Old 05-12-2002, 06:46 PM   #1
DoctorNick
Member#: 7022
heh, DC ITCA are
my rides
Talking Calling Automatic RS-Ts(and OBS's :D )
Hey, I would like to get a listing of all you guys and the mods you guys got. I wanna see what I can look forward to. My goal for my RS-T is about a 14sec quartermile. Comming from a 17 sec (or worse) quarter with out mod to the tranny (minus a cooler) I think that is as fast as I can get on stock internals. What do you guys think? Also What are you guys running? Any suggestions when going around after it is installed? How to drive it..how to listen for tranny problems. ect...
-Neal
DoctorNick is offline   Reply With Quote
Old 05-13-2002, 09:23 AM   #2
Ethan
Member#: 246
Just throw on a small turbo, run about 5lbs and you'll be low 14's.
Ethan is offline   Reply With Quote
Old 05-13-2002, 09:39 AM   #3
omahasubaru
Member#: 1594
1995 WRX
2002 Legacy
through on a better turbo and get good engine management and you can run 10 Psi all day long.
omahasubaru is offline   Reply With Quote
Old 05-14-2002, 06:03 AM   #4
Kevin Thomas
Street Racing Instructor
Member#: 110
1989 1989 XT6
Default Tranny first
I'd say fix up the tranny first. Synthetic tranny fluid, tranny cooler (edit...just read you had that already), torque converter upgrade and possibly a valve body. Yep, it'll cost a bit of $$$ but its a worthwhile investment into insuring your tranny lasts. You won't gain hp but your 1/4 mile times will drop and your drivability would be much improved.
Kevin Thomas is offline   Reply With Quote
Old 05-14-2002, 12:37 PM   #5
Jejunum
Member#: 15773
2011 Impreza WRX
can somoene explain the torque converter upgrade? link me to something even
what are hte disadvantages/advantages
who makes them? how hard to install? how much
thnx!
Jejunum is offline   Reply With Quote
Old 05-14-2002, 01:09 PM   #6
DoctorNick
Member#: 7022
heh, DC ITCA are
my rides
Default Re: Tranny first
ok, well I am going to change to synthetic very soon but the tranny mods I was under the idea that modding the valve body would make the car shift harder and that the TC mod would take the car a longer time to get off the line in normal grandma driving because of a highrpm to lockup...
-Neal
Old 05-14-2002, 08:47 PM   #7
Kevin Thomas
Member#: 110
1989 1989 XT6
Default Torque converter info
Post Torque Converter question here
As for the valve body, it eliminates slippage of the clutchpack during shifting. It just instantly grabs. This reduces transmission heat build up, slows down wear from the slipping parts and 'may' lower your 1/4 mile time(s) due by reducing the time the clutchpacks take to engage (no slipping in between gears).
You can read more about Level Ten's Valve Body (Hydrosystem) here.
Old 05-17-2002, 01:50 PM   #8
Rich L
Member#: 961
1999 RS-Tw/ CobraMAF
Custom Rallispec kit/IC#1
you better not race any grandma's then!
anywho...
modding your torque converter to a higher stall speed can be a great mod. I took a good sec off my old Conquest TSi 0-60mph.
If you got a high reving motor and turbo.... even better.
You'll get into juicy part of the power band quicker and stay there longer.
Rich L is offline   Reply With Quote
Old 05-17-2002, 06:52 PM   #9
Rovah
Member#: 1375
2003 WRX Rally Car
My RS-T is an auto. Tranny cooler, AMSOIL and Pro Torque convertor are the mods so far. Waiting to see what people find with their TB upgrades before I leap in.
It's not tuned, so I can't post any times yet...
Cheers! John
Rovah is offline   Reply With Quote
Old 05-17-2002, 07:21 PM   #10
Andrew
Member#: 1170
2005 STi
after i put in a jdm engine, ill be buying a WRX 4eat and TCU and sending the valve body to level10 and the torque converter to pro torque.
oh yeah for the guys who get to the point of running a FMIC...at the rim of the world rally we noticed something very interesting on a wrx that i figured us 4eat guys could use.... since they had a FMIC, they had space at the hood scoop to do whateve rthey want...so what did they do? they put an oil cooler there. i was thinking we could use it to place the tranny cooler...but if you drag race thats probably not the best place (heat soak).
Andrew is offline   Reply With Quote
Old 05-17-2002, 07:37 PM   #11
DoctorNick
Member#: 7022
heh, DC ITCA are
my rides
andrew thats a cool idea...I am going to look into that!
Old 05-17-2002, 07:43 PM   #12
Andrew
Member#: 1170
2005 STi
yeah theres no way i can afford to send my current tranny to them and have that week-long or so downtime. plus with the WRX tranny we will have a constant 45/55 torque split in D instead of 90/10. if i coudl get one for as much as riftswrx got his, id be a very happy camper
doh..you were probably talking about the tranny cooler i dont know how bad heat soak would be. you could probably create a duct underneath it and not allow a lot of the hot air into it.
Old 05-19-2002, 02:44 AM   #13
DoctorNick
Member#: 7022
heh, DC ITCA are
my rides
rex tranny? uk spec? info plz...if ya wanna share
Old 05-19-2002, 02:58 AM   #14
Andrew
Member#: 1170
2005 STi
i just wnat a US WRX tranny and tcu. thats all. nothing special.
Old 05-19-2002, 03:13 AM   #15
DoctorNick
Member#: 7022
heh, DC ITCA are
my rides
I just want and automatic 5 speed
Old 05-19-2002, 01:42 PM   #16
inpreza kid
Member#: 3334
actually the torque split is more like 60front 40rear for the MPT- muti-plate transfer tranny.
http://www.i-club.com/forums/showthr...hreadid=189146
inpreza kid is offline   Reply With Quote
CALL All RS/TS suspension mods!! Come in and let me know! shinjyo Brakes, Steering & Suspension 7 01-22-2006 09:20 PM
Difference between RS/TS and WRX calipers? Orson Brakes, Steering & Suspension 5 11-20-2005 07:44 PM
('93-'01) Out of Respect: Forum requests for L models and 02 RS/TS Kostamojen Impreza Forum 10 08-07-2001 05:59 PM
Pics of Blaze Yellow WRX and RS, TS, OBS info from Chicago Auto Show kelley nelson General Forum Archive 12 02-09-2001 10:53 AM
