Old 05-12-2002, 04:47 PM   #1
inpreza kid
Member#: 3334
Default stock wrx turbo fittings?
sorry for cross posting but wrx guys don't want to seem too helping these days. i can't find these fittings anywhere. does anyone know if i can order these through the dealership? or if anyone has the part numbers for the oil drain, coolant feed, and coolant drain fittings?
inpreza kid is offline   Reply With Quote
Old 05-13-2002, 09:22 AM   #2
subachad
Member#: 8488
1993 Impreza GCStyle
Teal
Try an auto parts shop or a race shop that sells Earls, Goodrich, etc...
Chad
93 1.8T
subachad is offline   Reply With Quote
Old 05-13-2002, 03:00 PM   #3
latinskllz
Member#: 3461
1998 BMW M3 Coupe
Estoril Bleau
Default have you tried a subaru dealership
to order the OEM parts?
latinskllz is offline   Reply With Quote
Old 05-13-2002, 03:08 PM   #4
inpreza kid
Member#: 3334
i've looked around a few places with goodrich parts and haven't had any luck. at last resort i'm going to try and order these parts from the dealer. my question is would the dealer be able to order these parts since they are oem wrx parts? this is a long shot but would anyone have the part numbers?
Old 05-13-2002, 03:58 PM   #5
subachad
Member#: 8488
Teal
I was able to go to an auto parts store and get A/N fittings for my RHB5. They are normal Earls fittings, all you need is the size and pitch of the bolt, then maybe you could order them online.
Just take the turbo to the store with you and ask, it worked for me.
Chad
93 1.8T
Old 05-13-2002, 07:41 PM   #6
inpreza kid
Member#: 3334
subachad do you know any places online i can order these pieces from? what about the oil drain fitting?
i know the thread pitch to all the fittings. just having some problems finding a source.
Old 05-14-2002, 09:45 AM   #7
subachad
Member#: 8488
Teal
If you know the size and pitch, you can get Earls fittings from Frey Racing. They are a race shop in San Jose, CA.
www.freyracing.com
Chad
93 1.8T
Old 05-14-2002, 01:30 PM   #8
Member#: 6655
2000 Impreza 2.5RS
Dirty White
Impreza Kid:
Oil Feed on turbo is 10mm x 1.0 metric pipe thread
Coolant Feed & Return on turbo are both 12mm x 1.5 metric pipe thread.
For the return i'd just have a plate made and weld a -6AN or larger bung on it.
Part numbers are:
-4AN to 10mm x 1.0 = FCM2239
-6AN to 12mm x 1.5 = FCM2246
-6AN weld-on bung = 997106
All are available from http://www.bakerprecision.com
Hope this helps.
- Adam
adam@stonehill.edu is offline   Reply With Quote
Old 05-14-2002, 04:41 PM   #9
inpreza kid
Member#: 3334
Old 05-14-2002, 04:59 PM   #10
Member#: 6655
2000 Impreza 2.5RS
Dirty White
Impreza Kid:
If you know the size then why are you asking?
Also on Baker Precisions website they do not list an application for 10mm x 1.5 nor 12mm x 1.25.
I bought the fittings that I specified and they work perfectly. That's all I know .
- Adam
Old 05-14-2002, 07:31 PM   #11
inpreza kid
Member#: 3334
Old 05-15-2002, 09:57 AM   #12
Member#: 6655
2000 Impreza 2.5RS
Dirty White
Impreza Kid: No problem. For the oil return I plan just to make a metal plate & have a AN bung welded to it. Should work just fine.
Thanks.
- ADam
Old 05-15-2002, 04:17 PM   #13
scooby5
Member#: 1998
1999 Impreza STi v5
Silver Mica
Here's the parts you need from the dealer.
You can look at the image, and from the first 5 digits of the part # identify what it is on the chart.
15196AA060 Gasket Oil
15197AA060 Outlet-Turbo Oil
14443AA000 Bolt, Turbo x2
(D91204) 803912040 Gasket x4
15194AA100 Screw Union x2
14430AA121 Pipe Complete - Turbo #2
scooby5 is offline   Reply With Quote
Old 05-15-2002, 07:59 PM   #14
inpreza kid
Member#: 3334
scooby5, you wouldn't imagine how thankful i am for those part numbers i'm sure it will be very helpful to lots of people.
stock header, stock sti uppipe, stock wrx turbo, stock intercooler dubyawagon NESIC Private Classifieds 4 06-24-2011 04:18 PM
Stock STi turbo fit 02 WRX? MikalsWRX Newbies & FAQs 9 03-16-2004 04:15 PM
WTB: Stock WRX Brakes, calipers, brackets. Stock WRX turbo deyes Private 'Wanted' Classifieds 0 11-03-2003 05:14 PM
Will stock '03 WRX turbo fit '00 2.5 RS? getek20 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 10-12-2003 12:13 PM
does anyone have the part numbers to the stock wrx turbo fittings? inpreza kid Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 05-12-2002 07:45 PM
