Old 10-12-2009, 02:46 PM   #1
Knight_Fall
Member#: 197408
2006 STI
Default Oil drain plug leaking
Hi all, (noob question) A friend recently gave me a Titek magnetic drain plug, which I changed out when I did an oil change 2 weeks ago. Now my Sti leaks oils, is it possible that I either put the oil plug gasket on facing the wrong way, or perhaps the Titek MDP is not good? I'll probably watch the oil for now, and put the stock plug back on. Just wanted to know why it was leaking. Thanks, KT
Knight_Fall is offline   Reply With Quote
Old 10-12-2009, 02:47 PM   #2
Jons_uurx
Member#: 189180
04 wrx jbp stg dos
03 Infiniti G35s
did you use the same crush washer?
Jons_uurx is offline   Reply With Quote
Old 10-12-2009, 02:50 PM   #3
xTourniquet
Member#: 177477
2006 WRX Limited
Make sure it's tight and use a new crush washer every time.
xTourniquet is offline   Reply With Quote
Old 10-12-2009, 02:53 PM   #4
Scooby-King
Member#: 180499
2007 SRT8-Cherokee
2008 Sierra Denali
every other time . . . .
Scooby-King is offline   Reply With Quote
Old 10-12-2009, 03:01 PM   #5
lotarg
Member#: 90940
I read that magnetic drain plugs are pointless for the engine oil.
lotarg is offline   Reply With Quote
Old 10-12-2009, 03:09 PM   #6
UFOpilot
Member#: 189525
2007 WRX Wagon
Invisible Plain
Flat side of crush-washer to the plug, rounded side to the pan.
I put a new one on every time, though there are people who say otherwise. Then again I change my gear oil every year, my oil at 3000 max (AMSoil 20-50), and I go over suspension components every month at the longest.
You will get all types of responses from all types of people who use their vehicles in all types of ways. I am a performance oriented fail-safe type. My car runs great, and I definitely push it to it's limits regularly.
UFOpilot is offline   Reply With Quote
Old 10-12-2009, 03:12 PM   #7
bpang1
Member#: 67225
2015 Audi S4
Red
I too put a new crush washer everytime...better safe than sorry and the thing is so cheap.
Then again I haven't changed crush washers in a year and a half because I have a Fumoto valve.
bpang1 is offline   Reply With Quote
Old 10-12-2009, 03:34 PM   #8
Torquey
Member#: 175334
2003 Impreza WRX
JDM v8 EJ207 WRB
.. do this $20 dollar investment next time and be done with headaches. But for now give the bolt an extra turn or two.
Torquey is offline   Reply With Quote
Old 10-12-2009, 06:02 PM   #9
CynicX
Member#: 48199
06 WRX
I never looked into Subaru's specs but in general crush washers work until they are crushed (aka once). I work on some very high end machinery and you never, ever, ever reuse a crush washer. Once it conforms to the surface imperfection once its done for. Esp when they are 10 cents each....
Does Subaru recommend reusing them?
CynicX is offline   Reply With Quote
Old 10-12-2009, 11:00 PM   #10
cardude007617
Member#: 216556
2016 WRX Limited
nooooo they dont
cardude007617 is offline   Reply With Quote
Old 10-13-2009, 12:33 AM   #11
chazly413
Member#: 151079
2005 2.5RS RBP
too many friction losses
If you over-torque a crush washer, it's going to leak. I used the same crush washer for three changes at sliiiightly higher torque specs each successive change, and I had no leak problems. But I now change them every other change.
chazly413 is offline   Reply With Quote
Old 10-13-2009, 03:24 PM   #12
Knight_Fall
Member#: 197408
2006 STI
Thanks for all the help.
Yes, I changed the crush washer with one I got from the dealership. I might have put the crush washer on facing the wrong way. I will know when I change the oil in a bit.
Hmmm.. Over torque-ing the bolt can make it leak?
I did give it another 3/4 turn and still leaks. Seemed pretty snug and also I do not want to over torque it too much.
Now, I am just worried I may have cross threaded the oil pan.
