Old 12-22-2009, 01:37 AM   #301
Ralliart4
Member#: 135927
2002 Impreza WRX RA
wow this is pretty interesting stuff
Ralliart4 is offline   Reply With Quote
Old 12-22-2009, 10:22 AM   #302
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
a big factor to consider is that the IAT is not in the manifold as expected by this rom, but in the maf pipe.
since the IC doesn't have sufficient ambient airflow during LC or rotational idle the core temps skyrocket as soon as the turbo starts to wake up. trust me on this one..
you have two competing effects going on: the higher charge air temp is less dense, the ecu does not "know" this and thus afr swings rich. a "safe" thing.
however, the higher charge temps mean the mixture is that much closer to detonation. NOT a safe thing.
whether or not this results in a bad day is unknowable until it happens. just keep in mind that this is decidedly NOT the case with the IAT (really MAT) sensor in the manifold where it belongs (and this ecu code EXPECTS).
an old thread on relocating IAT/MAT: http://forums.nasioc.com/forums/show....php?t=1088149
Old 12-22-2009, 10:39 AM   #303
JSarv
Member#: 163445
l33t *******
[email protected]
My gm iat is in the cold side piping int he fender
JSarv is offline   Reply With Quote
Old 12-22-2009, 11:18 AM   #304
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
wise move.
Old 12-22-2009, 11:54 AM   #305
Maxwell Power
Member#: 190729
we're running blow through or GM temp sensors on all the cars running this map. it's the right way to do it.
Maxwell Power is offline   Reply With Quote
Old 12-22-2009, 01:33 PM   #306
JSarv
Member#: 163445
l33t *******
[email protected]
I'm curios to see how your gm iat is scaled dom.
I'm within 2-3* of ambient almost all the time....
Old 12-22-2009, 06:09 PM   #307
MPS-Craig
Member#: 204489
2000 2.5RS
STM
nice. Mine isn't very precise right now. It's changed a bit from stock to get the temps much closer to actual (a couple degrees), but on the far ends of the scale, I haven't verified the scaling.
MPS-Craig is offline   Reply With Quote
Old 12-23-2009, 09:37 AM   #308
CUNNINGHAM
Member#: 5563
JDM 98 GM6, 05 BP6
Porsche 955
subscribe
CUNNINGHAM is offline   Reply With Quote
Old 12-26-2009, 08:46 AM   #309
Ralliart4
Member#: 135927
2002 Impreza WRX RA
Bump! Cant let this one die so fast...
So this program is switchable witht he Japan market STI water spray switch? Interesting stuff the swich cant be more than 50.00.
Old 12-26-2009, 09:10 AM   #310
JSarv
Member#: 163445
l33t *******
[email protected]
Lol not even remotely that easy
Old 12-26-2009, 09:20 AM   #311
69subaru360
Member#: 159682
1995 WRX
2015 F150
It might be that easy for you if you have a wrx RA with the V7 JDM ecu. It didn't work with the usdm ecu.
Old 12-26-2009, 10:14 AM   #312
Ralliart4
Member#: 135927
2002 Impreza WRX RA
Fair enough... Im looking at the information both here and romraider and this is some pretty in depth stuff. It makes me appreciate the engineers much more now (since im just a dumb driver 'hold the wheel monkey, wear your suit monkey, remember to smile monkey, dont crease the car again monkey!!').
I am trying to learn this stuff before i do something that i dont have diappers for! To operate the car under these controls with your advice is more that doable but the trick is seems is to get it fine tuned correctly. I have compared the information to what i have based on my Clark Turner SD map (I also have UTEC so i may just move the switch to "0" and load this as the skeleton with no help from the UTEC) and the values are not that far removed besides ignition timing. If you guys have any more advice I would appreciated it.
For those who dont understand how expensive running antilag is i have some pics from a friend working for prodrive supported a UAE/Saudi Championship Gp.N car. If I can find them when i get home I will post them tonight or tomorrow.... its $$$$$$$ ^ compared to the evo world that i came from
Old 12-28-2009, 03:31 PM   #313
Ralliart4
Member#: 135927
2002 Impreza WRX RA
This is turning out to be some fantastic information lets keep it coming guys.
Old 12-28-2009, 03:55 PM   #314
JSarv
Member#: 163445
l33t *******
[email protected]
More definitions will probably be released in the near future.
Mostly for Idle Timing - but a few others
This will probably apply for all 16bit ecu's as well.
-Jerod
Old 12-28-2009, 10:47 PM   #315
treystoys
Member#: 97436
05 Legacy GT
white
Jerod any luck with the mystery cel?
Trey
treystoys is offline   Reply With Quote
Old 12-28-2009, 11:07 PM   #316
JSarv
Member#: 163445
l33t *******
[email protected]
Trey
No not yet - done a little testing but still haven't traced it 100% back to its origins... Will eventually figure it out.
