Old 10-13-2009, 09:02 PM   #1
Meat Supply
Member#: 137902
---- among the
lost we all shall survive
Default stupid ****In saturn. oil filter removal emergency
so i came home. was gonna change the oil in the old ladie's car, play ps2 black for a bit, then watch TV. well those plans have gone completely down the tubes.
i can't get the oil filter off and now i've effed it up pretty bad. tried a filter wrench, then resorted to the old screwdriver through the side trick. well, that just mutilated the metal prettty bad. i've run out of ideas and would appreciate some tricks or tips some of you might have.
ibyoregay
ibotherstuff
Meat Supply is offline   Reply With Quote
Old 10-13-2009, 09:03 PM   #2
CincinnatiKid
Member#: 207672
08 WRX, S50 E30
rot
just drive it, it doesn't need oil
CincinnatiKid is offline   Reply With Quote
Old 10-13-2009, 09:05 PM   #3
pnilly
Member#: 26088
out of your
system
kill yourself
pnilly is offline   Reply With Quote
Old 10-13-2009, 09:05 PM   #4
hkerekes
Member#: 66310
2015 korean muscle
ibyoregay
ibotherstuff
Run a bigger screw driver or whatever thru it. Grab a big ass set of channel locks. Use whatever, its going in the garbage anyway. Vise grips may help as well.
A chisel/screwdriver can be hammered at the edge to help spin it off. Just dont **** up the gasket surface.
hkerekes is offline   Reply With Quote
Old 10-13-2009, 09:05 PM   #5
stiluv2xl8
Member#: 167027
02 WRX Sedan
sounds like you may need a chain filter wrench.
stiluv2xl8 is offline   Reply With Quote
Old 10-13-2009, 09:07 PM   #6
Slappie
Member#: 16500
06 sti-EWG-Spearco
Stage 2
Pics of yer carnage or no help!
Slappie is offline   Reply With Quote
Old 10-13-2009, 09:08 PM   #7
plode
Member#: 116910
Burn it off with a torch.
Disclaimer: I bear no responsibility if your car burns to the ground.
plode is offline   Reply With Quote
Old 10-13-2009, 09:08 PM   #8
enkd
Member#: 15376
2002 WRX Wagon
2016 Forester
righty tighty lefty loosey.
enkd is offline   Reply With Quote
Old 10-13-2009, 09:08 PM   #9
rogue
Teddard Snark
Super Moderator
Member#: 7977
100% Abuse
Hairdryer.
I've been there.
Hairdryer. Get that ****er heated up. Then use the screwdriver.
rogue is offline   Reply With Quote
Old 10-13-2009, 09:09 PM   #10
kgb4187
Member#: 35824
I always beat the side of the filter in to get a better grip on it. Use a hammer and dent it.
kgb4187 is offline   Reply With Quote
Old 10-13-2009, 09:09 PM   #11
outbacksport
Member#: 23114
2009 Cadillac CTS-V
Thunder Gray Chromaflair
haha are you sure you are turning it the right way? those things aren't on there that hard.
outbacksport is offline   Reply With Quote
Old 10-13-2009, 09:09 PM   #12
chu my pu
Member#: 132127
2009 BMW
X5
or rag (or 2) over the mangled metal and use your hand
chu my pu is offline   Reply With Quote
Old 10-13-2009, 09:10 PM   #13
chapstien
Member#: 68284
1988 Corolla SR5
0-points
Crimp it from the side with channel locks (actually a brand name.) Did you warm it up first? Ya gotta cook it.
leftie loosie rightie tightie. It's lady's
chapstien is online now   Reply With Quote
Old 10-13-2009, 09:11 PM   #14
chapstien
Member#: 68284
1988 Corolla SR5
0-points
2 minutes?
Old 10-13-2009, 09:13 PM   #15
Meat Supply
Member#: 137902
---- among the
yeah, i might pick one up tomorrow after work.
^^^ yeah i've tried a bigger screwdriver but there's not a ton of room to work with and the angles are bad. i can't do the chisel on the base thing because i can't get to it. the axle is right under the filter, less than a thumb width, as i couldn't even get a grip on it.
so the axle is right under the filter, blocking me from the base of the filter. access from above is a joke as well. eff my life
Old 10-13-2009, 09:14 PM   #16
rogue
Teddard Snark
Super Moderator
Member#: 7977
100% Abuse
And the hairdryer? Basically the rubber washer on the thing is glued down and holding the filter in place. You heat that up, it lets go.
Old 10-13-2009, 09:16 PM   #17
Meat Supply
Member#: 137902
---- among the
haha thnaks for the help guys. i drove it for a minute to move it in the garage, put it on ramps, etc but it wasn't *hot* persay. yeah and i am turning it the right way i put it on on the last change but don't think i got it that tight. well, apparently i did.
Old 10-13-2009, 09:17 PM   #18
Indocti Discant
Member#: 138000
Buy Nate's coffee
west coast roasting
and this is precisely why you pay someone you trust $15 to do this for you.
Indocti Discant is offline   Reply With Quote
Old 10-13-2009, 09:20 PM   #19
Meat Supply
Member#: 137902
---- among the
^i guess so. i've been changing my own oil for years and never had this problem. the only time i've ever needed a filter wrench was the last time i worked on this car.
Old 10-13-2009, 09:21 PM   #20
rogue
Teddard Snark
Super Moderator
Member#: 7977
100% Abuse
No.
This is why you:
1) Put a little oil on the rubber washer before tightening the new filter
2) Use the hairdryer if the engine isn't warmed up
3) Man up
Old 10-13-2009, 09:21 PM   #21
john_matrix
Member#: 54787
2005 Saab 9-2x
Satin Gray Metallic
Hairdryer? Have you tried that yet?
john_matrix is offline   Reply With Quote
Old 10-13-2009, 09:21 PM   #22
rogue
Teddard Snark
Super Moderator
Member#: 7977
100% Abuse
Yeah well, now I'm gonna put you in TO because I've said three ****ing times to use a hairdryer and you're not even acknowledging me.
Old 10-13-2009, 09:23 PM   #23
chapstien
Member#: 68284
1988 Corolla SR5
0-points
He needs heat gun. He's going to get it like 105 degrees F with a hair dryer after 20 minutes. He could start it, for a great video.
Old 10-13-2009, 09:23 PM   #24
gramicci101
Member#: 64763
The cake is a lie.
Use a what?
gramicci101 is offline   Reply With Quote
Old 10-13-2009, 09:24 PM   #25
Meat Supply
Member#: 137902
---- among the
okay, okay i'll get to it after i eat something here!!! best idea i've heard today actually, thanks!
Chicago, oil filter remover Guerilla Mid West Subaru Owners Club Forum -- MWSOC 21 10-12-2009 01:49 PM
Oil filter removal on 08 impreza. terry9842 Service & Maintenance 9 07-07-2008 12:37 PM
Avondale- I need OIl filter remover wrench or socket!!!! Jim.mEh South West Impreza Club Forum -- SWIC 17 08-18-2007 11:05 PM
oil filter removal horrow Rickyh Service & Maintenance 3 05-14-2006 12:46 PM
Oil Filter Removal slickvic Service & Maintenance 8 01-08-2003 06:57 AM
