Old 10-13-2009, 03:59 PM   #1
AVANTI R5
Member#: 73805
2016 Cayman GT4
black
Default Porsche 911 3.8 Turbo
What is it?
The new Porsche 911 Turbo. Unveiled in at last month’s Frankfurt motor show, the latest evolution of Zuffenhausen’s uber coupe/cabriolet has been extensively reworked in a two year program that Porsche’s head of passenger car development, August Achleitner, claims has made it an even better and more entertaining car to drive then ever before.
Given the adrenalin inducing appeal of the old 911 Turbo – a car we described as the best all weather supercar of all time not all that long ago, it is hard to believe such a thing is possible at all. Still, it would be very out of character for Porsche to unleash a new model that didn’t, in some little way at least, improve on the one it replaces.
Not that it’s reflected in the styling. Tweaks include new titanium-coloured louvers in the front side air ducts, LED daytime driving lamps residing in the place previously taken up by the fog lamps, revised exterior mirrors with a new double arm design, altered tail lamp graphics with LEDs as well as larger tail pipes poking out through the rear valance.
The old but mightily effective multi-point fuel injected 3.6-litre flat six-cylinder petrol engine with its twin variable vane turbochargers, relatively low 9.0:1 compression ratio and split deck design has been resigned to history.
It’s replaced by a more powerful direct-injected 3.8-litre version of Porsche’s classic flat six-cylinder running newly reworked twin variable vane turbochargers, higher 9.8:1 compression ratio and closed deck architecture which is claimed to boost rigidity. In doing so, peak power climbs from 473bhp to 493bhp at 6000rpm while torque has increased from an already hugely potent 630Nm in the outgoing engine to 650Nm between 1950 and 5000rpm.
Along with the new engine, there’s also a new optional gearbox in the form of a new seven-speed PDK gearbox. Fitted to the car we drove, it replaces the Mercedes-Benz produced five speed automatic offered on the old 911 Turbo.
What’s it like?
Mind blowing. The bare performance figures - 0-to-62mph in 3.4sec, 0-to-100mph in 7.0sec and 193mph top speed - hint at something very special and better its predecessor in each case. But the way the 911 Turbo goes about its business almost defies conventional road car logic.
You’d likely find a more powerful and faster car over a wide and smooth surfaced race track. But on normal roads – the sort you and I encounter every day with varying surfaces, odd cambers and all variety of hidden surprises like those served up at the car’s launch in Portugal this week, I seriously doubt any rival – not even a Bugatti Veyron, Ferrari Enzo or Porsche Carrera GT - would come close to matching it for sheer pace or outright dynamic prowess for any length of time.
See the hi-res pictures of the new 911 Turbo
It is the engine, more than anything else, that stands out. Hard as it may be to image given the sort of power it develops, there is no discernable turbo lag at all. Owing to the increased capacity and higher compression ratio, Porsche has actually decided to dial back boost pressure a touch, from a previous 1.0 to a nominal 0.8 bar, in the interests of added driveability. The result is even keener throttle response and a level of flexibility you really have to experience to believe.
The weight has been trimmed by 25kg in models with the new dual clutch gearbox over those running the old automatic to an impressive 1595kg, giving it a power-to-weight ratio of 309bhp/tonne.
When the road is straight, you’re treated to typically solid and high speed stability, albeit with some characteristic bobbing at the front end as lift forces begin the build. More remarkable that this, however, is the speed at which the dual clutch gearbox manages to pick off the gears without any interruption in acceleration despite having to cope with all that torque.
The steering wheel mounted paddles are nicely weighted, positive in action and enhanced by a Sport Plus function, which lights up on the left-hand spoke of the steering wheel, to signal a remapping of the throttle for an even more aggressive throttle response. As well as making it faster, another one of Porsche’s primary aims with the new 911 Turbo was to make it more entertaining.
It’s certainly gained in terms of overall agility, feeling less reliant upon the four wheel drive system for grip and more accommodating to sudden changes in direction. With the optional torque vectoring automatically braking the inside rear wheel, there’s a new found willingness upon turn in as well as a noticeable increase in the amount of speed you can confidently carry through corners. On normal roads the handling is virtually vice-free, with so much grip you'll never feel the need to turn off the ESP.
However, as devastatingly good as the 911 Turbo is, it can sometimes come across as lacking a certain something. I’m opposed to calling it clinical , but in certain respects that’s exactly what it is, if only because of the way it is able to conquer every thing you throw at it with such crushing authority.
While superbly damped and wonderfully direct, the speed sensitive variable rate steering is also a little short on ultimate feel. Compared to lesser, rear wheel drive versions of the 911, there’s clearly less being communicated from the front end.
