Welcome to the North American Subaru Impreza Owners Club Tuesday August 23, 2016
Old 09-15-2011, 09:26 PM   #801
02RexWI
Member#: 165141
If romraider could have an easily configurable option to set up a sensor via the TGV wires that would be ideal. A menu to just plug in the sensor information would be all you need.
02RexWI is offline   Reply With Quote
Old 09-16-2011, 12:36 AM   #802
NSFW
Member#: 140444
05 Stage Free LGT
ATP 3076, 6MT, AVO FMIC
You could hack it yourself without too much work. Just wire it up and log the TGV sensor voltage. If you did OK in your math classes you can create a new conversion function in the logger.xml file that does some math on the voltage and gives you the result in AFR.
Old 09-16-2011, 08:22 AM   #803
02RexWI
Member#: 165141
^It would just be nice to have a form pop up that would modify the logger.xml automatically. I'm sure I could figure out the scaling myself, but wouldn't it be nice to just have a simple form to fill out instead of doing it manually?
Old 09-16-2011, 09:01 AM   #804
MRF582
Member#: 48219
. Always drive
the race line .
Originally Posted by sorrowfulkiller View Post
Will there be any way to eventually ditch the stock o2 sensor and instead use a 0-5 volt signal from where the tgv sensors used to be? It would be a huge plus to be able to tune with and use after market wide bands as the o2 sensor. That and I heard talk of using a tgv sensor input for an ethanol content sensor?
Originally Posted by Carbibbles View Post
This is definitely possible, if enough people are interested I can implement it.
Before you spend your time recoding this, please investigate the success many people have had simply moving the stock oxygen sensor post-turbo... For some reason people are so reluctant to believe that it works well even when there have been several documented cases. I have even seen one working perfectly fine first hand. I'd just hate for you to do unnecessary work.
The ethanol sensor is a fantastic idea!
MRF582 is offline   Reply With Quote
Old 09-17-2011, 04:13 AM   #805
Carbibbles
Member#: 292996
02 wrx
Carbibbles is offline   Reply With Quote
Old 09-21-2011, 12:30 AM   #806
seanathanq83
Member#: 173241
2002 s256 twinscroll
now with one more gear
Does anyone know which two wires I need to splice into off of the maf sensor to hook up the GM IAT sensor???? I want to try and get this hooked up this weekend so I have everything working the best possible since I just got my engine running
seanathanq83 is offline   Reply With Quote
Old 09-21-2011, 08:25 AM   #807
02RexWI
Member#: 165141
I assume you are looking for a 2002 WRX... correct?
If nobody answers by tonight I'll look it up in the repair manual.
Old 09-21-2011, 01:18 PM   #808
kbaldi_29
Member#: 222707
2003 WRX EJ207
SD Carberry....
its the pin 27 of connector b135 of the ecu, dont have the color of the wires but this might help you. From the sensor one its going to be ground and the other to the pin i mentioned before. And you will need to re scale the sensor in the map. good luck!
If still need the color i will look into it later, when i get to my car!
kbaldi_29 is offline   Reply With Quote
Old 09-21-2011, 10:36 PM   #809
seanathanq83
Member#: 173241
I have the manual, I know there Are 5 wires And I believe someone said once before it was the brown wire and another one, im assuming I need the sheilded signal so im thinking sheilded signal ( which has a ground, and power????) Or just ground and signal????
Edit B27 is brown, doesn't say what it is, actually im looking in the 2002jdm sti manual, but most the wires are the same, and I have a jdm ver8 engine And complete engine harness, but I guess that wouldn't matter since the maf is part of the bulk head harness, either way B27 is Br and im thinking its also E13/E8, E13 being the sheilded wire and E8 being the sheild ground so basically power and signal,
Does anyone know what to rescale, and what to rescale it too????
Edit #2
Group d I believe is the GR which is green red but not sure why it wouldn't use the PL ( purple - blue) sheilded wire.
Old 09-23-2011, 10:25 AM   #810
seanathanq83
Member#: 173241
bump for an answer
Old 09-23-2011, 10:35 AM   #811
02RexWI
Member#: 165141
The shielded wire is for the MAF. There are only 2 IAT wires, and 3 MAF wires.
Old 09-24-2011, 09:52 AM   #812
sorrowfulkiller
Member#: 170439
I <3 Lamp
On a usdm wrx the maf signal wire is maf purple shielded wire. Then just find out which one is getting voltage and which is getting ground
sorrowfulkiller is offline   Reply With Quote
Old 09-24-2011, 10:10 AM   #813
h82lose91
Member#: 269069
1997 Impreza
Blue/Grey
Ok on the MAF Sensor Plug theres 5 wires.
