Old 10-26-2011, 01:35 AM   #851
NSFW
Member#: 140444
05 Stage Free LGT
ATP 3076, 6MT, AVO FMIC
Originally Posted by fastblueufo View Post
I've met a software engineer fixing to retire. He just opened a private shop near me with a dyno. He has a vw that he has been able to hack the ecu and do some stuff that's preety nice. He got very interested in this platform when I showed him how far os has gotten with subaru. Hopefully I can get him onboard with romraider soon. He seemed to know exactly how to go about implimenting live tuning since he had done it on his vdub.
If he wants a head start with 32-bit ECUs I'll be happy to point him to some tools that help a lot. For me, having good tools made the difference between wishing I could modify my ECU's code, actually doing it. Everything I've done is shared at RomRaider already (or will be shortly), but a roadmap couldn't hurt.
Old 10-26-2011, 09:46 AM   #852
02RexWI
Member#: 165141
Originally Posted by elevenpoint7five View Post
This is a damn good idea! I might code it up and see how it works on my car, if so I can probably offer a patch for whatever ecu/ecu's you need. Though it will be a little while as I'm pretty busy with work right now.
Andy
I lied... his post was on here: http://www.romraider.com/forum/viewt...hp?f=14&t=7731
02RexWI is offline   Reply With Quote
Old 11-07-2011, 10:54 PM   #853
gaby
Member#: 94097
2004 WRX Hybrid GT35
[email protected]
Just read the hole thread ufff. You guys are awesome.
gaby is offline   Reply With Quote
Old 11-26-2011, 11:07 AM   #854
bcheck555
Member#: 174930
I know there are quite a few people running this ROM. A few of us have seen the AFR's lean out as the temp rises. A couple different opinions on this on romraider.
Starts here http://romraider.com/forum/viewtopic...7594&start=810
continues here http://romraider.com/forum/viewtopic.php?f=15&t=7841
Maxwell Power, ride5000, blueufo hope you guys see this.
bcheck555 is offline   Reply With Quote
Old 11-26-2011, 12:21 PM   #855
gaby
Member#: 94097
[email protected]
I will post some logs in rr if temps rise enough.
Old 01-14-2012, 11:59 PM   #856
slinkyWRX
Member#: 280483
03 Bugeye WRX
Originally Posted by JSarv View Post
Lets do a reference:
3000
30psiA (15.3psiG @ sea level)
@ 30psiA and 3000 rpms SD Load Compensation is a conservative 5%.
30*(0.0764448)+(-0.00683594)*1.05= 2.40 G/Rev
So @ 3000 rpms and 30psiA (15.3psi relative) you will have a load value of 2.40 G/Rev. This is theoretical...
im just starting out learning SD. so i hope im not just being a noob. but your equation doesn't equal 2.40
idk if you just rounded up or if the math needs to be exact.
but i come up with 2.28616626
just wondering how/why you used 2.40 as the g/rev when it isnt what the math comes out too.
again just trying to learn. thanks.
slinkyWRX is offline   Reply With Quote
Old 04-20-2012, 01:15 AM   #857
dub c
Member#: 145069
Keep It Sleazy
Question regarding IAT sensor and methanol jet placement...
-I have heard some conflicting information, the way I see it is the IAT sensor should be placed as close to the head as possible or at least midway through the runner (so heat from the valves isn't transferred), and the methanol near/before the throttle body.
So the cooler air charge going into the engine is measured by the IAT.
Contradictory information:
-In a MAF based system the airflow in doesn't change when the meth is spraying, the charge temp is just lower and the burn speed is slowed but the mani. pressure did not change with the methanol injection.
-In a SD system, if there is a significant drop in IAT, the IAT sensor will trigger the ECU to add more fuel when in fact the airflow into the engine isn't changing causing the car to run rich.
PLEASE HELP!
Hope I made sense.
Thanks in advance.
dub c is offline   Reply With Quote
Old 04-20-2012, 03:02 PM   #858
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
you really ought to have a completely different fuel map for spraying meth ADI.
Old 09-12-2012, 02:22 PM   #859
skets
Member#: 170698
2003 WRX V-Limited
Just to confirm will there be an issue running this ROM on either my JDM 03 WRX or 03 STi ECU?
skets is offline   Reply With Quote
Old 09-12-2012, 02:29 PM   #860
MRF582
Member#: 48219
. Always drive
the race line .
Any further discussion on 16-bit Speed Density should happen here :
http://www.romraider.com/forum/viewforum.php?f=36
MRF582 is offline   Reply With Quote
Old 04-01-2013, 06:30 AM   #861
STi MAN86
Member#: 287906
2006 STi
Any one have any info on the 32bit I would love to go with out a maf on a ADM 06 STI A8DH200V
STi MAN86 is offline   Reply With Quote
Old 04-01-2013, 04:56 PM   #862
Phatron
Member#: 36033
CEO PhatBottiTuning
2006 STi GTX3582 + Meth
All the sd info is on romraider.
There is a speed density subforum
Old 06-21-2013, 11:41 AM   #863
Amaan_ej20
Member#: 358865
2003 2L JDM WRX STI
Do u have the injector scaling for this map with 800cc sard injectors on an 03 wrx STi jdm?
Amaan_ej20 is offline   Reply With Quote
Old 06-21-2013, 01:18 PM   #864
MRF582
Member#: 48219
. Always drive
the race line .