Should I buy one?
There are more spectacular looking, faster and better sounding supercars for the money. But as an everyday proposition the new 911 Turbo is just about beyond comparison.
Greg Kable
First drive data
How much?
  • Price as tested TBA
How fast?
  • 0-62 mph 3.4 sec
  • Max speed 194 mph
How big?
  • Weight no data
How thirsty?
  • Combined 24.1 mpg
  • CO2 emissions no data
Engine
  • Layout no data
  • Max power 493 bhp
  • Max torque no data
http://www.autocar.co.uk/CarReviews/...-Turbo/243959/
Old 10-13-2009, 04:02 PM   #2
AVANTI R5
Member#: 73805
2016 Cayman GT4
black
Default 2010 Porsche 911 Turbo: The daily driver of supercars
As four-wheeled evolution goes, the Porsche 911 Turbo's first three and a half decades have been spectacular.
First introduced at the back end of the oil crisis in 1974, Zuffenhausen's iconic coupe began life with a 256-hp turbocharged 3.0-liter version of Porsche's classic, horizontally opposed six-cylinder engine and rear-wheel drive.
By all accounts, the first 911 Turbo was monstrously fast in a straight line but a wild ride otherwise, and not easy to tame in the wet. Despite its faults, the fatalistic attraction of that first 911 Turbo stuck. Over 35 years and six model generations, it has grown in power, performance and standing.
The last one, the 997 launched in North America in 2006, served up 473 hp from its twin-turbocharged 3.6-liter flat-six and sent it to the corners through a sophisticated four-wheel-drive system. It was, as AutoWeek noted then, the most rounded 911 Turbo to date. It sold in bigger numbers than any of its predecessors, thanks in part to Porsche's strategy to offer it in cabriolet guise and with an automatic gearbox.
That brings us to this car, the new 911 Turbo. Unveiled at the Frankfurt motor show in September, it is another evolution of the car that preceded it. But it has been extensively reworked in a two-year program that August Achleitner, Porsche's head of passenger-car development, claims made it more entertaining to drive. Given the adrenaline-inducing appeal of its predecessor, it is hard to believe that such a thing is possible. Still, it would be out of character for Porsche to unleash a new model that didn't improve on the one it replaces.
You've seen this before
The message here is familiar--bring together all the elements that have contributed to the 911 Turbo's appeal through the years.
Not that it's reflected in the styling. There's little in the appearance to signal the extent of the modifications made under the 911 Turbo's steel body shell. A close inspection reveals some subtle visual changes, including titanium-colored slats in the front air ducts, light-emitting diode daytime driving lamps in the space previously used by the fog lamps, exterior mirrors with a new double-arm design, altered taillamp graphics with LEDs, and larger tailpipes poking out through the rear valance.
This 911 Turbo rolls on new 19-inch forged alloys--some 8.5 inches in width up front and 11 inches at the rear. The two-tone wheels come shod standard with 235/35 ZR19 (front) and 305/30 ZR19 (rear) Bridgestone Potenza RE050A tires. Alternately, customers can also opt for the RS Spyder-style wheels of the same size used on the 911 GT3, complete with center locking hubs.
A new heart
But there is a great deal to the 911 Turbo that has changed, starting with the engine. The 3.6-liter flat-six is replaced by a direct-injection 3.8-liter version, running reworked twin variable-vane turbochargers, a higher 9.8:1 compression ratio and closed deck architecture, which is claimed to boost rigidity.
Peak power climbs from 473 hp to 493 hp at 6,000 rpm, while torque has increased from 464 lb-ft in the outgoing engine to 479 lb-ft between 1,950 rpm and 5,000 rpm.
Not enough pull? Order the optional Sports Chrono package and, along with goodies such as electromagnetic engine mounts, you get an overboost feature which momentarily elevates torque by an additional 37 lb-ft to 516 lb-ft--or more than double that of the original 911 Turbo from 1974.
Power is still channeled through a Getrag-built six-speed manual gearbox to a four-wheel-drive system, or Traction Management system in Porsche-speak. It relies on a Haldex style multiplate clutch to apportion drive to the axle with the most grip. In extreme conditions, it is able to transfer up to 100 percent of drive to either axle.
For the new 911 Turbo, however, there are changes to the nominal torque split to provide what Achleitner describes as a "more tail-happy character." Porsche has changed the software to allow the multiplate clutch to send a greater percentage of drive to the rear under a wider range of conditions.