Old 12-28-2009, 11:29 PM   #317
treystoys
Member#: 97436
05 Legacy GT
white
Cool...and just for another bit of additional info, I'm running a spec c 207 ecu, and still get the blank cel, so its not just the usdm versions.
ttyl
Trey
Old 12-28-2009, 11:34 PM   #318
JSarv
Member#: 163445
l33t *******
[email protected]
ttyl
Trey
No kidding?
Do you have ecu exploder? If so can you do a ram dump and email it to me?
[email protected]
If you don't know how:
Tools:
ecuquery
Do everything it says, make sure you store it to somewhere that is easily found (it likes to not store it where you want it to)
I'm curious if anything is stored there.
I'm almost sure this has to be a hardware issue now but honestly should be able to be disabled one way or another.
-Jerod
Old 12-29-2009, 02:05 PM   #319
Maxwell Power
Member#: 190729
My guess is that it's used for an indication of something and not actually a fault.
Old 12-29-2009, 02:49 PM   #320
hmmyip
Member#: 108776
I was thinking this........ maybe its a sign of being in group n mode?
hmmyip is offline   Reply With Quote
Old 12-29-2009, 04:15 PM   #321
elevenpoint7five
Member#: 187798
04 2 liters of
AWESOME!
ttyl
Trey
Do you have the IC Autowash switch wired up and functioning or no?
Andy
elevenpoint7five is offline   Reply With Quote
Old 12-31-2009, 04:17 AM   #322
JSarv
Member#: 163445
l33t *******
[email protected]
A little update (also can be read on RR forums):
CEL fix will be tested in the morning
Found what MIGHT <---- VERY IMPORTANT be a knock sensitivity table, further testing is needed to prove/disprove this.
Misfire Threshold was found in the 16bit roms.
Defs will be updated in the next week or so (maybe sooner, maybe later) with a ton of new stuff to play with, even for the MAF guys.
- Note to you guys running this rom. WHEN there is a OCV code present FLKC/IAM ARE NOT ACTIVE. FBKC is 100% active and working.
Basically you will never leave FBKC mode, or conditions are not fully met to enter rough and then fine correction mode.
The CEL fix SHOULD fix this 100%, again I will be testing it tom.
IF there is ANYTHING else people think may exist or would like to exist (within reason) please feel free to throw it out there. Even for the MAF based roms.
Once we get through this CEL/NPS (done and verified) stuff - I'm going to begin work on some of the unknown but usefull portions of the SD rom and carry over to MAF based roms (as much as I can)
Future plans as of right now:
Completely define ALL fueling compensations
Per Gear timing implemented
Possible Per Gear IPW Compensation
My favorite
Simple switching via Flash Block "switch" for 100% E85/93 octane switching.
This will include 2 separate Injector scalars - timing tables - OL fueling tables.
More or less you will be able to flip a switch and have PROPER fueling/PROPER timing/Proper injector scalar for both fuels.
Eventually included in this will be the switching of AL/LC by the A/C button.
-Jerod
Old 12-31-2009, 04:22 AM   #323
GLD247
Member#: 207789
2003 WRX EJ257 Swap
GLD247 is offline   Reply With Quote
Old 12-31-2009, 10:33 AM   #324
fastblueufo
Member#: 212154
02 billet crank
pauter rods, pt5857, E85
My favorite
-Jerod
Hey Jerod, How about looking into injector on time for throttle release or anything to do with fueling when throttle is lifted. I have done many logs and there has to be some sort of table for this . Its happens with the sd rom and the maf rom 16 bit.
When throttle is lifted somewhat "It doesnt have to be lifted all the way" the afr will swing rich for a second at like 11.0 and then go back to stoich. If I lift all the way it will go to 11.0 and then fuel will cut and wideband will go to 20. Also if im at 100% throttle and lift it will cut fuel without going rich first. It def has something to do with throttle input.
Merchgod said he thought he found a table of the sort but nothing ever came from it.
fastblueufo is offline   Reply With Quote
Old 12-31-2009, 10:38 AM   #325
JSarv
Member#: 163445
l33t *******
[email protected]
Will take a look right now.
-Jerod
OS Speed Density in LGT groff Open Source Reflashes 10 08-07-2008 08:27 PM
UTEC, DTEC and Speed Density SloRice UTEC 26 03-21-2007 01:26 PM
PCV on WRX with Speed Density Token-Negro Built Motor Discussion 3 07-21-2006 10:26 AM
please ASAP is the STI speed density or mass air bobturismo Off-Topic 12 04-25-2004 02:45 PM
speed-density thng Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 07-10-2003 01:06 AM
