Old 05-12-2002, 05:00 PM   #1
edkwon
Member#: 453
2014 Audi S4 B8
Metallic Gray
Default WRX engine transplant-does it fix the 99MAF problem?
I'm wondering if doing a WRX engine or whole drivetrain transplant will fix the dreaded MAF sensor problem in a 99 RS because I am assuming you replace the whole intake manifold as well as the engine. Is this true or wrong?
Ed
edkwon is offline   Reply With Quote
Old 05-12-2002, 05:37 PM   #2
Aphex
Member#: 146
'16 WRX Limited
with the WRX engine swap, you swap everything, engine, manifold, and the ECU. since you swap the ecu as well, then you need all the WRX sensors, including the MAF sensor.
eli
Aphex is offline   Reply With Quote
Old 05-12-2002, 06:53 PM   #3
Eric SS
Sooby Guru
Member#: 1914
2000 2.5RS w/ EJ22T
swap and N20. gone. : (
in other words, yes, it will fix it
Eric
Eric SS is offline   Reply With Quote
Old 05-12-2002, 07:18 PM   #4
DoctorNick
Member#: 7022
heh, DC ITCA are
my rides
Default Re: WRX engine transplant-does it fix the 99MAF problem?
Ed
ok, so ed. i work so hard to make my auto as fast as the other rs's and wrx's then ALL OF YOU MWSOC guys build up your cars just to make me the slowest in the midwest again@#!
DoctorNick is offline   Reply With Quote
Old 05-13-2002, 10:25 AM   #5
edkwon
Member#: 453
2014 Audi S4 B8
Metallic Gray
Neal: hahahaha, sorry m'man.
Ed
Old 05-13-2002, 02:53 PM   #6
Boeleni
Top Scoob 003
Member#: 1812
1999 Impreza Try-R
Satin Black
Unless you swap in a 99 WRX which has the same Hot Film type MAF, only bigger
Boeleni is offline   Reply With Quote
Old 05-14-2002, 02:05 PM   #7
Z1 Performance
Member#: 9327
Actually, the JDM MAF is not bigger....same part number and everything, and yes, they had problems with them there too...but a solution is one the way this summer....you heard it here first
adam
Z-1
Z1 Performance is offline   Reply With Quote
Old 05-14-2002, 02:11 PM   #8
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
They've been saying that for over 2 years now.
Realistically... swapping another car's MAF in and adjusting the signal is the best bet I've heard, though.
Old 05-14-2002, 03:20 PM   #9
Boeleni
Top Scoob 003
Member#: 1812
1999 Impreza Try-R
Satin Black
The 99 WRX MAF has a much larger diameter then the 2.5RS one. Trust me. I had to order one because mine was too small.
Does the AP STI fix the pinging problem? SemperFiSti Engine Management & Tuning 2 06-22-2004 03:52 PM
WRX automatic - does it ruin the WRX experience? ufoguy Newbies & FAQs 49 10-29-2003 07:20 PM
How much does it weigh and does it fit the WRX? mynew02 Brakes, Steering & Suspension 11 07-18-2002 02:27 AM
WRX engine transplant Rags Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 02-22-2002 03:47 PM
engine swap, does it fit only a suby Newbies & FAQs 2 12-23-2001 03:25 AM
