Old 12-13-2009, 09:23 PM   #201
JSarv
Member#: 163445
l33t *******
12.07@115.9mph-EJ205
What I was going to have someone log is a compensation to the fueling process. It looks like a failsafe map, but it also is used againsted injector latency, almost like a latency compensation.
-jerod
JSarv is offline   Reply With Quote
Old 12-13-2009, 09:25 PM   #202
TDagen
Member#: 163648
2002 Wrx,2.5L,HTA86
E85,2007 6mt,No traction
-jerod
Strange and interesting ... Subaru360 on rr forums donated himself/car for the cause tommorow ...
TDagen is offline   Reply With Quote
Old 12-13-2009, 09:57 PM   #203
JSarv
Member#: 163445
l33t *******
Honestly - I'm not sure what it is.
To be perfectly honest - I think I found injector phasing to lol. This Table is involved in Final IPW, and the value is subtracted by 128 and multiplied by two - compared to a value and then allows the process of each injector to fire per the ecu's recommendations.
But I think it also determines injector phasing as well, as it calls a specific address for each injector in two places.
-Jerod
Old 12-15-2009, 12:06 AM   #204
elevenpoint7five
Member#: 187798
04 2 liters of
AWESOME!
Dwell times are available now: http://www.romraider.com/forum/topic5577.html
Andy
elevenpoint7five is offline   Reply With Quote
Old 12-15-2009, 01:52 PM   #205
SVT_WRX
Member#: 164830
G61 III OVE 58e
Default Thanks!!!!!!!!!!!!!
THANK YOU JSARV AND EVERYONE ELSE WHO CHIPPED IN! EXCITING STUFF!
SVT_WRX is offline   Reply With Quote
Old 12-15-2009, 03:30 PM   #206
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
on a side note, i am now very curious as to what the utec's dwell is.
i do not BELIEVE that it is variable as the oem ecu is.
i know that the majority of utec firmware development was done in AU.
it is certainly possible that the AU spec cars had longer dwell from the get-go.
like i said earlier in the thread, back some 5-6 years ago when utec users were reporting coil pack failures left and right, txs claimed up and down that dwell was "same as stock." the question then becomes, what's stock? as we can see dwell depends on both ECU rom AND rpm.
finally, knowing the utec's dwell duration would give us an ipso facto "safe" starting point. maybe "safe" is the wrong word, but speaking personally i've been running on a utec since fall '03 and i've never had a coil pack problem.
unfortunately my tek 454's trigger circuit has been flaky for years. i think i need a new tunnel diode. if it's not one thing it's another...
Old 12-15-2009, 03:34 PM   #207
elevenpoint7five
Member#: 187798
04 2 liters of
AWESOME!
Are there any AU spec ROMs available? I could locate the dwell table quite easily and release it in the definitions if someone wanted me to...
The current defs, http://www.romraider.com/forum/topic5603.html I believe have all ADM, JDM, USDM, and EDM ROMs that were available to me on scoobypedia.
I must say, the last line of your post confused the hell out of me!
Andy
Old 12-15-2009, 03:40 PM   #208
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
seems i was wrong about that...
http://forums.nasioc.com/forums/show...40#post5938140
still there's the question of whether the AU cars are categorically different coil-wise from the US cars.
Old 12-15-2009, 03:58 PM   #209
elevenpoint7five
Member#: 187798
04 2 liters of
AWESOME!
Do you have a ROM from an AU spec car, or know where to get one? It would take 5 minutes to figure it out if someone has one.
Andy
Old 12-15-2009, 04:18 PM   #210
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
Old 12-15-2009, 04:29 PM   #211
elevenpoint7five
Member#: 187798
04 2 liters of
AWESOME!
Every ROM on that link is defined in the def files that I posted a link to earlier. I was not putting together the fact that AU = ADM
Maybe this will help I'm not sure why the font wouldn't change in mspaint. Paint skills > me I guess.
Andy
Old 12-15-2009, 04:30 PM   #212
elevenpoint7five
Member#: 187798
04 2 liters of
AWESOME!
Wow that's really small. They are the same though for those of you that don't have magnifying glasses built into your eyes.
Andy
Old 12-15-2009, 04:39 PM   #213
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
ok, good to know.
it was just a question hanging around in the back of my mind for a couple of years that was recently revived by your work.
Old 12-15-2009, 04:41 PM   #214
elevenpoint7five
Member#: 187798
04 2 liters of
AWESOME!
