, I'm really starting to like the way this thing is sounding.
Hopefully I'll be ready for the rallyx school this weekend, still got a pile of projects to get done.
kbeefy is offline   Reply With Quote
Old 10-12-2009, 01:34 AM   #2
greenspeed
Member#: 151248
00 Impreza 2.5RS
Whore Door
Can I have your old front camber bolts?
greenspeed is offline   Reply With Quote
Old 10-12-2009, 01:49 AM   #3
kbeefy
Member#: 197417
no more subaru
mostly dirty
still using them. The ones I installed replaced the non-adjustable lower bolts.
Old 10-12-2009, 06:20 AM   #4
greenspeed
Member#: 151248
00 Impreza 2.5RS
Whore Door
so you're running 4 adjuster bolts on each strut?
Old 10-12-2009, 12:11 PM   #5
kbeefy
Member#: 197417
no more subaru
mostly dirty
well, 2 on each strut. 4 on the front of the car.
Old 10-13-2009, 01:24 AM   #6
kbeefy
Member#: 197417
no more subaru
mostly dirty
took the rear struts out tonight, need to borrow a strut compressor tommorow then hopefully pull the fronts.
Old 10-13-2009, 01:32 AM   #7
greenspeed
Member#: 151248
00 Impreza 2.5RS
Whore Door
autozone lends them out...however idea where one is in Alaska
Old 10-13-2009, 03:12 AM   #8
kbeefy
Member#: 197417
no more subaru
mostly dirty
I think the alaska one is in washington.
I know a shop that will let me use theirs.
If I could find some Group N tophats I'd like to run those instead of my old squishy stuff. Trying to track down the aplication for it but legacy central seems to be on the fritz.
Old 10-13-2009, 09:38 PM   #9
Arctic Assassian
Member#: 91875
91 legacy TD04
04 WRB/carbon fibre STI
That car will be dangerous... GC parts bolt right on, anything after 02 needs the strut tower bolt holes modified a bit. Wagon parts fit better than sedan parts, except struts(they're the same.)
Arctic Assassian is offline   Reply With Quote
Old 10-13-2009, 11:52 PM   #10
kbeefy
Member#: 197417
no more subaru
mostly dirty
in the middle of installing KYB AGX struts and ground control coilovers right now. Had to do some modifications, but I think it'll turn out nice. Pics soon....
Old 10-14-2009, 12:28 AM   #11
missiceblast
Member#: 142304
SWEET! we'll see it on sat/sunday???
missiceblast is offline   Reply With Quote
Old 10-14-2009, 12:53 AM   #12
greenspeed
Member#: 151248
00 Impreza 2.5RS
Whore Door
except you get butt sag for some reason using the newer suspension, on the 2g's that is...
Old 10-14-2009, 02:27 AM   #13
kbeefy
Member#: 197417
no more subaru
mostly dirty
Didn't like how the coilover sleeves fit the struts, so I modified them a bit.
Didn't have time to pull the fronts tonight, hopefully early enough tomorow to get to the compressor before closing time.
I have every intention of being ready this weekend, I already registered, paid and got time off work.
Old 10-14-2009, 02:33 AM   #14
Arctic Assassian
Member#: 91875
91 legacy TD04
Can you reverse that mod? Did you cut the lower spring perch off?
Old 10-14-2009, 05:27 AM   #15
greenspeed
Member#: 151248
00 Impreza 2.5RS
Whore Door
basically looks that way, however just hope those springs are ganna be beefy enough k, cause they look a little like pansy springs, whats the rate and rebound on them?
Old 10-14-2009, 11:33 AM   #16
kbeefy
Member#: 197417
no more subaru
mostly dirty
definatly not reversible. Yes, thats the lower sitting beside them.
I'm not gonna have rubbing problems on the struts
Guess you haven't used 2.5 springs before? These are 200# rears and 250# fronts. If I decide I don't like them it's easy to change spring rates, Eibachs go over 800#.
Pretty sure theres no rebound rating for a spring, but the AGX go at least 150% of stock, I've been told they're good enough for 300# springs.
Old 10-14-2009, 06:56 PM   #17
greenspeed
Member#: 151248
00 Impreza 2.5RS
Whore Door
There's usually 2 numbers incorporated with springs, ones the rate what,s the second? Clutching springs are like 110/200 so basically it would be considered pro active springs with 2 different rates then?
Old 10-14-2009, 07:10 PM   #18
Arctic Assassian
Member#: 91875
91 legacy TD04
I like that mod. I've never seen it before. I might do this when I start driving my legacy again. I've got a set of those AGX's too along with a set of those sleeve's. Make sure you measure the ride hight change before and after you install them. sweet deal.
Old 10-15-2009, 02:52 AM   #19
kbeefy
Member#: 197417
no more subaru
mostly dirty
these are single rate springs, not progresives. The do have two numbers, but it's inside diameter and spring rate. Since my springs are 2.5" springs, they're 200.250 and 250.250.
Got the front together and on, after fighting with a stripped strut nut for a while (my fault).
I measured ride height before, but it was too dark after. I'll check tommorow. I really like the ride, it's much stiffer and more responsive now. Dive/lift and roll are almost gone, during the brief test drive around the neighborhood.
I did notice some noise, I think it's the springs rubbing on the collars, but I'll check it out tommorow to be sure.
Old 10-15-2009, 05:26 PM   #20
Arctic Assassian
Member#: 91875
91 legacy TD04
those sleeves tend to be noisy.
Old 10-15-2009, 09:39 PM   #21
kbeefy
Member#: 197417
no more subaru
mostly dirty
so heres the before/after shots, can hardly tell a difference without a tape measure.
Measurements from the center of the hub to the bottom of the fenderwell:
Front: 14 5/8" before, 15 1/2" after
Rear: 14 1/2" before, 15" after
The adjusters are as low as they will go, and it's tiny bit higher than stock. This is good, as my intentions are to add a little lift, I'm just waiting on camber solutions for the front. There are some Camber plates en-route, when those arrive I'm planning on going up approx 1 1/2" more in the front and 1" in the rear, or whatever combination gets the car a bit more level and still allows me enough camber to keep the tires looking decent.
If anyone is wondering, I got 12" coils, 10" coils would lower the car 0-2" depending upon spring rate.
Old 10-17-2009, 06:47 AM   #22
Arctic Assassian
Member#: 91875
91 legacy TD04
Ah ha! This means you can go higher!
Old 10-17-2009, 12:08 PM   #23
kbeefy
Member#: 197417
no more subaru
mostly dirty
Precisely! Thats exactly why I choose this setup. As soon as my camber plates show up @ Underground I'll be jacking it up.
Anyone down on working on a subaru this weekend? sizzflair Tri-State Area Forum 13 03-24-2010 12:15 AM
My weekend date with my Subaru - Missing the Tri-Staters Chandy69 Tri-State Area Forum 12 01-18-2010 11:58 PM
My stupid neighbor backed a truck into my car this weekend Layman Off-Topic 89 02-11-2009 06:28 PM
saw an interesting subaru this weekend.. paultg New England Impreza Club Forum -- NESIC 9 10-05-2000 08:47 AM
Can anybody help with spring replacement this weekend? Dan_E Bay Area Impreza Club Forum -- BAIC 5 05-03-2000 06:21 PM
