Welcome to the North American Subaru Impreza Owners Club Monday January 26, 2015
Go Back   NASIOC > NASIOC General > Motorsports > Autocross
Old 10-12-2009, 10:57 AM   #1
pinkertonpunk
Member#: 62386
2008 Honda S2000
Chicane Silver
Default APS Intake for STU, 65mm or 70mm?
Hey guys, I plan on doing a few more power mods for next season and need to find out which intake would work better. I am going to be buying an APS intake but I don't know if I should buy the 65mm or 70mm. This is going to be for STU for no boost or wastegate tuning allowed, I am really just looking for more power and need to find out which would be better for spoolup if any or which would be better for more power. I don't plan on really doing anything different to the car after I stop racing it, so that isn't a concern, I just need to find out which would be better for STU. I will be having it tuned again for sure, so that is not a concern either.
The intake will be paired with a turbo inlet, either a Perrin or Samco and I will be buying a ported stock exhaust manifold as well. All I have currently is a turbo back exhaust and a tune.
pinkertonpunk is offline   Reply With Quote
Old 10-12-2009, 12:03 PM   #2
mccanixx
Member#: 60566
2005 XT 5sp, 02 WRX
01 Legacy 95 Impreza L
With-in the STU ruleset I don't think there be a huge difference between the 2.
They both lean the car out which allows for additional fuel, which had an impact on my car when it was in STX. I ran the 65mm
If I was purchasing one right now I would get the 70mm......I'm actually looking for a used one.
my.02
Greg
mccanixx is online now   Reply With Quote
Old 10-12-2009, 01:23 PM   #3
Splash
Member#: 55936
04 WRX STi
I know the cars with bigger injectors and bigger turbos run into the MAF ceiling quickly, but I don't know if I've seen a stock turbo/stock injector car do it. I'd say if you don't plan on changing either part, the 65 would be fine.
Splash is offline   Reply With Quote
Old 10-12-2009, 01:29 PM   #4
Dirty25RS
Member#: 56731
2004 STi, 00 Insight
10 Volvo C30R-d 11 F150
bigger is better. u want less restriction, less energy loss. as long as it doesn't screw up the MAF or have any weird aerodynamic internal disturbances.
If you really want better spool up replace all the other intake piping as well. You want rigidity for spool up. pipe flexing yields lag.
I've heard you can drop peak boost by 500rpm @ WOT by getting rigid piping.
Dirty25RS is offline   Reply With Quote
Old 10-12-2009, 01:59 PM   #5
pinkertonpunk
Member#: 62386
2008 Honda S2000
Chicane Silver
I plan on replacing all the piping to the turbo. I can't do hard pipes though since the only one available is the APS which isn't legal. I will be doing an APS intake and then probably the two Perrin hoses from there which will cover everything up to the turbo.
Sounds like 70mm will be the way to go though.
Old 10-12-2009, 02:12 PM   #6
boyracer_05
Member#: 126171
2005 Silver STi
Out of curiosity, what makes the APS inlet illegal for STU? I am looking for a similar setup as currently I only have a turboback on the car.
boyracer_05 is offline   Reply With Quote
Old 10-12-2009, 02:14 PM   #7
pinkertonpunk
Member#: 62386
2008 Honda S2000
Chicane Silver
I don't know exactly but I think it has something to do with modifying the fuel system in some way which you can't do per the rules.
Old 10-12-2009, 04:24 PM   #8
STirish
Member#: 71515
'06 STi
Both of the APS intakes cause a little inconsistency in fueling due to the flow around the MAF. That being said the 65mm should be tuned for and the 70mm 100% requires a re-tune of the MAF curve.
Rob
STirish is offline   Reply With Quote
Old 10-12-2009, 04:36 PM   #9
pinkertonpunk
Member#: 62386
2008 Honda S2000
Chicane Silver
Originally Posted by STirish View Post
Both of the APS intakes cause a little inconsistency in fueling due to the flow around the MAF. The being said the 65mm should be tuned for and the 70mm 100% requires a re-tune of the MAF curve.