Glad I could help
Are the UTEC settings actually the same as stock then?
Andy
Old 12-15-2009, 04:57 PM   #215
Phatron
Member#: 36033
CEO PhatBottiTuning
2006 STi GTX3582 + Meth
so......should i load this up or what?
new parameters to play with.....hmm.
are the dwell tables now unlocked in the regular old MAF roms?
Old 12-15-2009, 05:00 PM   #216
elevenpoint7five
Member#: 187798
04 2 liters of
AWESOME!
Yes, http://www.romraider.com/forum/topic5603.html has the def files for every ROM that was available to me.
If you don't understand dwell I recommend you learn about it before playing with it or at least make very small changes. You can fry coil packs pretty quickly with the wrong settings as well as create a lot of excessive heat. Changing the dwell times will also change your AFR which, in turn, will require the rest of the tune to be changed.
Andy
Old 12-15-2009, 05:26 PM   #217
Phatron
Member#: 36033
CEO PhatBottiTuning
i dont like to read. i just change stuff and see what happens
Old 12-15-2009, 05:30 PM   #218
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
incidentally i would be very suspicious of attributing afr changes to tweaking dwell.
next you're going to be saying that timing changes afr too.
Old 12-15-2009, 05:53 PM   #219
SVT_WRX
Member#: 164830
G61 III OVE 58e
Andy
Wow. The SD 02' map has quite a bit more dwell than the USDM 02' MAF based map. Nice!
Oh, wait, I have black coil packs.....hmmmmm.....I'm guessing lower dwell a smidge????
Old 12-15-2009, 05:54 PM   #220
Phatron
Member#: 36033
CEO PhatBottiTuning
I was wondering that too. Does unburnt fuel + air = the same AFR as burnt fuel + air?
probably be a little different.....even having the wideband at the tailpipe registers a little different AFR than in the downpipe.
if anyone else (like me) never heard of dwell before this thread then this is a good read
http://www.tonyfoale.com/Articles/Ignition/Ignition.htm
Old 12-15-2009, 09:58 PM   #221
bcheck555
Member#: 174930
Indeed, so has anyone measured time to max current for either coil pack?
bcheck555 is offline   Reply With Quote
Old 12-15-2009, 10:21 PM   #222
JSarv
Member#: 163445
l33t *******
Actually a wideband will react to a better combustion by registering a leaner value. Not substantially but yes it can and WILL change.
from wiki:
"The sensor does not actually measure oxygen concentration, but rather the amount of oxygen needed to completely oxidize any remaining combustibles in the exhaust gas. Rich mixture causes an oxygen demand. This demand causes a voltage to build up, due to transportation of oxygen ions through the sensor layer. Lean mixture causes low voltage, since there is an oxygen excess."
A more complete combustion will leave less combustible particles in the exhaust stream. Again, this will not be substantial.
-Jerod
Old 12-15-2009, 10:32 PM   #223
elevenpoint7five
Member#: 187798
04 2 liters of
AWESOME!
It is incredibly fast. I didn't record the value when I was measuring everything, but with the oscope set to 5ms boxes everything showed up as square waves. We had to "zoom" in to less than 1ms boxes in order to get any sort of slope on the wave.
-Jerod
And the reason I bring this up is because of the massive change in dwell between the black and grey packs. So those of you changing the settings to match your packs might notice a change in AFR that should be paid attention to.
Andy
Old 12-15-2009, 10:33 PM   #224
JSarv
Member#: 163445
l33t *******
aren't you supposed to be getting wasted??!
Old 12-15-2009, 10:35 PM   #225
elevenpoint7five
Member#: 187798
04 2 liters of
AWESOME!
Haha I wish! I have school in the morning and we are at her moms house visiting.
Andy
OS Speed Density in LGT groff Open Source Reflashes 10 08-07-2008 08:27 PM
UTEC, DTEC and Speed Density SloRice UTEC 26 03-21-2007 01:26 PM
PCV on WRX with Speed Density Token-Negro Built Motor Discussion 3 07-21-2006 10:26 AM
please ASAP is the STI speed density or mass air bobturismo Off-Topic 12 04-25-2004 02:45 PM
speed-density thng Factory 2.0L Turbo Powertrain 0 07-10-2003 01:06 AM
Message Board Statistics All times are GMT -4. The time now is 03:16 PM.