As I mentioned I will most likely just go back to the OEM drain plug, hope it doesn't leak then.
Old 10-13-2009, 04:07 PM   #13
xTourniquet
Member#: 177477
2006 WRX Limited
I think you would know if you cross threaded it, it would NOT go in easily...
Old 10-13-2009, 04:17 PM   #14
danny77
Member#: 226627
i always have that problem
danny77 is offline   Reply With Quote
Old 10-13-2009, 04:19 PM   #15
UFOpilot
Member#: 189525
2007 WRX Wagon
Invisible Plain
Torque spec is 44 Nm IIRC.
Old 10-13-2009, 04:24 PM   #16
2.5ReallySexy
Member#: 167943
The crush washer can go either way.
2.5ReallySexy is offline   Reply With Quote
Old 10-13-2009, 04:31 PM   #17
UFOpilot
Member#: 189525
2007 WRX Wagon
Invisible Plain
Flat side to flat surface, crush side to irregular service is the "right" way. Only one side will "crush" to fit irregular surfaces, why would you want that side against the bolt head ? Though yes, you can do many things a number of ways.
Old 10-14-2009, 09:48 PM   #18
piecemealBHC
Member#: 106248
2015 WRX CWP
2000 RS 2.5
I think I got about 8 changes out of one crush washer before it began to leak... maybe it was a fluke, but as long as you don't torque the hell out of the thing and make sure to clean it, the plug and the surface of the pan you should easily be able to get away with every other change if not more.
And yes, they are cheap, but it's not always convenient where I live to make a trip to the dealer to get more (I finally just bought a ****load of them to keep in the toolbox).
Next up... buying a supply of push clips and replacement bolts for the undertray.
piecemealBHC is offline   Reply With Quote
Old 10-14-2009, 11:00 PM   #19
p01ntb1ank
Member#: 134299
wait so.... which way does the crush washer go? someone said flat to bolt and someone said other wise
p01ntb1ank is offline   Reply With Quote
Old 10-15-2009, 07:20 AM   #20
ScoobyGuy101
Member#: 226215
2005 Subaru WRX
I know when I worked at Toyota we had people come in with aftermarket drain plugs that were just a haaaaaiir smaller than the original and they would leak, or break in half when you take them out, or would just strip to a perfect circle the first time you change your oil. Does that happen with subarus? Not sure. Just thought I would mention that.
And yea, change the washer everytime for me.
ScoobyGuy101 is offline   Reply With Quote
Old 10-15-2009, 01:19 PM   #21
UFOpilot
Member#: 189525
2007 WRX Wagon
Invisible Plain
I think thus far I am the only person to reference the orientation of the crush washer. The rounded "crush" side is meant to form itself to slight irregularities on the pan, while the flat side is meant to seat against the bolt head. No-one in this thread said otherwise, except for one person that said it doesn't matter which way you do it. Of course I believe they simply do not have enough experience to know what they are talking about.
Old 10-15-2009, 03:41 PM   #22
yo14jman
Member#: 138229
2006 STI
try using teflon tape...it worked for my oldsmobile back in the day lol.
yo14jman is offline   Reply With Quote
Old 10-15-2009, 03:58 PM   #23
Le Saboteur
Member#: 142244
2007 SWP STi
WFC #243
oh man
Le Saboteur is offline   Reply With Quote
Oil drain plug leaking jamosthemagician Warranty Issues & SOA Problems 9 03-06-2008 12:53 AM
Rear differential oil fill and drain bolts, same size as the oil drain plug? scooterforever Transmission (AT/MT) & Driveline 4 01-24-2005 06:06 PM
Where to get an Oil Drain plug for oil temp sensor ? (HKS CAMP) Extraze Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 3 08-27-2004 03:35 PM
Oil Drain plug fell off of my Nissan 200SX after dealer oil change plunk10 Mid Atlantic Impreza Club -- MAIC 8 08-05-2003 12:48 PM
DIY Oil Change: How do you remove oil drain plug? RSarte Newbies & FAQs 14 07-10-2001 12:11 AM