The joy of PDK
There also is a new optional gearbox, the seven-speed PDK dual-clutch unit. Fitted to the car we drove, it replaces the Mercedes Benz-produced five-speed automatic on the old 911 Turbo. The gearbox, which comes with shift paddles mounted to the steering wheel, is based on the unit recently made available in lesser 911 models but gets beefed up clutches. The dual-clutch gearbox comes with a mechanical rear differential which, similar to the old 911 Turbo, achieves 22 percent lockup under power and 27 percent in overrun.
Also available as optional equipment on the new car is an electronically controlled torque-vectoring system--the first time such a system has been used by Porsche. It alters the 911 Turbo's yaw properties by automatically braking the inside rear wheel upon turn in, and not just when it's needed but at every corner.
How does all this come together? Imagine yourself behind the new three-spoke steering wheel of the new 911 Turbo at the end of a long and flat straight. You call up the Sport setting to active the dual-clutch gearbox's launch control.
With 5,000 rpm wound on the engine, you sidestep the brake and are launched with incredible intensity--the sort that sends your head careening back into the headrest and your stomach wishing it was somewhere else.
There's no hint of delay, just immediate traction as the four-wheel-drive system doles out the power to each corner. A giant wave of acceleration propels you up the road. There's no wild slithering or screeching from the huge tires out back, merely rapid forward progress. At this point, you need to focus hard just to stay on top of it all.
The way the 911 Turbo goes about its business almost defies conventional road-car logic. Along with an official 0-to-62-mph claim of 3.4 seconds for the dual-clutch model, Achleitner says the car also is capable or running from 0 to 100 mph in just 7.0 seconds, 0 to 124 mph in 11.8 seconds and--get this--0 to 186 mph in 38.8 seconds.
Don't forget, Porsche is notoriously conservative when quoting performance. Even the claimed 193 mph top speed is apparently 5 mph down on what the car is really capable of achieving.
Supercar for every day
Still, the way the new Porsche manages to devour long stretches of blacktop in one intense lunge is only part of the thrill. It can also carry massive speeds into corners with unwavering composure and can tame awful road surfaces without becoming unduly harsh. If there is such thing as an ultimate performance car for the everyday driver, this surely has to be it.
It is the engine, more than anything else, which stands out. There is no discernible turbo lag. Owing to the engine's increased capacity and higher compression ratio, Porsche has dialed back boost pressure a touch, from the previous 14.5 psi to 11.6 psi, in the interests of added drivability.
The result is keen throttle response and a level of flexibility you have to experience to believe. You can plant your right foot at 1,500 rpm in any gear and the 911 Turbo will respond with a degree of vigor. It's helped, of course, by the relatively low weight, which is trimmed by 55 pounds in models with the dual-clutch gearbox over those running the old automatic to 3,516 pounds.
Even so, it's not until you have 2,000 rpm on the rev counter that you experience the sledgehammer qualities to which those acceleration claims allude. It is here where the big levels of shove begin. By the time you've breached the 4,000-rpm mark, it starts to feel monstrously fast. The delivery is acutely linear and remains that way all the way until you've dialed in well above 6,000 rpm. There is no crescendo up near the redline, just one urgent and omnipotent surge of revs accompanied by a flat and rather nondescript blare of exhaust.
When the road is straight, you're treated to solid high-speed stability, albeit with some bobbing at the front end as lift forces begin the build. More remarkable, however, is the speed at which the dual-clutch gearbox picks off the gears without any interruption in acceleration, despite all that torque.
The steering-wheel-mounted paddles are nicely weighted, positive in action and enhanced by a Sport Plus function, which lights up on the left-hand spoke of the steering wheel to signal a remapping of the throttle for an even more aggressive throttle response and more rapid gear shifts when you choose. At the same time, a change in the engine mapping conjures up an additional 2.9 psi of boost, giving you access to that solid 516 lb-ft of torque.
More delicacy to the handling
Another of Porsche's primary aims was to make the new 911 Turbo more entertaining.
"We were confident it had sufficient acceleration but wanted some additional delicacy to the handling," explains Achleitner.
The handling certainly has gained in terms of overall agility, feeling less reliant upon the four-wheel-drive system for grip and more accommodating to sudden changes in direction. With the optional torque vectoring automatically braking the inside rear wheel, there's a newfound willingness upon turn in, as well as a noticeable increase in the amount of speed you can carry through corners. On normal roads, the handling is virtually vice-free, with so much grip and such high limits of lateral acceleration through corners, it is rare to see the stability management spring into action.
