Old 01-07-2010, 09:55 PM   #351
ownnij
Member#: 70459
2002 AW Bugeye ej257
6spd, GT3076R, Alky & EWG
alright i'm needing some clarification on the hardware needed to have this working. if i don't want to run a maf sensor then i will need a GM IAT sensor with would be the open element sensor and not the closed element, this will be wired to the correct wires from the maf sensor plug.
then i will need to replace the map sensor on the throttle body with the aftermarket map sensor. possibility the aem 3.5 bar sensor and wiring for this is straight forward using the original wiring from the oem map sensor?
correct me if im wrong please.
ownnij is offline   Reply With Quote
Old 01-08-2010, 01:15 AM   #352
Ensi
Member#: 90329
05 Sti
Gray
You would need to wire the GM IAT to wires 5 & 6 off the MAF sensor harness, you wouldn't need to replace your map sensor unless your going to run more than 24 psi, if so than the AEM setup is the way to go you also need an adaptor I forget the name of who makes that.
Ensi is offline   Reply With Quote
Old 01-08-2010, 02:53 PM   #353
ownnij
Member#: 70459
NICE, i dont even neeed to replace the map if not running more then 24psi.
Old 01-09-2010, 12:13 AM   #354
SVT_WRX
Member#: 164830
G61 III OVE 58e
Bump for more R & D.
Jerod,
Any update on the CEL yet?
SVT_WRX is offline   Reply With Quote
Old 01-09-2010, 01:09 AM   #355
JSarv
Member#: 163445
l33t *******
[email protected]
still no LIGHT fix. No codes though. I have Fuel Resume on Throttle Lift defined however, I have not completely defined the logic to ensure how it works 100%. The jist of it is, when you let off the throttle (IE Rev/pulling out of gear to come to a stop light) it is the target RPM that the ECU resumes injector pulse width. There are a few other variables on exactly what happens, but as a rule of thumb it drops to table rpm either resumes and falls from there or has an added 0-700 rpms (depending on certian conditions)
I also have "RPM Error" idle timing compensation. Basically the amount of timing swing at idle the ecu applies for "RPM Error" vs Idle Speed Target. If your rpm drops below target idle (after all compensations, which there are many many many more than currently defined) then the ecu adds timing to increase RPMS. If RPM raises above target idle speed, the ecu removes timing to slow engine speed.
I also have (Pointless) Power Steering Idle Compensation additive. As well as thresholds.
I'm also working on throttle lift IPW additive (tip-out) but that is not going so well at the moment) And I am almost possitive that fuel injector phasing is per firing order. 1-3-2-4 (ABCD).
Future will include, but not be limited to, ISCV control (eventually), permanent fix for CEL (even though we are at a standstill on it as there are NO codes and all "pinouts" per ecu logic are correct. Also control over short term fuel correction is a possibility (if I would stop being lazy and test it).
Thats about it? I've pretty much been through the rom 500000 times and everything left worthwhile is too complicated to use. There are some things with fueling that can be changed, but timing is pretty much completely defined.
-Jerod
JSarv is offline   Reply With Quote
Old 01-09-2010, 03:53 AM   #356
GLD247
Member#: 207789
2003 WRX EJ257 Swap
well if theres no codes, and the cel dosent cause limp mode. whats so bad?
correct me if im wrong, this is like a switchable map correct? like antilag on is one map, and it off is another. maybe its just meaning its in Group-N mode?
GLD247 is offline   Reply With Quote
Old 01-09-2010, 10:42 AM   #357
JSarv
Member#: 163445
l33t *******
[email protected]
I've ran my car in every different "mode byte" that works. I've ran GPN mode and I typically run non-GPN mode.
The CEL has nothing to do with GPN mode.
-Jerod
Old 01-09-2010, 05:51 PM   #358
Phatron
Member#: 36033
CEO PhatBottiTuning
2006 STi GTX3582 + Meth
is it possible that the off/on (0/1) is just swapped on this rom for some reason?
Old 01-09-2010, 05:54 PM   #359
JSarv
Member#: 163445
l33t *******
[email protected]
haha yea we've been through that one. Dunno where "Check Engine Light" on/off byte is.... Even with a NON-CEL/CEL ram dump....
Old 01-09-2010, 06:01 PM   #360
Phatron
Member#: 36033
CEO PhatBottiTuning
have u tried forcing a cel to see if it turns it off? Setting the min MAP voltage cel to 2v would be an easy check.
Old 01-09-2010, 06:26 PM   #361
69subaru360
Member#: 159682
1995 WRX
2015 F150
It doesn't. I've had codes set and the cel was on.
