Old 11-17-2009, 08:59 PM   #126
BBEJ22T
Member#: 204953
1995 STi - Swap
Anybody put on some miles with anti lag ON and a big turbo setup? Too aggressive?
BBEJ22T is offline   Reply With Quote
Old 11-18-2009, 05:52 AM   #127
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
imo the anti lag needs to have some mechanical modifications to make it work properly (a throttle stop). the iacv isn't going to cut it.
Old 11-18-2009, 08:04 AM   #128
69subaru360
Member#: 159682
1995 WRX
2015 F150
I've tried it and it does work. It's a soft anti lag. Looking at the ROM, there are different values in the tables for different TPS values. So I think you are supposed to adjust the throttle plate screw open more for the antilag to hit harder.
To the guy who posted above, either way this isn't something that you want to put a lot of miles on, if you care about your engine and turbo lasting a long time. I was just going to use it for drag racing, 20 seconds at a time.
Old 11-18-2009, 10:07 AM   #129
JSarv
Member#: 163445
l33t *******
[email protected]
Odds are there is a map that determines iacv duty per ect/rpm. I'm sure this is involved with the mode byte as iac duty nears 100% at idle with al set.
There are enough undefined items in this rom to make a person cringe
JSarv is offline   Reply With Quote
Old 11-18-2009, 11:48 AM   #130
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
define "work."
Old 11-18-2009, 01:36 PM   #131
69subaru360
Member#: 159682
1995 WRX
2015 F150
define "work."
I lift off the throttle and it pops and bangs a bit and makes a few psi of boost.
Old 11-19-2009, 07:40 AM   #132
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
i guess you've never had launch control, eh?
as anti-lag systems go, this one, on a stock car w/o mechanical mods, is useless: there is just no way to get the requisite amount of air past a closed throttle to give the hot side any puff.
Old 11-19-2009, 09:55 AM   #133
69subaru360
Member#: 159682
1995 WRX
2015 F150
I've been using the tinywrex LC since he released the patch. I actually couldn't get the LC on this ROM to work. I think possibly because of differences in the neutral or clutch switch inputs, but I didn't check.
Anyway this is while driving, lift off the throttle and it antilags a bit a light popping and banging and rpms hang at about 2000 3000 rpm at about 1-2 psi. I think looking at the way the idle is set up, you need to adjust the throttle plate so it is open more to get more of the antilag effect.
This isn't a hard flame shooting full boost antilag like you hear on open class rally car and drag cars, it's softer, but it does do something.
I gave up on this rom and went back to maf, for a few reasons. I couldn't get the antilag to be switchable with my 02 usdm ecu, I didn't like driving with a cel all the time, and really I was happy with how my car drove with maf. If I can get a V7 or V8 ECU, I would try it again.
Old 11-19-2009, 05:03 PM   #134
JSarv
Member#: 163445
l33t *******
[email protected]
Oh what the future holds for this rom
So many undefined tables/compensations/fixes......
-Jerod
Old 11-19-2009, 05:11 PM   #135
69subaru360
Member#: 159682
1995 WRX
2015 F150
-Jerod
Oh yeah? Who's doing the work on the definitions and new tables? It's beyond my ability for sure.
Old 11-19-2009, 07:21 PM   #136
BBEJ22T
Member#: 204953
1995 STi - Swap
I'll try tomorrow with BOV plate and throttle stop. Maybe it will do a cool link/autronic style injector cut idle.
Old 11-19-2009, 09:52 PM   #137
Phatron
Member#: 36033
CEO PhatBottiTuning
2006 STi GTX3582 + Meth
i have an OT question for u guys......in my 02 wrx i installed a aem 3.5 bar MAP sensor....and i rescaled it so that it reads 5 psi low since the 16 bit ecu wont allow for inputs above 24.75.....
i just put the car back togehter and started tuning it again.....well im putting down almost 100whp less in airboy. Same boost, same afr, same timing....100whp less. the car was sitting for 8-10 months with gas in it ~1/4 tank. i put 6 gallons of 95 octane in and 1 gallon of meth to try and clean it out. is it possible that the old gas is that bad and is causing the power loss? or is my motor done?
i havent gotten around to a comp test or a leak test.....just kinda confused and pissed right now.
Old 11-19-2009, 10:23 PM   #138
JSarv
Member#: 163445
l33t *******
[email protected]
with the SD rom? Do you have knock control enabled correctly........?
Old 11-19-2009, 10:29 PM   #139
Phatron
Member#: 36033
CEO PhatBottiTuning
not with the SD rom, just plain old 02 wrx romraider.
Old 11-19-2009, 10:31 PM   #140
JSarv
Member#: 163445
l33t *******
[email protected]
did you change any of your WGDC settings? or adjust your mbc? Could be your map scaling off up top lying to you.
-Jerod
Old 11-19-2009, 10:36 PM   #141
Phatron
Member#: 36033
CEO PhatBottiTuning
im just running a perrin ebcs.....yes i changed the wgdc.