It's only on a racetrack where you can confidently begin to explore the 911 Turbo's dynamic ability. When you do rush up to a bend with excess speed--something that's all too easy--there's less of a tendency toward early oversteer and a more neutral feel as you tip it in. While there's some slight movement of the body when you're really leaning on it, it is progressive and rarely builds to a level where you're prompted to back off. More often than not, you're reveling in the traction afforded by the four-wheel-drive system and the ability of the locking differential and torque vectoring to provide easily controllable drifts at the exit. Another highlight is the sheer brilliance of the brakes.
How good is the handling? According to Achleitner, the new 911 Turbo will lap the Nürburgring in 7 minutes, 39 seconds on standard Bridgestone Potenza tires--some 10 seconds less than the time quoted for its predecessor.
Still, there is a disclaimer in all this: "We don't want to get ourselves into a race for Nürburgring lap-time supremacy," Achleitner says. "The times we quote are not really representative because they are set on different days and in differing weather conditions."
Is it too good?
Yet, as good as the 911 Turbo is, it can sometimes come across as lacking something. I'm opposed to calling it clinical, but in certain respects, that's what it is, because of its way it is able to conquer everything you throw at it with such authority. With a pair of turbochargers damping the aural effects of the new engine, it never sounds quite as inspiring as some rivals.
There are more spectacular-looking, faster and better-sounding supercars for the money. But as an everyday proposition, the new 911 Turbo is just about beyond comparison. It achieves things that many perceived rivals ultimately fail to deliver on everyday roads, purely because it is so adaptable to such a wide range of conditions. It's a car you hop into and feel confident right from the outset, despite its huge capabilities.
If you have the means and don't want to die wondering, it's a must. Whether you'll manage to hold on to your driver's license for long, though, is doubtful
http://www.autoweek.com/article/2009...IEWS/910139990
Old 10-13-2009, 04:08 PM   #3
Spenk
Member#: 7164
2000 Miata LS
Evo Orange Mica (1/644)
That front clip is seriously ugly.
Spenk is offline   Reply With Quote
Old 10-13-2009, 04:08 PM   #4
VerySlowRS
Member#: 171496
93 Civic VX 50+MPG
Finally they adopted the proper paddle shifter.
VerySlowRS is offline   Reply With Quote
Old 10-13-2009, 04:10 PM   #5
Spenk
Member#: 7164
2000 Miata LS
Almost.
The paddles should be column-mounted, not on the wheel.
Old 10-13-2009, 04:13 PM   #6
jigga
Member#: 9960
2002 Impreza WRX
WRBlue Perl
It is interesting that the 911TT is now also being labeled as being "clinical" just like the GTR..
Should be interesting to see how the competition responds
jigga is offline   Reply With Quote
Old 10-13-2009, 05:14 PM   #7
William WRX
Member#: 291
2013 Scion FR-S
Asphalt
Engine Layout, No data???
WTF!?!?!?!?!
Twin Turbo Flat Six, is a 911 Turbo....
William WRX is offline   Reply With Quote
Old 10-13-2009, 05:45 PM   #8
steve
Member#: 4718
Sold my Subaru, and
now I'm so OT
Are you kidding me?
How does one shift while turning?
Simply wait until you're going straight again?
nice car.
I want one.
steve is offline   Reply With Quote
Old 10-13-2009, 06:49 PM   #9
left footed whooten
Member#: 44652
06 WRX
15 Forester
Well, yeah actually, the Peugeot and the Skoda had a ring shifter, but the Subys, Fords, etc have a large paddle that's mounted on the column. They make the paddle larger for added range, but they have to have their hand near it whether that hand is engaged in turning or not.
For a road car, given that a 911 will attract a more active driver and is an exception, its probably a bad idea to sell Joe Blow a paddle shifted car that requires WRC skill.
left footed whooten is offline   Reply With Quote
Old 10-13-2009, 06:53 PM   #10
doubleurx
Member#: 64024
03 996 TT, 964 C4
salt and pepper
Paddles are mounted absolutely where they should be. Mounting on the column has always been a bad idea.
doubleurx is offline   Reply With Quote
Old 10-13-2009, 07:59 PM   #11
Masterauto
Member#: 198376
STI E30 M3
Nissan GT-R 15
Looks like they aimed at beating the Nissan GT-R...competition is good and the consumer wins. I like the color but would still say the GT-R wins at half the cost.
Perhaps Nissan should offer a "dial 911 Blue" color to piss them off. Lord knows they sure have German automakers attention especially Porsche.
Masterauto is offline   Reply With Quote
Old 10-13-2009, 08:00 PM   #12
murrdogg24
Member#: 50586
04 WRX
Flappy bird edition
Seriouly I was like huh? But yeah man I wish I win the lottery.
