Old 09-13-2011, 10:04 AM   #776
kbaldi_29
Member#: 222707
2003 WRX EJ207
SD Carberry....
Cool
Originally Posted by Carbibbles View Post
Hey guys no need to bash on each other. This is supposed to be a fun thing.
The anti-lag actually does work pretty well. While driving, the car just wants to "go" all the time. If you let off the throttle and get back into it there is literally no transient lag at all, it gives it almost a powerful "NA" feel. And this is just using the IAC valve for extra air flow which is minimal. If you were to actually put on a throttle kicker or lock the throttle open a bit I bet it would be pretty crazy.
Granted anti-lag is more stressful on engine components, but if you are just using IAC valve fed anti-lag it really isn't as harsh as you would think. Revving your engine at a standstill and letting it pop back down to idle is probably harsher than when you are actually driving where the effect only comes into play on throttle lift.
Anyway, the next version should be out very soon with map switching and a more aggressive launch control
Jason
Now that u mentioned, it actually feels like an NA while you take of..... lol
Was looking a word to describe it but i think that how it feels like!!!!
awesome job jason!!
kbaldi_29 is offline   Reply With Quote
Old 09-13-2011, 10:11 AM   #777
Karl S.
Member#: 30871
Whatturbolag, what is your problem with me ?
Karl S. is offline   Reply With Quote
Old 09-13-2011, 10:45 AM   #778
02RexWI
Member#: 165141
^Some people are just aholes to anyone who opposes them. Don't take it personal.
02RexWI is offline   Reply With Quote
Old 09-13-2011, 10:50 AM   #779
kbaldi_29
Member#: 222707
2003 WRX EJ207
SD Carberry....
Cool
Dont take it in bad way but i think what he is trying to say is we know the pros, cons and how to use anti lag and even better how to use the group N map, and those non constructive comments are not necessary!!!
I dont think there is something to debate here about this topic, lets concentrate in the purpose of this threat!!!
Old 09-13-2011, 11:47 AM   #780
02RexWI
Member#: 165141
I'll have to use the anti lag as my new pre turbo exhaust leak tester.
Old 09-13-2011, 01:02 PM   #781
kbaldi_29
Member#: 222707
2003 WRX EJ207
SD Carberry....
hahaha.... nice... if dont have a leak it will make one for you!!!
Old 09-13-2011, 01:27 PM   #782
WhatTurboLag?
Member#: 243992
2006 WRX TR
Originally Posted by kbaldi_29 View Post
this map comes with a switch, that maybe the why is much better to use now that you can turn it on and off when there is cops around!
or not even run it on the street and just for competition/showing off to your friends
im not usually an ass, just see below.
this is why, its been in devlopment for so long and it takes a certian knowlege to even run this map. they know what they are getting into by using it and its been beaten to hell by every subaru noob on this forum that it will blow up your car if you use any form of it...
WhatTurboLag? is offline   Reply With Quote
Old 09-13-2011, 01:42 PM   #783
kbaldi_29
Member#: 222707
2003 WRX EJ207
SD Carberry....
Yeahhhhh!!! hahhaa
Old 09-13-2011, 02:01 PM   #784
wil06STI
Member#: 153228
02 WRX Fully Built
Sedona Red
Jason
Jason,
Is it safe to turn the ALS in the rom as is? Any advice before turning it on will be appreciated.
Wil
wil06STI is online now   Reply With Quote
Old 09-13-2011, 02:49 PM   #785
kbaldi_29
Member#: 222707
2003 WRX EJ207
SD Carberry....
Originally Posted by wil06STI View Post
Jason,
Wil
i didnt check the AFR with the base map, on my map i changed timing, AFR table and load compensation table before even started my car the first time, i can tell you for sure it make a difference in the way you set those, so i will make sure your AFR are safe before you turn AL.
I think the best answer can be given by jason!
Old 09-13-2011, 03:24 PM   #786
wil06STI
Member#: 153228
02 WRX Fully Built
Sedona Red
My friends car already has the old SD rom and we just tuned the car so i know that fueling is good. I will just copy everything over and drive around first to make sure is good before i turn on the ALS. So is as easy as checking the box and hitting the deffrost switch to turn it on or off?
