Rocky Mountains Impreza Club
Go Back   NASIOC > NASIOC Chapters > Rocky Mountains Impreza Club Forum -- RMIC
Old 10-16-2009, 09:18 PM   #1
uaoSTI
Member#: 175957
2005 Subaru STI
Default 95 Legacy CEL - how to reset it
I am a new owner of a 95 legacy outback wagon (EJ22) that will be my commuter/winter beater. The previous owner said the CEL is from the knock sensor from him using bad gas. I filled it with 91 and fuel treatment but the CEL is still on (only have gone a few miles so no real surprise i guess). I also unplugged the positive in the battery for one minute hoping it would reset the CEL as well.
How can I get the CEL to reset? Scan it (autozone)? Should I unplug the battery for an hour or longer?
no pix because its ugly (seriously).
uaoSTI is offline   Reply With Quote
Old 10-16-2009, 09:32 PM   #2
PCSkiBum_21
Member#: 164437
EVO IX - Track Car
BRZ - Daily
you can have a shop read it, i'm not sure if they do re-set or not though. solid can for sure. to reset it yourself, pull the negative terminal and pump the brake pedal until the lights don't show up anymore. that should reset it for you. if not let it sit for 15 minutes or so after you do that.
PCSkiBum_21 is offline   Reply With Quote
Old 10-16-2009, 11:04 PM   #3
907Bum
Member#: 183634
02 wrx/ 92 ss
Booze fueled :)
Welcome to OBD-1 Cars.
Go to legacycentral.org and read the thread on pulling engine codes, there are two connectors under the dash that by connecting and turning the ignition on will have the car flash the code for you. This should be the same on your car as it is mine (obd-1 wise) i have a 1st gen wagon, since yours is second gen it might be slightly different.
Now some ej22e bits (I just rebuilt and replaced the ej22e in my winter beater this weekend), the knock sensors are prone to fail, find one with a white connector and make sure the connecting surfaces are clean and free of debris, this sounds simple yet no one checks the surfaces. Odds are the car will throw a 35 code as well (purge vale solenoid), there is a thread on how to wire in a resistor to bypass the solenoid. Uhh there is a thread on legacy central's cite on resetting the ecu as well.
I'd link all the address but alas I'm at work
907Bum is offline   Reply With Quote
Old 10-17-2009, 12:40 AM   #4
PCSkiBum_21
Member#: 164437
EVO IX - Track Car
BRZ - Daily
ah^ i fail.
Old 10-17-2009, 10:44 AM   #5
xblackdeathx
Member#: 72357
06 fxt,11 outback
,96 land cruiser
The only way to fix it, is with a hammer.
xblackdeathx is offline   Reply With Quote
Old 10-18-2009, 12:17 PM   #6
uaoSTI
Member#: 175957
2005 Subaru STI
Thanks for the help. I just pulled the terminal on the battery and it seems to have worked. Gonna hopefully get it by inspection today.
Old 10-22-2009, 11:56 PM   #7
DLC
out back
Member#: 1964
05 OB XT LTD
Silver/Gray
The 95 Legacy is OBDII.
http://www.sl-i.net is the place to go for 95-04 Legacy info. Legacy Central is more for the 90-94 owners.
DLC is offline   Reply With Quote
CEL Blinking... how to fix it aferrari88 Newbies & FAQs 11 11-23-2008 05:03 PM
CEL! How to get rid of it? WRXfoME Newbies & FAQs 8 09-21-2005 05:18 PM
got a CEL...how to reset? JayByRd724 Newbies & FAQs 2 06-11-2003 07:39 PM
How to reset ecu? Robmat General Forum Archive 4 11-17-2000 12:46 AM
How to reset cookies John2.5RS General Forum Archive 10 05-18-2000 12:24 AM
