Old 10-17-2009, 06:13 PM   #1
kmook
Member#: 146168
2002 Black WRX
Default Help with subframe lockdown bolt install
Hello,
I'm in the middle of this install and of course having issues getting the bolts started. I've read in other threads about adjusting the subframe after loosening the 4 bolts with a crowbar or such, but my question is where to you put/position the crowbar to adjust the subframe?
Thanks!
kmook is offline   Reply With Quote
Old 10-17-2009, 06:27 PM   #2
skimobile
Member#: 92114
03 WRX Bugeye
2.61L Hybrid Track Toy
You just losen the 2 bolts on either side of the subframe, spray PB Blaster into the hole that the lockdown bolts will thread into, the hole alignment shouldn't be too far off.
Clean the threads with a Q-tip soaked with more PB BLaster and try installing the lockdown bolts 1st without the unethane/poly sleeves on them, you may have to work them in an out several times while cleaning the threads.
After years of nothing in those holes there's probably lots of rust, road grime, etc up in there.
More info here....
http://www.scoobymods.com/kartboy_su...lts-t9236.html
skimobile is offline   Reply With Quote
Old 10-17-2009, 08:28 PM   #3
kmook
Member#: 146168
2002 Black WRX
I'm going to try the q-tip and a small wire brush tomorrow to get the threads clean in the bolt holes.
Unfortunately I'm useing the whiteline kit not the kartboy so the sleeves dont come off.
The holes look pretty much lined up but i just didnt see where to try adjusting the subframe with a bar...
Old 10-17-2009, 08:37 PM   #4
jamal
Member#: 71875
98 2.5GT
my wheels fit
I put a wire pipe cleaning brush in a drill. That got the threads super clean. And you want to use a crapload of anti-seize.
I can't tell you exactly where to pry. I'm pretty sure it took a bunch of prying and hammering in different spots.
jamal is offline   Reply With Quote
Old 10-17-2009, 08:46 PM   #5
drifterx
Member#: 25128
1983 911sc
Matte Mexico Blue :)
i never prybar'd anything on any of my installs (4 sets installed so far). ive always done it the scoobymod way and dropped the 4 bolts about a half inch down or so and then put the whitlines in place and torqued to spec then did the factory bolts.
drifterx is offline   Reply With Quote
Old 10-17-2009, 08:48 PM   #6
kmook
Member#: 146168
2002 Black WRX
I'm curious if you dont need to adjust the subframe what is the purpose of loosening the 4 factory bolts?
Old 10-17-2009, 08:53 PM   #7
drifterx
Member#: 25128
1983 911sc
you know in all honesty i dont know why. maybe to make sure that they sit correctly, since the factory ones dont lock it (the rear diff) down 100% there is a little bit of wiggle room for the rear subframe to shift one way or another possibly (i dunno so please correct me if im wrong).
Old 10-18-2009, 07:50 AM   #8
wrxracer519
Member#: 149890
02 WRX 11 WRX
that is correct. I have spent about 2 hrs cleaning the holes in my 02 to get them in. The amount of crap that was up there was nasty, and wear some goggles or something to crap doesn't fall in your eyes.
wrxracer519 is offline   Reply With Quote
Old 10-18-2009, 12:21 PM   #9
boost junkie
Top Scoob 009
Member#: 68273
2012 WRX
GD Race Car in progress
The threads on mine were nasty, no amount of cleaning would make the bolts thread in smoothly. I ended up chasing the threads with a tap, then cleaning them and using anti-sieze and the bolts went right in.
boost junkie is offline   Reply With Quote
Old 10-18-2009, 12:39 PM   #10
kmook
Member#: 146168
2002 Black WRX
I got them in this morning. The pass side just needed a lot of cleaning as said. I had to use a tap/rethreader to get the drivers side in though.
Thanks for the help!
Old 10-18-2009, 09:22 PM   #11
romanlynch
Member#: 126684
02 wrx
PLATINUM silver baby
not everyones subframe perfectly lines up. when i installed mine i had to shift the subframe 1/4" or so to line it up.
romanlynch is offline   Reply With Quote
Old 10-19-2009, 12:03 AM   #12
todeswalzer
Member#: 191495
'05 WRB GTX3071R
JDM V8 EJ207 USDM 6MT
i have the whiteline ones.
took about 5 minutes to line each one up but after that it was a breeze, i never cleaned the threads or anything and my car has 58k on the clock in new england
i torqued to spec and snapped one of em.....while its still in there and has held in place for about 6 months now i dont know what to do when/if i ever want to take them out
so becareful
todeswalzer is offline   Reply With Quote
How to Fix Subframe Lock Bolts Install Disaster? williaty Brakes, Steering & Suspension 15 11-16-2007 10:31 PM
Whitline Subframe Locking Bolts Install Question Lo0mis Transmission (AT/MT) & Driveline 7 02-13-2003 04:34 PM
Does anyone want to help with uppipe or spring install? Also need install suggestions rex n effect Mid Atlantic Impreza Club -- MAIC 4 10-03-2002 01:54 AM
help with rear camber bolts needed datdudedennis Brakes, Steering & Suspension 6 05-22-2002 01:39 PM
Help with strut top bolt removal MrZone Brakes, Steering & Suspension 2 05-06-2002 11:25 AM
Message Board Statistics All times are GMT -4. The time now is 03:31 PM.
