Go Back   NASIOC > NASIOC Technical > Factory 2.5L Turbo Powertrain
Old 10-15-2009, 09:12 PM   #1
blah0r
Member#: 106122
Default Tons of White smoke from exhaust after intake change??? Help
Fixed.
blah0r is offline   Reply With Quote
Old 10-15-2009, 10:56 PM   #2
my name is joe
Member#: 171412
Did you check your oil?
my name is joe is offline   Reply With Quote
Old 10-15-2009, 11:11 PM   #3
blah0r
Member#: 106122
Also, i just checked my PCV valve, which is working fine. Car has 37k miles.
i just changed the oil before all this and it was pretty low. Was reading about maybe it being turbo seals, any idea if this a spot to check for these symptoms?
Old 10-16-2009, 12:24 AM   #4
IIdiceII
Member#: 90438
leak in the intake? intake or turbo inlet hose? need to be more specific.
IIdiceII is offline   Reply With Quote
Old 10-16-2009, 03:40 AM   #5
C89ZX7R
Member#: 119154
2004 White
STi
What year is the car? is it a 2.5 wrx or a 2.5 sti?
don't see how you made it this long with out filling out your profile.....
C89ZX7R is offline   Reply With Quote
Old 10-16-2009, 04:05 AM   #6
303 sti
Member#: 107565
2010 STI
Are you getting a CEL? Could be your MAF malfunctioning so it's dumping too much fuel
303 sti is offline   Reply With Quote
Old 10-16-2009, 04:30 AM   #7
penusai
Member#: 102808
2002 v8 EJ207
v7 6spd FP Green
compression test?
penusai is offline   Reply With Quote
Old 10-19-2009, 01:35 PM   #8
blah0r
Member#: 106122
fix.ed
Old 11-24-2009, 03:02 AM   #9
subaru_01
Member#: 193661
2001 Impreza R.S
Silverthorn
white smoke means a blow headgasket....or water leak into the exhaust...
subaru_01 is offline   Reply With Quote
Old 11-24-2009, 05:12 AM   #10
Exarch
Member#: 208321
2012 WRX
Extremely Red
If the turbo is epically boned it could potentially be dumping both oil and coolant into the exhaust, don't forget that your turbo has both of these flowing through it. Might be time to yank the downpipe and have a lil look at your hot side.
Also pull your engine's dipstick and have a look, if the oil looks like it's kinda frothy or otherwise wierd, that can indicate you have coolant in your oil. Coolant in oil can be from a cracked cylinder or a failed oil cooler. Combusted coolant can be from a blown head gasket or cracked cylinder. Combusted oil can be from a cracked piston or seriously cracked head. Combusted coolant and oil at the same time can be from any of the two above or from your turbo. Factoring in that you're not able to boost yet the car seems to run otherwise fine leads me back to the epically boned turbo statement.
Check that turbo, 17.2 PSI on a TD04 is going to be a bit hard on it to begin with as the wheels will be turning at close to 170,000 RPM vice the stock 130,000.
Exarch is offline   Reply With Quote
Old 11-24-2009, 07:26 AM   #11
Uncle Scotty
Member#: 16200
OK Houston
we have an Uncle
Originally Posted by blah0r View Post
Relevant Mods: Perrin Intake, Custom DP/catback, stage 2 tune OS
So my car has'nt been hitting target boost and its been making a strange oil/gas smell from the exhaust. Its been happening for about 1k miles and i decided that it might be a leak in the intake, so i swapped to another aftermarket intake (AVO). When i swapped intakes and started the car, huge puffs of white smoke came out the exhaust and the car wouldnt hit close to 1bar even though the tune is for 17.2 psi.
Obviously i have a problem, so i switched to the stock intake. The same problem occured, huge puffs of white smoke from exhaust. No smoke from anywhere under hood. More smoke comes out when in boost then idle, although alot comes out during idle. Car idles fine.
If a problem existed before i swapped intakes to stock, what could my problem be? I checked coolant res and it is very low, when it was recently changed, so it is indeed coolant coming from my exhaust.
Battery was reset after intake change to stock. Any help is greatly appreciated. Thanks.
faulty logic
Old 11-27-2009, 02:27 PM   #12
blah0r
Member#: 106122
problem solved.
Old 11-27-2009, 05:15 PM   #13
NSFW
Member#: 140444
05 Stage Free LGT
ATP 3076, 6MT, AVO FMIC
And you're not going to tell anyone else what went wrong, how you fixed it, or how you identified the problem?
Old 11-27-2009, 07:49 PM   #14
blah0r
Member#: 106122
^^ If someone asked i planned on it.
The bolt holding the ypipe to the intercooler core was backing out of the threads and was almost out when i finally found this happening. Sealing it gave me my power back and no more smoke.
The problem was identified when i decided to change my aftermarket throttle body silicone hose back to the stock piece. When i had the IC off, i checked to make sure everything was tight, and it wasnt.
Thanks for the help, im happy my car works fine now, and i've decided not to sell it for now.
white smoke from exhaust on first start of day if its cold outside. yamaha_rider619 Service & Maintenance 16 05-21-2010 11:57 AM
06 Wrx Just Installed Vf39 Turbo And Tbe, Now White Smoke From Exhaust! Help lordizzy626 Newbies & FAQs 10 02-12-2010 03:10 PM
Help - White smoke from exhaust during acceleration Mrs. White Factory 2.0L Turbo Powertrain 4 10-21-2009 06:24 PM
White smoke from exhaust u_r_a_bus Newbies & FAQs 5 07-01-2005 09:14 AM
VF30 recently installed - now white smoke from exhaust... is2scooby Factory 2.0L Turbo Powertrain 14 12-21-2002 05:12 AM
Message Board Statistics All times are GMT -4. The time now is 12:36 AM.