Originally Posted by hypa View Post
Are you kidding me?
nice car.
I want one.
murrdogg24 is offline   Reply With Quote
Old 10-13-2009, 09:03 PM   #13
delongedoug
Member#: 124113
and beyond!
Nice color. I'm not a big fan of the other aesthetic changes, though.
delongedoug is offline   Reply With Quote
Old 10-13-2009, 09:26 PM   #14
virpacalis
Member#: 19214
'07 STI
in the slow lane
If only I could afford one. Its N-ring time should be interesting.
virpacalis is offline   Reply With Quote
Old 10-13-2009, 09:42 PM   #15
eachit
Member#: 216124
That's what I can't wait to see.
I wonder how much influence (if any) the GTR had on the development of this car.
That blue and the GT3RS Green are such great car colors.
White rims on that.... mmmmm.
eachit is offline   Reply With Quote
Old 10-13-2009, 10:56 PM   #16
Nico Flax
Member#: 109531
2006 STI
2008 CBR1000
Are you kidding me?
How do you do a u turn? Double jointed in the elbows? Do you arms wrap around each other? Or do you merely never turn the steering wheel more then 90 degrees?
I don't think there is a right answer in a road car, and seeing you drive it as such. I prefer column myself, but I could see why someone would like steering wheel mounted.
Nico Flax is offline   Reply With Quote
Old 10-13-2009, 11:04 PM   #17
g-pimpin
Member#: 95510
02 WRX
15 STI
^ True, but the steering rack on these cars are quite different from your everyday R32/Acura TL. Probably two turns lock to lock.
g-pimpin is offline   Reply With Quote
Old 10-13-2009, 11:17 PM   #18
E. Nick
Member#: 8489
1978 Plymouth Volare
Maroon / White Vinyl
Bye bye GT1 block. AE91 is apparently not as stout and costs 30% less to produce. 997.1's are the ones to have if you want to mod IMHO, but I do love the 997.2 as a cab pdk with a re-flash for the ultimate DD.
E. Nick is offline   Reply With Quote
Old 10-14-2009, 01:06 AM   #19
Skunkers
Member#: 115480
Are you kidding me?
That's better than trying to shift with one of the wheel-mounted paddles when the wheel is upside down.
To each his own, I guess.
Skunkers is offline   Reply With Quote
Old 10-14-2009, 07:45 AM   #20
Masterauto
Member#: 198376
STI E30 M3
Nissan GT-R 15
I think BMW M3 does it nicely and lets you still use the shift lever if you like.
I have the column mounted paddles and thought wheel mounted would be nice but think you may be right.
Old 10-14-2009, 08:07 AM   #21
Jaylyons1
Member#: 113884
2013 BRZ
24.1 combined MPG?!?!? Holy hell! Thats enough to get me interested!
Jaylyons1 is offline   Reply With Quote
Old 10-14-2009, 10:05 AM   #22
mhoward1
Member#: 9481
1832 Steam Buggy
Wood
That is a nice color
mhoward1 is offline   Reply With Quote
Old 10-14-2009, 10:17 AM   #23
HaTReD
Member#: 25256
what a rip off. porsche obviously took a GT-R, which has been breaking new ground for decades, deconstructed it and built something designed specifically to beat it.
wait a minute...
HaTReD is offline   Reply With Quote
Old 10-14-2009, 10:23 AM   #24
Spenk
Member#: 7164
2000 Miata LS
Are you kidding me?
Not a problem if you have the skill to shuffle the wheel from the bottom.
Old 10-14-2009, 10:31 AM   #25
teh POD
Member#: 90195
That's Imperial MPG. That translates to about 20 MPG US, which is still pretty damn good for a near 500 HP, AWD sports car.
teh POD is offline   Reply With Quote
TX: 2007 Porsche 911 997 Twin Turbo r6chiro Private Vehicle 'For Sale' Classifieds 70 05-08-2010 02:09 PM
Wimmer RS Presents Porsche 911 GT2 Bi-Turbo with 680HP AVANTI R5 Non-Subaru News & Rumors 5 05-17-2009 12:15 AM
Porsche 911 with 3.3L SVX Motor? Krmnnghia01 General Community 10 10-08-2008 11:02 PM
New Porsche 911 GT3: The world’s fastest engine in the 3.6-liter class NYCshopper Non-Subaru News & Rumors 41 02-28-2006 05:29 AM
Porsche 911 GT Turbo sighting........You're going to enjoy this. obyone Mid West Subaru Owners Club Forum -- MWSOC 21 11-04-2002 08:28 PM