"20 psi" which is 25.25 psi from peak to redline. 14* up to 20* of timing. 11.3-11.5 AFR.
thats giving me 310 whp in airboy. copy/paste this log into airboy and graph the maf g/s.....it goes nuts.
use 06 sti since i have an 06 sti 6 speed and total weight of 3000 lbs.
Code:
Time	LOAD	RPM	MAF	FBKC	FLKC	IAM	IGN	MRP	MAFv	WGDC
0	0.24	2694	10.71	0	0	16	44.5	-14.7	1.86	0
172	0.25	2698	11.53	0	0	16	45	-14.7	1.86	0
370	0.26	2710	12	0	0	16	45.5	-14.7	1.92	0
566	0.3	2737	16.25	0	0	16	45	-13.73	2	0
769	0.47	2770	23.11	0	0	16	42.5	-8.59	2.34	0
960	0.51	2804	24.08	0	0	16	42.5	-7.37	2.44	0
1147	0.55	2864	27.06	0	0	16	39	-7	2.4	1.18
1343	0.57	2901	27.59	0	0	16	37.5	-6.69	2.46	13.73
1535	0.59	2960	29.85	0	0	16	36.5	-6.34	2.52	27.45
1730	0.59	2994	29.68	0	0	16	36.5	-5.96	2.58	36.47
1939	0.61	3042	31.25	0	0	16	35	-5.51	2.66	54.9
2128	0.61	3112	32.4	0	0	16	35	-5.09	2.62	58.82
2318	0.65	3193	34.81	0	0	16	35	-4.64	2.72	58.82
2515	0.66	3226	36.48	0	0	16	35	-4.22	2.76	59.22
2703	0.66	3312	39.07	0	0	16	35.5	-3.71	2.72	59.61
2895	0.68	3378	38.07	0	0	16	35	-3.19	2.86	60
3085	0.68	3448	38.66	0	0	16	35.5	-2.65	2.72	60.78
3276	0.72	3477	43.93	0	0	16	35	-2.05	2.86	60.78
3471	0.74	3582	43.17	0	0	16	35	-1.31	2.94	61.57
3660	0.8	3671	46.64	0	0	16	35	-0.54	3.04	61.96
3852	0.83	3746	53.72	0	0	16	34	0.44	3.08	62.35
4043	0.88	3799	60.37	0	0	16	29.5	1.59	3.14	62.75
4248	0.98	3930	64.85	0	0	16	25	3	3.32	63.53
4438	1.03	3998	73.28	0	0	16	22.5	5.07	3.34	64.31
4640	1.15	4118	82.98	0	0	16	20.5	7.52	3.56	64.71
4835	1.32	4235	95.93	0	0	16	15.5	10.83	3.58	65.88
5013	1.44	4355	109.3	0	0	16	14.5	14.5	3.8	66.67
5200	1.64	4499	126.71	0	0	16	14	18.22	3.92	67.45
5406	1.7	4667	137.5	0	0	16	14	19.96	4.1	68.24
5589	1.7	4870	136.36	0	0	16	14	20.19	4.16	68.63
5777	1.63	5027	135.86	0	0	16	14	19.38	4.12	70.2
5967	1.68	5226	143.85	0	0	16	14	19.22	4.18	73.33
6164	1.69	5270	150.13	0	0	16	14	19.88	4.3	74.9
6346	1.71	5442	162	0	0	16	14	19.68	4.34	76.47
6539	1.68	5588	154.72	0	0	16	14	19.61	4.34	80
6724	1.63	5699	160.7	0	0	16	14	19.57	4.32	82.75
6930	1.67	5818	156.25	0	0	16	14	19.59	4.38	84.31
7106	1.59	5882	152.36	0	0	16	14	19.7	4.38	87.45
7307	1.56	6107	158.66	0	0	16	14	19.55	4.36	90.59
7497	1.47	6188	152.71	0	0	16	14	20.11	4.32	91.37
7695	1.46	6324	158.87	0	0	16	15	19.7	4.38	91.76
7881	1.44	6432	143.06	0	0	16	15	19.94	4.24	92.55
8074	1.41	6493	155.16	0	0	16	15.5	19.92	4.36	92.94
8264	1.39	6550	151.92	0	0	16	16.5	20.09	4.36	93.33
8459	1.38	6620	158.44	0	0	16	17.5	20.32	4.36	93.73
8637	1.35	6800	152.32	0	0	16	19.5	20.57	4.28	94.51
8829	1.37	6957	153.06	0	0	16	20	20.85	4.34	94.9
Old 11-19-2009, 10:42 PM   #142
JSarv
Member#: 163445
l33t *******
[email protected]
Intake Diameter?
Old 11-19-2009, 10:45 PM   #143
Phatron
Member#: 36033
CEO PhatBottiTuning
its a perrin blow through....not really sure. i think 3"
Old 11-19-2009, 10:46 PM   #144
JSarv
Member#: 163445
l33t *******
[email protected]
Well your moving about as much air as I do @ around 360-380whp on airboys...
By chance did you check tire pressure.....? I mean it was sitting for a long time.