Old 01-09-2010, 06:30 PM   #362
elevenpoint7five
Member#: 187798
04 2 liters of
AWESOME!
If it were a backwards bit then all the codes that people have would turn off the light. This is not the case. I am a few days away from just releasing the code fix and revisiting the light another time. I've been pulling my hair out over that thing and I can't figure it out.
Andy
elevenpoint7five is offline   Reply With Quote
Old 01-09-2010, 07:54 PM   #363
bcheck555
Member#: 174930
Do you guys know what A/F Learning Range references? I believe I read somewhere it is not g/s, but something else?
bcheck555 is offline   Reply With Quote
Old 01-09-2010, 08:42 PM   #364
scottyhall
Member#: 180673
02 WRX Wagon
Custom Road Tuning by me.
"load"
scottyhall is offline   Reply With Quote
Old 01-09-2010, 09:44 PM   #365
GLD247
Member#: 207789
2003 WRX EJ257 Swap
is the cel light even that big of a deal to people?
Old 01-09-2010, 09:58 PM   #366
fastblueufo
Member#: 212154
02 billet crank
pauter rods, pt5857, E85
I run a utec so I am able to turn the cel off, But you have to set the rom up funky to run utec with this rom. I Tuned another bugeye with a 35r on this rom with no UTEC and it went well. The customer wanted the cel bulb disabled so thats what I did. Thinking about doing the same thing to my own car. I have a laptop on my car all the time so having the cel bulb disabled is not that big of a deal. Now that the launch control works without anti lag I see no need for the utec.
fastblueufo is offline   Reply With Quote
Old 01-09-2010, 10:04 PM   #367
Phatron
Member#: 36033
CEO PhatBottiTuning
not really. i mean people that have to smog probably wont be running this rom and a mafless setup anyway. at least in states where they have a visual inspection too like cali. u cant even get away with running a CAI at some smog shops.
They failed my old civic that had a k&n cone filter on it.
Old 01-09-2010, 10:37 PM   #368
wrxsti.l
Member#: 156973
2002 ADM WRX STi
STi Black/Blue
On my ADM 2002 STi the CEL turns off, so I don't think it is.
Jsarv, maybe see what is different between the 02 ADM and the 02 USDM models, it might not be ECU logiv that is turning the CEL on and off, but something else.
Leslie
wrxsti.l is offline   Reply With Quote
Old 01-09-2010, 10:52 PM   #369
69subaru360
Member#: 159682
1995 WRX
2015 F150
Leslie
I did that a while ago. The ecu pin for the CEL is the same usdm,jdm,adm,edm.
Old 01-09-2010, 11:15 PM   #370
JSarv
Member#: 163445
l33t *******
[email protected]
Af learning is map reference not g/s or load. That will be fixed soon.
Trust me guys I've tried everything to shut the cel off.
There is a ghost code that we will eventually be able to disable or we will have a permanent cel OFF fix.
Its not just that easy
Old 01-09-2010, 11:27 PM   #371
JSarv
Member#: 163445
l33t *******
[email protected]
Remember when LC is active under all circumstances no knock correction is active. Even if you are not technically "using LC" kc is disabled.
Old 01-10-2010, 12:18 AM   #372
GLD247
Member#: 207789
2003 WRX EJ257 Swap
any videos of this LC or Antilag yet? is it fuel or spark cut?
i didnt see anythign when i searched the thread.
Old 01-10-2010, 02:39 AM   #373
fastblueufo
Member#: 212154
02 billet crank
Thats good to know... Only time I run the LC map is at the track with race gas so kc is mute anyhow.
Old 01-10-2010, 02:10 PM   #374
bcheck555
Member#: 174930
Jerod what do you mean by 'fixed'? Is the logic bad, or just to correct the description of the range?
Not sure if you've seen my thread on RomRaider. Thanks.
http://www.romraider.com/forum/topic5668.html
Old 01-10-2010, 02:55 PM   #375
bcheck555
Member#: 174930
Nevermind, figured it out...
OS Speed Density in LGT groff Open Source Reflashes 10 08-07-2008 08:27 PM
UTEC, DTEC and Speed Density SloRice UTEC 26 03-21-2007 01:26 PM
PCV on WRX with Speed Density Token-Negro Built Motor Discussion 3 07-21-2006 10:26 AM
please ASAP is the STI speed density or mass air bobturismo Off-Topic 12 04-25-2004 02:45 PM
speed-density thng Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 07-10-2003 01:06 AM