Pin ------ Color ------ Signal/Voltage ------ Ecu Pin
Pin1 ------ YL ------------ 12v ----------Main Power Relay
Pin2 ------ BG -------- Sensor Grnd ------ 84/7
Pin3 ------PL ---------- Maf Sign -----------84/13
Pin4 ------ Br --------- AirTemp Sig ------ 135/27
Pin5 ------ GR --------- Ground -----------Ground Connector
See if that helps.
Last edited by h82lose91; 10-18-2011 at 01:21 PM. Reason: Caught slipping by Maxwell Power! Corrected Pin3/Pin4
h82lose91 is offline   Reply With Quote
Old 10-17-2011, 03:40 PM   #814
sorrowfulkiller
Member#: 170439
I <3 Lamp
updates?
Old 10-17-2011, 04:36 PM   #815
strange_magic
Member#: 259257
I love this rom!
strange_magic is offline   Reply With Quote
Old 10-17-2011, 05:16 PM   #816
Carbibbles
Member#: 292996
02 wrx
updates?
I have been posting updates on RomRaider, I have a new version that I should be able to release very soon. Im going to make a thread on here(Nasioc) as well
New features:
-NLTS - this will require a small amount of wiring. Luckily the clutch switch basically switches a ground to and from a relay, so all that needs to be done is your desired ECU input needs to be spliced into the GY wire on the clutch switch. By just splicing in and not cutting the wire, the clutch-in-to-start function will remain functional.
-Removed the MAX load table
-Included the ability to use positive or negative values in the MAP sensor offset
-Removed the user levels
-Coded in a "cut x from y" method for launch control and NLTS (to get a quicker more accurate RPM hold)
-DTCs can effect CEL status alongside KnockCEL
-Sparkcut Launch Control
-Ability to disable Defrost logic (if anybody ever had issues with using it as an input)
-Ability to target higher than 24psi (haven't done this yet but it should be quick)
-Fuel pump duty hysteresis (so fuel pump duty doesn't go crazy when you are right on the edge of the switch point)
and maybe some other random little things I forgot lol
Old 10-18-2011, 03:10 AM   #817
Maxwell Power
Member#: 190729
New features:
Amazing. You are in the wrong line of work.
Maxwell Power is offline   Reply With Quote
Old 10-18-2011, 03:12 AM   #818
Maxwell Power
Member#: 190729
Pin3 ------ Br --------- AirTemp Sig ------ 135/27
Pin4 ------ PL ---------- Maf Sign -----------84/13
See if that helps.
You have three and four backwards.
Old 10-18-2011, 03:14 AM   #819
Maxwell Power
Member#: 190729
bump for an answer
Iat is the last two. The small wires, not the big yellow with green wire.
Old 10-18-2011, 10:33 AM   #820
MRF582
Member#: 48219
. Always drive
the race line .
ORLY?
Old 10-18-2011, 10:43 AM   #821
Carbibbles
Member#: 292996
02 wrx
I agree, you should hire me to work at your shop! haha just messing, Im actually working on getting my mechanical engineering degree right now, but I hope to have a career that has some bearing in the automotive industry.
Old 10-18-2011, 11:38 AM   #822
Maxwell Power
Member#: 190729
Originally Posted by MRF582
ORLY?
Yeah really . Look at it again, your diagram shows it right there.
You think I haven't done this 100 times? I've been doing this for years, hell I'm pretty sure I was the first.
Old 10-18-2011, 11:47 AM   #823
Token-Negro
Member#: 81659
2006 STI / 2010 FXT
Aspen White / Silver
DOM is the man. I love how Subaru will show you a connector 5 pins label them 1 - 5 left to right then put the wires in the connector 1,2,4,3,5.
Token-Negro is offline   Reply With Quote
Old 10-18-2011, 12:30 PM   #824
MRF582
Member#: 48219
. Always drive
the race line .
Damn, you're right. But, you were the first to use a non-Subaru IAT sensor on a MAF Subaru?
Jesus, how the eff did I miss that. I myself did this a month ago and I just looked at the wire colors.
Old 10-18-2011, 01:19 PM   #825
h82lose91
Member#: 269069
1997 Impreza
Blue/Grey
Ah, yes you are right, not that everyone didnt know that already, i was kinda in a hurry when i put that up. Thats what i get!
Good catch!
Gonna edit my post to reflect it properly.
OS Speed Density in LGT groff Open Source Reflashes 10 08-07-2008 08:27 PM
UTEC, DTEC and Speed Density SloRice UTEC 26 03-21-2007 01:26 PM
PCV on WRX with Speed Density Token-Negro Built Motor Discussion 3 07-21-2006 10:26 AM
please ASAP is the STI speed density or mass air bobturismo Off-Topic 12 04-25-2004 02:45 PM
speed-density thng Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 07-10-2003 01:06 AM