Wil
Old 09-13-2011, 03:40 PM   #787
kbaldi_29
Member#: 222707
2003 WRX EJ207
SD Carberry....
Wil
it is as simple as turn the switch off and on as long the car is in between temp threshold it will activate!
Now, in the same way i did you can just copy from the previous map into this one, but be careful that the tables have same values, as jason explained, you need to open your previous map with carberry definition to get load compensation table right, apparently there is a difference in this table if you load it with a different definition, so just use carberry def and copy that table to the new map!
Old 09-13-2011, 04:29 PM   #788
Carbibbles
Member#: 292996
02 wrx
Jason,
Wil
All the anti-lag stuff is still the same as the group-n rom, on my car I think I just changed the "idle target fueling (anti-lag active)" to 12.xx (cant remember exactly but basically just richened it up a bit). Another thing you may want to do if you extensively use the anti-lag is to relocate your 02 sensor from your header to your downpipe as it could break apart and damage your turbine on your turbo.
And as kbaldi_29 said, use the CarBerry defs to open your old SD tune and then copy everything over.
Carbibbles is offline   Reply With Quote
Old 09-13-2011, 04:33 PM   #789
kbaldi_29
Member#: 222707
2003 WRX EJ207
SD Carberry....
good that you mentioned the o2 part.... the scaling on this map is for the o2 sensor on downpipe or header? i used the scaling of grp n map because i know that one is on downpipe!
Old 09-13-2011, 04:44 PM   #790
02RexWI
Member#: 165141
Location should not matter for scaling. I believe the scaling is sensor dependent.
Old 09-13-2011, 04:55 PM   #791
kbaldi_29
Member#: 222707
2003 WRX EJ207
SD Carberry....
i been under the idea all this time that i was... so good to know.... thanks
Old 09-14-2011, 03:09 AM   #792
vc08
Member#: 173946
noob question ... : where to find carberry defs?
vc08 is offline   Reply With Quote
Old 09-14-2011, 08:23 AM   #793
wil06STI
Member#: 153228
02 WRX Fully Built
Sedona Red
Go to the link in post #740.
Old 09-15-2011, 10:35 AM   #794
sorrowfulkiller
Member#: 170439
I <3 Lamp
Will there be any way to eventually ditch the stock o2 sensor and instead use a 0-5 volt signal from where the tgv sensors used to be? It would be a huge plus to be able to tune with and use after market wide bands as the o2 sensor. That and I heard talk of using a tgv sensor input for an ethanol content sensor?
sorrowfulkiller is offline   Reply With Quote
Old 09-15-2011, 01:14 PM   #795
Carbibbles
Member#: 292996
02 wrx
This is definitely possible, if enough people are interested I can implement it.
Old 09-15-2011, 01:36 PM   #796
sorrowfulkiller
Member#: 170439
I <3 Lamp
I noticed some people on the romraider forums were talking about the ethanol sensor. Haven't seen anyone talking about the oxygen sensor thing though
Old 09-15-2011, 01:40 PM   #797
02RexWI
Member#: 165141
I'd rather stick with the stock Do sensor for closed loop fuelling. They seem to last longer.
As for the ethanol content sensor, I'm the one who asked for it, and yes I'm still interested in using it, but the car will be going away for the winter.
Old 09-15-2011, 06:39 PM   #798
sorrowfulkiller
Member#: 170439
I <3 Lamp
Even if we could data log a wide band with the stock ecu it would be worth it.
Old 09-15-2011, 08:08 PM   #799
Carbibbles
Member#: 292996
02 wrx
Romraider can actually already do this with aem and innovate
Old 09-15-2011, 08:19 PM   #800
sorrowfulkiller
Member#: 170439
I <3 Lamp
I mean to be able to wire it directly to the ecu.
OS Speed Density in LGT groff Open Source Reflashes 10 08-07-2008 08:27 PM
UTEC, DTEC and Speed Density SloRice UTEC 26 03-21-2007 01:26 PM
PCV on WRX with Speed Density Token-Negro Built Motor Discussion 3 07-21-2006 10:26 AM
please ASAP is the STI speed density or mass air bobturismo Off-Topic 12 04-25-2004 02:45 PM
speed-density thng Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 07-10-2003 01:06 AM