12345
Old 07-22-2013, 09:05 PM   #865
bazza
Member#: 119307
I have a question. I've got a new ecu / engine setup for my track car. It would seem the previous tune hasn't accounted for the big injectors properly. They are set to 575cc, they're ID1000's on E85.
And I think to get around this, the previous person has changed the SD base load table to fix it.
My question is - can anyone actually look at this and give me an idea of the proper numbers? I think proper injector size for ID1000 is 650cc (for E85). But then I imagine the SD base load table would be wrong. And then I'd like to have proper figures in the fueling table - not 8's and 6's!!! PLEASE HELP The engine is EJ207/DOM3XTR running 25 psi.
bazza is offline   Reply With Quote
Old 07-22-2013, 09:11 PM   #866
Clark Turner
Member#: 178047
02 WRX STI Spec C
I would not even use that map. Whoever made it has no idea what they are doing with SD. The Scaling for ID1000s would be around 900 but that depends on your latency table.
Clark Turner is offline   Reply With Quote
Old 07-22-2013, 09:30 PM   #867
bazza
Member#: 119307
Tell me about it, it's extremely frustrating how bad this is given how much power it's making... dissapointing indeed.
So, if I'm to start the fuel map from scratch, how might I do this, I don't have a MAF in the system at all btw so I can't log it and come up with a VE table.
Car has ID1000 with E85. Found the ID1000 latency table (online version), think these are the figures. The ecu's figures were out from this also.
6.5 .. 3.98
9.0 .. 2.34
11.5 .. 1.47
14.0 .. 1.06
16.5 .. 0.84
Also here is the other offset info:
Old 07-22-2013, 09:35 PM   #868
Clark Turner
Member#: 178047
02 WRX STI Spec C
That map points to a classic lack of fuel pump. As the car makes more power on the top end, the fuel pump cant keep up. The tuner then tries to make up for this by putting really low fuel targets and skewing the VE table.
So even if you did straighten all of this out, Its probably going to be lean as hell on boost up top.
The difference between me and a lot of the so called tuners is that if this kind of thing happens, I get out and say, the car needs a pump, lines and regulator. Sometimes they get mad. Sometimes they listen to me.
So let us know the setup. Let me guess? A single walbro and stock lines?
C
Old 07-22-2013, 09:44 PM   #869
Carbibbles
Member#: 292996
02 wrx
Looks like they used the stock groupn ve map and tried to adjust fueling with the fuel target map. I'd be surprised if the timing table has even been adjusted from the stock map.
Carbibbles is offline   Reply With Quote
Old 07-22-2013, 09:45 PM   #870
bazza
Member#: 119307
C
Okay, I'll back the truck up a little and explain. The donor street car indeed had a walbro. I pinched the loom, ecu, turbo, engine, cluster and stuck it in my time attack car (gc8) which has plenty of fuel pump and far better fuel system. I just love using the stock ECU and it's huge ability to do pretty much whatever I want it to do.
So being a picky person, I've gone through the tune and instantly found the fuel side of things is rubbish as you picked up on - and I'd LOVE to fix it but I'm trying to get my head around how the SD works, slowly picking it up.
At least the timing table looks okay lol.
Old 07-22-2013, 09:49 PM   #871
Carbibbles
Member#: 292996
02 wrx
Originally Posted by bazza View Post
Okay, I'll back the truck up a little and explain. The donor street car indeed had a walbro. I pinched the loom, ecu, turbo, engine, cluster and stuck it in my time attack car which has plenty of fuel and far better fuel system. I just love using the stock ECU and it's huge ability to do pretty much whatever I want it to do.
First note that the tables are in absolute pressure so subtract 14.7psi in your head to figure out what gauge pressure is. Then set your primary open loop table to the afr values you would like the engine to run at each pressure and rpm cell. Then tune the sd load comp(ve) map to achieve your afr targets.
Old 07-22-2013, 09:53 PM   #872
bazza
Member#: 119307
Will give it a go. For interest sake, do you think there is a way I can roughly calculate the proper figures? My dyno is about 300 miles away
Old 07-23-2013, 01:04 AM   #873
bazza
Member#: 119307
New fuel and base load compensation map. I basically took the known AFR's (from WOT dyno tune) and adjusted the base load compensation table to fix that issue. Then I set the actual AFR table to more realistic AFR targets. Know I just have to go test and hopefully fine tune (hopefully not a huge amount of fine tuning haha).
Old 07-23-2013, 01:25 AM   #874
Clark Turner
Member#: 178047
02 WRX STI Spec C
Ok. Just understand that fixing the map may cause the engine to run very very lean on boost.
C
Old 07-23-2013, 01:34 AM   #875
bazza
Member#: 119307
C
Hi Clark, please check the above tables and tell me what you think? I've adjusted a few things in both tables (using calculations from carbibbles original post on romraider), obviously changing the AFR table alone will end in tears!!! Cheers
OS Speed Density in LGT groff Open Source Reflashes 10 08-07-2008 09:27 PM
UTEC, DTEC and Speed Density SloRice UTEC 26 03-21-2007 02:26 PM
PCV on WRX with Speed Density Token-Negro Built Motor Discussion 3 07-21-2006 11:26 AM
please ASAP is the STI speed density or mass air bobturismo Off-Topic 12 04-25-2004 03:45 PM
speed-density thng Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 07-10-2003 02:06 AM
