Welcome to the North American Subaru Impreza Owners Club Friday February 27, 2015
Old 10-17-2009, 04:05 PM   #1
Dragicon
Member#: 112323
Default 18x9.5 +44, Will it fit on STI stock struts?
Hi guys,
I am probably going to get some 18x9.5 +44 rims. I currently have Prodrive springs and lowering camber plates up front on my STI. I have stock struts on the car. I am worried that the inside of the rim will contact the strut. Or that the tire may rub on the strut as well. Does anybody have any experience with such a tire? I am hoping I do not have to get coilovers. I am not concerned about the tire rubbing on the fenders (if it does that should be easy to fix)
Thanks.
Gerry
Dragicon is offline   Reply With Quote
Old 10-17-2009, 05:22 PM   #2
mosc
Member#: 177401
2004 STi White
The rim will clear the strut. The tire you choose might not though, that's a different matter.
mosc is offline   Reply With Quote
Old 10-18-2009, 10:45 AM   #3
Dragicon
Member#: 112323
Thanks for the response. Do you have any idea what tire would fit?
Old 10-18-2009, 10:56 AM   #4
Spun Autosports
Member#: 104686
1999 Outback Sport
www.Spun-Autosports.com
If it does not clear you can always get some 3 mil spacers if its close. You should be fine on the rim pending the offset. 38mm-35mm offset should be fine with 255 or 265 tires again depending on what brand.
Spun Autosports is offline   Reply With Quote
Old 10-18-2009, 11:04 AM   #5
Dragicon
Member#: 112323
Thank you for the response.
Old 10-18-2009, 10:15 PM   #6
Badler
Member#: 133597
You are going to need serious fender work to fit those. Especially with 265s.
Badler is online now   Reply With Quote
Old 10-19-2009, 01:45 AM   #7
mosc
Member#: 177401
2004 STi White
Stick with 255/35/18. That should clear the strut. You're still going to need fender work. I don't think 265/35/18 will clear the strut. It's taller too which won't help things.
will it fit on a 2.5 rs vendetta Normally Aspirated Powertrain 2 02-20-2008 10:47 AM
18x8.5 51 offset SSR COMP..will it fit on an 05 WRX? DieselClown Tire & Wheel 2 04-11-2007 06:30 PM
stock STI exhaust; will it fit on ALL wrxs? oilybirdy Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 2 01-02-2006 10:47 PM
17x8.5 rims. Will it fit the wagon? Boosted Wagon Brakes, Steering & Suspension 13 05-14-2002 03:16 PM
version 5 wing, will it fit wrx? WRxednEffect Interior & Exterior Modification 2 03-25-2002 04:40 AM
