Old 10-18-2009, 04:14 PM   #1
haro15
Member#: 109135
2004 subaru wrx sti
NOT FACTORY
Default 04 sti with rota g force 18x9 +35???
i have a o4 sti with tein super sport coilover's i just purchased rota g force 18x9 with a 35 offset. i rolled the rear quarters and put the new wheels on. i have not drove the car yet but im questioning are these going to fit UNDER my quarter panels they look to wide and stick out past the sheet metal about 1/4 inch or less. can anyone help? thanks
haro15 is offline   Reply With Quote
Old 10-18-2009, 04:20 PM   #2
wantsti
Member#: 134764
04 sti
java black pearl
You need more camber or a fender pull. What size tire you running?
wantsti is offline   Reply With Quote
Old 10-19-2009, 02:18 AM   #3
bObby
Member#: 66959
04 STi and E46
M3
Sell the G forces to me.
bObby is offline   Reply With Quote
Old 10-19-2009, 12:35 PM   #4
just Touge
Member#: 220530
2006 Impreza WRX
Crystal Grey Metallic
they will rub in the rear, about -2 camber should help. I have the same wheels with 255 tires. I have Stances that are pretty stiff so that helps too.
just Touge is offline   Reply With Quote
Old 10-19-2009, 04:25 PM   #5
nhat
Member#: 140163
03 STi
hellaflunctional
none of our advice matters since none of us know what tire size you plan on running.
Old 10-19-2009, 04:41 PM   #6
haro15
Member#: 109135
2004 subaru wrx sti
NOT FACTORY
I Have 235/40/18 Thats What I Was Told To Run
Old 10-19-2009, 04:44 PM   #7
haro15
Member#: 109135
2004 subaru wrx sti
NOT FACTORY
I Think I Will Sell If The Prive Is Right They Have Advan Tires And Advan Tire Valves. Taking Offers
Old 10-19-2009, 04:44 PM   #8
mosc
Member#: 177401
2015 STi White
Your diagnosis is correct. They will stick out. That's why people pull out their fenders.
mosc is offline   Reply With Quote
Old 10-19-2009, 05:10 PM   #9
haro15
Member#: 109135
2004 subaru wrx sti
NOT FACTORY
do you know what that cost to have done?
Old 10-19-2009, 06:17 PM   #10
nhat
Member#: 140163
03 STi
hellaflunctional
call around your local shops for a quote on rolling/pulling the rear fenders. 18x9 +35 with 235s is easy to fit without rubbing.
Old 10-19-2009, 10:13 PM   #11
mosc
Member#: 177401
2015 STi White
Many shops won't touch your fenders. They don't want to be liable for cracked paint which is common from fender rolling. I suggest doing it yourself if you're serious.
Old 10-20-2009, 01:33 PM   #12
JDM_OBP
Member#: 105409
'05 HTA68'd WRX
327/310
heat gun and a bat will do just fine. just make sure to use alot of heat and go slow
JDM_OBP is offline   Reply With Quote
Old 10-20-2009, 08:30 PM   #13
haro15
Member#: 109135
2004 subaru wrx sti
NOT FACTORY
i have the fender roller but the rim itself sticks out past the quarter panel???
Old 10-20-2009, 11:45 PM   #14
JDM_OBP
Member#: 105409
'05 HTA68'd WRX
327/310
rolling the fenders doesn't stop it from rubbing with a +35, you're gonna need to dial in some camber to fit those without rubbing.
Old 10-21-2009, 09:28 AM   #15
Ruthless671
Member#: 150300
Chapter/Region: HIIC
2006 STi
I fit those on my wagon with rolled rear fenders, lower camber bolts and Cusco coils w/camber plates. I was running 225/40/18's though. On a sedan with 235's or 245's you should have no problem. GL
Ruthless671 is offline   Reply With Quote
Old 10-21-2009, 09:59 AM   #16
nhat
Member#: 140163
03 STi
hellaflunctional
did you not know that an 18x9 +35 was going to be that far outside the fender?? did you do any research before buying? YOU bought the wheels, DEAL with it...you have 2 options:
1. sell or return the wheels
2. stop moaning and do what it takes to get them to fit
Old 10-23-2009, 03:52 PM   #17
gregr01
Member#: 49333
04 STi
java pearl black
265/35/18 on Rota 18x9 +35, '04 STi
Wheels/tires do not stick out past the fenders--they're actually a bit inside the fenderline.
Front and rear fenders rolled.
Front and rear fenders pulled (though not an outrageous amount).
Ride height set for competition, not street (not interested in low, just go).
9k front/7k rear springs (Zero 2Rs).
No rubbing front or rear, street, track or autox.
gregr01 is offline   Reply With Quote
Will Rota G-force 18x9 +35 or Rota Torque 18x9.5 +35 fit on my 03 wrx? simon930 Tire & Wheel 9 04-27-2011 11:20 AM
f/s SoCal rota g forces 18x9 +35 5x100 with tires get HELLAFLUSH!!! team trucha racing Wheels/Tires 13 03-09-2009 02:20 AM
WTT: New/Painted (not rattle can'd) ROTA G-FORCE 18x9+35 with NEW FedRSR 245/35/18 JeffrWRX Wheels/Tires 12 01-15-2009 12:29 AM
WTT: gold rota g-forces 18x9 35 5x100 thinkofone28 SCIC Private Classifieds 21 08-17-2008 12:14 PM
FS VA : Brand New Rota G-Force 18x9 +35 GOLD kcook MAIC Private Classifieds 11 07-11-2008 08:02 AM
