Go Back   NASIOC > NASIOC Classifieds > Private 'For Sale' Classifieds > Motorsports Specific Items
Old 10-14-2009, 01:14 AM   #1
sunnynw
Member#: 18979
05 SWP Legacy GT
Default 1995 G5 / Open Class Subaru Impreza
The car comes with a current valid log book. This car is currently a Front Wheel Drive G5 Impreza but can be easily converted to All Wheel Drive (Open Class) if preferred by the buyer.
The roll cage far exceeds what is required by the current rules used in North American stage rally.
The high safety standards continue inside of the car utilizing 4 Safety Solutions Heavy Duty Rally Driver Nets. These nets are made from Kevlar webbing and they literally wrap the 2 OMP HTE FIA Homologated head wing seats creating a full containment of the upper body in a heavy side impact while at the same time reinforcing the flimsy fiberglass OMP HTE Seats.
Additional Dow Impaxx padding was added to the nets for improved intrusion protection around the occupant head area.
Blue FIA Homologated Roll Cage Padding covers the high risk head impact protection areas. The door bars feature the Dual Density Roll Cage Padding System with SFI 45.1 Label, great for not bumping your elbows on the door bars.
Continuing with the interior safety are the harnesses. These units are SFI Homologated 5 point units made by Gforce and are legal until 2010. Special attention has been paid to the harness webbing routing to ensure optimal geometry for safety. Shoulder belts are mounted to harness bar just behind the seats that keeps the shoulder webbing as short as possible. Special mounting points were added to the roll cage for the lap belts for the same reason. The shorter webbing is, the safer the occupants are.
There are two Amerex 2.5 lb Dry Chemical Fire Extinguishers with current inspection tags. These two units are bolted to the car using four bolts, nuts and lock washers.
The driver’s seat gives the driver a tidy place to work. Sparco Steering Wheel and Foot Pedals along with a custom hydraulic e-brake and proportioning valve create a rally cocoon of pleasure. A custom aluminum dash replaced the stock dash. The co-Driver area has a Hella Map Light.
Mechanical Details;
2.2L Turbo engine custom built in 2008
5MT from a ’99 2.5RS with welded front diff and modified to be FWD only
2 pot front brakes from a ’99 RS
1 pot rear brakes from a ’02 WRX
Custom hydraulic e-brake with proportioning valve
Rear suspension cross member and associated li nks are from AWD car
Aluminum Sump Guard
Extensive underbody plastic
Light Pod with 4 PIAA XT PRO Lamps, 2 spot, 2 driving with rings
Aluminum Hood with STI Version 5 front end conversion
* New OMP THE seats and side mount brackets added 1/09. (2 rallys)
$12,999 with Hotbits 1 way adjustable rally struts (brand new rebuild).
$13,999 with Tein HG 2 way adjustable rally struts (5 rallys old)
STI GN Top Hats included with all strut options
A spares package is also available at an additional cost.
sunnynw is offline   Reply With Quote
Old 10-15-2009, 12:42 AM   #2
biggreen96
Member#: 12535
vf39 93 Legacy Wagon
92 Legacy Rally EG33'd
Sounds like a nice place to get some work done! GL with the sale!
biggreen96 is offline   Reply With Quote
1995 G5 / Open Class Subaru Impreza Rally Car sunnynw NWIC Private Classifieds 10 01-07-2010 01:12 AM
FS: Open Class GC Impreza Rally Car roofis Private Vehicle 'For Sale' Classifieds 21 10-22-2009 09:48 AM
Open Class Subaru Rally car - SoCal Porsche914boxer4 Motorsports Specific Items 1 06-29-2009 05:55 PM
Open Class Subaru WRX Rally Car Porsche914boxer4 SCIC Private Classifieds 0 06-14-2009 04:04 PM
SD Rally Prepped Impreza - The Safe Drives 1995 G5 Open Class Impreza Safe Drives NWIC Vendor Classifieds 4 07-24-2007 06:44 PM
Message Board Statistics All times are GMT -4. The time now is 08:08 PM.