Rob
Jorge at P&L would be doing the tuning so I am sure that is something he can do. Thanks guys, I think I will be going with the 70mm then since that is what Jorge thought I should do anyway.
Old 10-12-2009, 05:04 PM   #10
Chiketkd
Member#: 71634
In hibernation...
Colin,
So what did you find out about your engine? Is everything okay?
-Chike
Chiketkd is offline   Reply With Quote
Old 10-12-2009, 05:36 PM   #11
pinkertonpunk
Member#: 62386
2008 Honda S2000
Chicane Silver
Originally Posted by Chiketkd View Post
Colin,
-Chike
No, I am going to be rebuilding it over the next month or so now that the season is over. I will need at least 2 pistons once the job is done. I am going to start taking the engine out after work tomorrow. Just planning more engine mods for next year.
Old 10-12-2009, 06:48 PM   #12
wrx wagone
Member#: 97301
2005 WRX Wag-Tow Rig
125 FM - QRE Invader
Colin,
I think you will be well served by either. I run the 65mm on my STX car. I would really have to say that either intake will require a MAF rescale.
-JR
wrx wagone is offline   Reply With Quote
Old 10-12-2009, 06:50 PM   #13
pinkertonpunk
Member#: 62386
2008 Honda S2000
Chicane Silver
That's fine, I am sure Jorge knows more about that than I do. I am sure it will be taken care of when I bring it in for a tune.
Old 10-12-2009, 06:51 PM   #14
wrx wagone
Member#: 97301
IIRC, the APS turbo inlet requires modifications to the air system piping. Connections need to be run together into the turbo inlet. SCCA rules do not provide an allowance to modify this piping in order to get an approved modification to work.
A Samco turbo inlet is the only one I'm aware of that doesn't require modifications to the stock piping.
Old 10-12-2009, 06:57 PM   #15
pinkertonpunk
Member#: 62386
2008 Honda S2000
Chicane Silver
So the Perrin isn't legal either then? Good to know!
Old 10-12-2009, 07:57 PM   #16
wrx wagone
Member#: 97301
Nope.
Old 10-13-2009, 10:08 AM   #17
piknockout
Member#: 192173
2006 STU prepped STi
Sponsored by Agile Auto
That is good to know, I thought that only the APS turbo inlet was a no go...I almost bought a Perrin last year, but I guess I will be getting a Samco this offseason.
While we're on the top of intakes, I have a COBB short ram intake that came with the car, but didn't use it last year due to the fact I don't have the COBB air box and being stuck sucking in tons of hot air. But this year I plan to make my own air box and use the COBB. So the real question is, worth it to build the box and use the COBB, or sell it and just get an APS? Thanks (sorry for the minor threadjack ).
piknockout is offline   Reply With Quote
Old 10-13-2009, 10:16 AM   #18
boyracer_05
Member#: 126171
2005 Silver STi
I know that there is another company that makes a box for the cobb intake. Let me try and find it.
Old 10-13-2009, 10:22 AM   #19
piknockout
Member#: 192173
MODE Racing makes one for about $125 or so. But I have access to cheap aluminum and pretty machinery, so I might do it myself for cheaper. But then again, I don't mind helping out the great Billy Brooks...he actually talked to me at Nationals!
*swoon*
Old 10-13-2009, 10:29 AM   #20
boyracer_05
Member#: 126171
2005 Silver STi
Yep thats it or the AVO carbon fiber box. I heard a rumor that AVO made a fiberglass version of their box but can't find it.
APS COLD AIR INTAKE: 65mm VS 70mm Red Rexx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 21 09-20-2011 11:48 AM
CAI 65mm or 70mm and Accesport v1 or v2 nywilliezx Private 'Wanted' Classifieds 6 07-02-2009 11:11 AM
Need A Aps Cai 65mm Or 70mm jeremywrx15554 Private 'Wanted' Classifieds 5 07-11-2008 10:49 PM
WTB APS CAI 65mm or 70mm leonbmx NWIC Private Classifieds 4 08-10-2007 12:53 AM
WTB: (WA) APS CAI 65mm or 70mm leonbmx Private 'Wanted' Classifieds 3 08-10-2007 12:53 AM
