Old 05-14-2011, 12:24 PM   #601
quazimoto
Member#: 70395
Originally Posted by Karl S. View Post
Hydra ?? that's on the same level as Megasquirt.
Please let's not consider those as proper stand-alone/plug-n-play ECU's in the world of things that actually work.
Any good standalone will allow you to pass emission any day .
So what do you consider a "good" stand alone? Because if it does not have the ability to run OBDII functions then for over 50% of the people it's not going to work.It's the same problem the other stand alones have. Most state/county emission stations require the ECU to pass a OBDII "readiness" test and a no DTC test.
quazimoto is offline   Reply With Quote
Old 05-14-2011, 01:37 PM   #602
02RexWI
Member#: 165141
I love a good a debate on tuning solutions any day, but lets try to keep things on track guys.
As for SD- I'll be trying the anti lag and I'll give my impressions after using it at a track day with a large turbo. We'll see how long the holset can last against raw fuel combusting inside of it
02RexWI is offline   Reply With Quote
Old 05-14-2011, 11:17 PM   #603
Karl S.
Member#: 30871
Motec, Pectel, Gems, are some of the better ones. There are few better then that but you are talkink $10k+ .
Sorry, but I didn't know that in some states you needed to have your OBDII hooked up to pass emissions. We don't need to have the OBDII plug hooked up.
Karl S. is offline   Reply With Quote
Old 05-14-2011, 11:32 PM   #604
seanathanq83
Member#: 173241
2002 s256 twinscroll
now with one more gear
yea it suck in houston texas we do, but once you get 4 counties out you dont, and some states dont have to at all, so it just depends where you are
so 02RexWI how did the antilag go??? holset still intact??
seanathanq83 is offline   Reply With Quote
Old 05-14-2011, 11:44 PM   #605
02RexWI
Member#: 165141
It'll be a while before I can do it, I've got to get the new engine broke in first.
Old 05-15-2011, 12:40 AM   #606
seanathanq83
Member#: 173241
Looks good, that's alot like I want. To do with the front mount, except flip it upside down for even shorter piping, have any better pictures of the area you cut out for the piping
Old 05-15-2011, 12:26 PM   #607
02RexWI
Member#: 165141
I originally was going to flip it upside down because of the shorter piping, but it was easier this way, and it was already extremely tight between the charge pipes and the bumper cover.
This is the only other pic I have of it with the bumper cover off. I can snap some pics of them in the engine bay if that helps.
Old 05-15-2011, 05:33 PM   #608
seanathanq83
Member#: 173241
Did you have to do any modification to the headlights or was all good when cutting the holes???? How big are the pipes????? I grenades my 5 speed so I'm seeing if I can get a 6 speed or if I need to try to rebuild my 5speed. Just trying to get the car finished this summer. And would really hate to sell it
Old 05-15-2011, 05:42 PM   #609
02RexWI
Member#: 165141
It clears the headlights without a problem, it all depends how much time u spend on making the pipes.
The pipes are all 2.5" stainless.
I didn't even screw with the 5MT, I got a 2006 STI Trans and rear diff for $1900.
Old 05-15-2011, 07:02 PM   #610
WhatTurboLag?
Member#: 243992
2006 WRX TR
even those are overkill on most peoples setups here. when a EMS like this is needed sure its the better way to go. but untill then i am fine on open souce.
i myself will go with a PRO EFI or a Vipec V88 when i need a EMS.
WhatTurboLag? is offline   Reply With Quote
Old 05-31-2011, 04:55 PM   #611
seanathanq83
Member#: 173241
well 6 speed is in and finally got all the little things fixed up, well i put in my ver8 ecu, flashed the map, car runs just like i did, issue now is the CEL still stays on, the reason i swapped was because i didnt want the damn light on lol, and again no actual CEL, just the light, so Karl s plz tell me what im doing wrong lol now i dont have the engine in, and what i have always herd is the light goes off on its own after a few minutes once the avcs starts working, well i dont have avcs, and no code for it , lol make my light go off hahah
Old 05-31-2011, 05:46 PM   #612
Karl S.
Member#: 30871
^^ what map did you flash to the ecu ??
Old 05-31-2011, 06:10 PM   #613
seanathanq83
Member#: 173241
The only group n I got lol you got one that will turn the light off haha
Old 05-31-2011, 06:17 PM   #614
Karl S.
Member#: 30871
Reset the ecu,.... then start the car, let it idle till it gets up to working/normal temp (till the fans turn on at least once). Then burp the throttle, and the CEL should go out. if not, shut the car off, and restart it again, then there should be no CEL. This is what happens when i run my Grp_N map.
Old 05-31-2011, 06:37 PM   #615
seanathanq83
Member#: 173241
Ok so I need to do it. The first timewhen the engine isn't hot???
Old 05-31-2011, 06:38 PM   #616
seanathanq83
Member#: 173241
Ok so I need to do it. The first time when the engine isn't hot???
Old 05-31-2011, 06:44 PM   #617
Karl S.
Member#: 30871
honestly, i haven't noticed if there is a difference from hot or cold starting. hmmmm.... i know i did it ususally when the engine was cold.
so.... try it cold first if you can.
Old 05-31-2011, 06:47 PM   #618
seanathanq83
Member#: 173241
Will do, or atleast not hot. Will reportback, also feels like I lost download torque even. Though its the same map. I will have to lookinto it
Old 05-31-2011, 10:23 PM   #619
seanathanq83
Member#: 173241
Well I did just as you said, flashed it, started it, waited till it got to 205, blipped the throttle, nothing, still have a light nothing changed, blippdr it again and the car died lol dunno what up, pretty much to the point of saying screw it and attempting to go back to a maf setup with a 4 inch inlet lol. Dunno what to do, light has been on for almost 2 years and it drives me insane
Old 05-31-2011, 11:07 PM   #620
Karl S.
Member#: 30871
so, no codes ??
Old 06-01-2011, 04:17 AM   #621
seanathanq83
Member#: 173241
Nope exactly the same as eighths usdm ecu, ghost cel
Old 06-01-2011, 11:16 AM   #622
Karl S.
Member#: 30871
sent you a PM
Old 06-03-2011, 12:18 AM   #623
seanathanq83
Member#: 173241
sent you a PM
I emailed and pmedyou back
Old 06-03-2011, 01:31 AM   #624
Karl S.
Member#: 30871
never got anything, PM or email.... i just sent you an PM let me know if you got it.
Old 06-20-2011, 09:43 PM   #625
crashtke
Member#: 120912
Not sure who all is still following this, but the gear specific wastegate compensations...those are added to both initial AND max wgdc? And I would guess the same to the target boost per gear?
crashtke is offline   Reply With Quote
OS Speed Density in LGT groff Open Source Reflashes 10 08-07-2008 08:27 PM
UTEC, DTEC and Speed Density SloRice UTEC 26 03-21-2007 01:26 PM
PCV on WRX with Speed Density Token-Negro Built Motor Discussion 3 07-21-2006 10:26 AM
please ASAP is the STI speed density or mass air bobturismo Off-Topic 12 04-25-2004 02:45 PM
speed-density thng Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 07-10-2003 01:06 AM