Old 11-19-2009, 11:00 PM   #145
Phatron
Member#: 36033
CEO PhatBottiTuning
yup....aired them up to 40psi all around.
how are u determining my airflow? how are u getting 360-380whp from my half maf'd 160 g/s?
the way the maf jumps seems to tell me there is a leak somewhere....
for reference here is the last log i did in february. pre blow through, but with the fmic and the car was 3280 lbs total with me. its 3000 lbs with me now.
Code:
Time	load	rpm	fbkc	flkc	ign	mrp	maf	lc-1
0	0.2	3042	0	0	41.5	-13.4	9.73	13.99
153	0.21	3055	0	0	41.5	-12.97	11.25	14.08
318	0.28	3066	0	0	41.5	-10.96	15.49	14.55
474	0.39	3018	0	-0.35	35	-8.12	23.79	17.38
639	0.47	3107	-2.11	-0.35	29.5	-6.79	24.94	17.35
798	0.51	3133	-2.11	-0.35	27	-5.9	28.2	15.41
957	0.55	3224	0	-0.35	28.5	-5.26	29.91	13.48
1117	0.57	3252	0	-0.35	27	-4.72	30.98	13.24
1279	0.6	3289	0	-0.35	26.5	-4.23	33.57	13.67
1433	0.62	3378	0	-0.35	26	-3.67	34.96	14.66
1595	0.64	3445	0	-0.35	25	-3.17	37.11	14.29
1757	0.67	3453	0	-0.35	24	-2.49	39.45	14.16
1916	0.69	3499	0	-0.35	23	-1.76	41.47	14.66
2075	0.73	3628	0	0	22.5	-1.01	44.26	15.89
2236	0.76	3680	0	0	20.5	-0.25	48.11	14.14
2394	0.82	3780	0	0	19.5	0.93	51.54	13.8
2552	0.88	3801	0	0	17	2.22	57.57	13.88
2700	0.98	3937	0	0	15.5	3.85	66.98	14.82
2860	1.08	4139	0	0	15	5.76	74.16	13.14
3020	1.2	4058	0	0	14	8.35	80.39	11.98
3176	1.38	4249	0	0	13	12.12	101.01	10.92
3327	1.55	4368	0	0	13	15.53	113.85	10.76
3491	1.69	4467	0	0	11.5	19.94	132.18	9.8
3653	1.79	4780	0	0	11	23.01	140.92	10
3813	1.8	4864	0	0	11	24.33	144.99	9.97
3973	1.75	5013	0	0	11	24.13	147.02	10.13
4142	1.72	5219	0	0	11	23.61	149.31	10.6
4292	1.71	5252	0	0	11.5	22.68	151.85	10.66
4446	1.67	5474	0	0	11.5	22.02	152.11	10.33
4599	1.67	5546	0	0	13	21.41	154.91	10.32
4760	1.62	5756	0	0	14	21.04	155.16	10.03
4916	1.57	5901	0	0	15.5	20.65	154.91	10.35
5079	1.53	6073	0	0	16.5	20.44	154.14	9.82
5235	1.51	6097	0	0	16.5	21.1	155.67	9.94
5391	1.49	6260	0	0	18	20.77	155.92	9.69
5546	1.46	6404	0	0	18.5	20.9	156.18	9.63
5701	1.43	6499	0	0	19	20.9	157.2	9.5
5858	1.41	6596	0	0	19	20.94	156.43	9.5
Old 11-19-2009, 11:02 PM   #146
JSarv
Member#: 163445
l33t *******
[email protected]
I could care less about your load value or g/s- they are BS numbers.
Your MAF V tells me on a 3" inlet/blow through (which I run) and see 4.44-4.48v on mine that your HP number is close...
-Jerod
Old 11-19-2009, 11:08 PM   #147
Phatron
Member#: 36033
CEO PhatBottiTuning
load up my old vs new in airboy.....how does that make sense? down from ~420whp to 310 whp......maybe the weight throwing it off?
can 8 month old gas really cause this?
Old 11-19-2009, 11:11 PM   #148
JSarv
Member#: 163445
l33t *******
[email protected]
Throw in your old weight with your new log... Alot of things could effect this - but imho improperly scaled map sensor could cause this as well, basically tricking you...
Old 11-19-2009, 11:14 PM   #149
Phatron
Member#: 36033
CEO PhatBottiTuning
even with the old weight its still only 336 whp.....and i didnt change the map scaling since then, it was the same in the old log.
Old 11-19-2009, 11:14 PM   #150
JSarv
Member#: 163445
l33t *******
[email protected]
don't know what to tell ya
OS Speed Density in LGT groff Open Source Reflashes 10 08-07-2008 08:27 PM
UTEC, DTEC and Speed Density SloRice UTEC 26 03-21-2007 01:26 PM
PCV on WRX with Speed Density Token-Negro Built Motor Discussion 3 07-21-2006 10:26 AM
please ASAP is the STI speed density or mass air bobturismo Off-Topic 12 04-25-2004 02:45 PM
speed-density thng Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 07-10-2003 01:06 AM
