#1 | |
Member#: 73805
Performance, price, and value - there's still a lot of gray area around GM's electric car
![]() Quote:
#2 |
Member#: 92858
the Volt will never be built or sold to public.
Volt is DEAD, Fail, etc. next. |
#3 |
Member#: 83633
RMIC
Vehicle:2012 bright green box |
I had already forgotten about the Volt.
By the time it hits showrooms it'll be years out of date. |
#4 |
Member#: 117504
Vehicle:1999 Legacy Lmtd 5MT Red |
I'm thinking that a 1.4L spinning at optimal RPMs will do well.
The initial Volt was supposed to AWD. Have we heard anything about the powertrain. Im just assuming that since I havent, it's FWD. |
#5 | |
Member#: 95600
Vehicle:2003 WRX wagon Silver |
Once again a journalist exposes their ignorance. Once again people give them attention for it. Fact checking is apparently too old school for them now days. Instead a bit of controversy gets them revenue so just write down some lies and hope that it goes well. |
#6 |
Member#: 120152
Vehicle:2006 06 WRX, 86 FMOD Blue, White/Red |
Who uses air conditioning at 65 degrees?
#7 |
Member#: 9132
Vehicle:2005 WRX STi 2009 Fit, 1972 Dart |
I saw a volt in light camo going down 275 here in Livonia.
#8 | |
Member#: 4203
South East
Vehicle:2009 WRX 5spd hatch Platinum Silver Metallic |
#9 | |
Member#: 95600
It isn't even close to best case. I guarantee people will be able to get 80 miles on a charge if they are being all silly and trying to hypermile. |
#10 |
Member#: 20325
NESIC
Vehicle:08 Yamaha WR250R 07 Suzuki DL650 |
Apparently if you have a Master's degree in journalism it allows you to speculate instead of fact-check...
Granted, GM isn't saying much on certain questions right now, so speculation is all we can do. Still, apparently this guy just isn't getting the concept behind a serial hybrid with a big battery and is basing his assumptions around how the Prius behaves with a low battery (which isn't good, trust me). So shooting just one hole in this guy's suppositions... Let's say GM makes the gas engine come on at 30% charge level in the battery* (indications are that this is the case). We know it's a 16kWh battery, which means there is 4.8kWh left. We also know the electric motor is around 100kW and the generator puts out 53kW. Go full throttle as soon as the gas engine kicks on, you'll be drawing 53kW from the generator and 47kW from the battery. It'll take just over six minutes (4.8kWh/47kW = .102 hours) to pull the battery down to 0% charge, 4 minutes if they limit to 10% SOC to protect the battery... How many roads are there in the US where you can hold the accelerator flat for four minutes? (Well, Montana in the good old days, but lets be realistic...) As soon as you let off the throttle, the excess power from the 53kW the generator puts out will go back into the battery until the charge level gets to the engine shutoff point (40% SOC? Nobody outside GM knows yet). Remember that cruising 65 on flat ground in this small, aerodynamic car will probably only need about 10kW of power - and that means lots of excess generator capacity to keep the battery in it's happy place under realistic driving conditions, and no loss of power except on the longest grades at high speeds. I, for one, welcome our electrically-powered overlords, and as a media figure I can be useful in helping convince others to work in your electron mines... *All specifications from gm-volt.com |
#11 |
Member#: 70572
Vehicle:2005 Tacoma Blue |
#12 | |
Member#: 20325
NESIC
With electric motors, the efficiency curve is VERY different, and efficiencies range from the mid-70% up to the high 90% level... Pulse and glide should not be nearly as effective as in a gasser. |
#13 |
Member#: 14555
Vehicle:1995 L (Apex Tiger) Battle Ready Baja |
#14 |
Member#: 161746
I've stopped listening to the naysayers. The factory were the Volt will be built is being put together as we speak. From what I understand, they will build around 3000 units next year and over 60000 units the following year. Fail? Probably not. Too many people will buy these things and I'm one of them. If this was a Toyota there would be more praise going around. Also with Chevy confirming the Convertible Camaro will go on sale as a 2011 model and the Z28 all but confirmed, I'll have an all American stable. The camaro5 forum has been debating the lineage of the Z28 for a couple of months now and sound like they want different model Camaros to suite different engines. I'm all for the CTS-V motor, but I wouldn't mind having the LS7 either. Something makes me all tingley hanging that 427 on the side of my convertible Camaro.
#15 | |
Member#: 117504
Question is, will EV1 loyalists buy em? I am willing to be GM poed enough EV1 Leasees. that they would never buy another GM. |
#16 | |
Member#: 95600
#17 |
Member#: 873
TXIC
Vehicle:2013 Golf R 1971 240Z |
Why should my tax dollars go give incentives for this car. Its bad enough they already have 50 billion bucks from us. At 32500 it better have stellar quality and reliability. If they are going to produce 60000 of these a year, then they are going to be quite a few sitting in lots unless they are drastically reduced.
#18 | |
Member#: 95600
#19 |
Member#: 873
TXIC
Yeah, for the most part, I am just complaining. But on the other hand nobody has explained it in a way it MAKES SENSE. So I will continue to complain about it. The government owns GM. The government giving tax payer dollars as incentives to sell a car they own is a bit shady.
I have gone over this repeatedly. And yet, when I patiently explain it people still do not understand. Guess I have not explained it so it MAKES SENSE either. |
#20 |
Member#: 158043
RMIC
Vehicle:old Something new SWP |
I thought this was supposed to be here by now?
#21 |
Member#: 191994
40 miles?!!!!
![]() ![]() ![]() ![]() 400lbs just for battery weight! no wonder these companies are dying. |
#22 | |
Member#: 101457
NWIC
Vehicle:Czar of Sweet Dance Moves |
I'm no fan of GM, but let's be clear about the facts, shall we? |
#23 |
Member#: 95600
#24 | |
Member#: 95600
#25 | |
Member#: 117504
I predict that 40 miles in a conservative estimate. Think of the Prius originally had 60 MPG rating. Most people got around 50 and then complained to Toyota that they weren't getting what they should. GM knows this. Thus, it is smart to be conservative and then reap the benefits of happy customers who rave about exceeding the rating. I do it with our 400h. Word of mouth works. |
| Thread Tools | |
| Display Modes | |
| Lots of Gauge questions | tacomaprime | Interior & Exterior Modification | 3 | 11-09-2004 07:42 PM |
| Lots of setup questions... | 1331 | Motorsports | 3 | 02-02-2004 07:51 AM |
| Lots of swaybar questions | fukamoto | Brakes, Steering & Suspension | 4 | 07-30-2003 09:51 AM |
| Turboing a 1.8L and new to GC8- lots of technical questions | Blugin | Normally Aspirated with bolt-on Forced Induction Powertrain | 20 | 02-25-2003 10:31 AM |
| Lots of newbie questions | Don | Car Audio, Video & Security | 5 | 01-12-2002 01:55 PM |
