Old 10-18-2009, 10:15 PM   #1
turbo01gc8
Member#: 217973
2001 turbo impreza L
acadia green
Question 2.2L sohc help
was reading a thread on the HIGH COMPRESSION FRANKENSTEIN and had some ?'s. i got an 01 impreza w/ 2.2 sohc. i was wondering how i could find out what my engine specs are b/c i just installed a turbo kit (about 5-8 psi depending on the WG adjustment). don't know if my stock block and heads can handle it (163K). was thinking about some 2.5 sohc heads for better flow and the dual port exhaust to install a better flowing header and possibly lowering the compression ratio w/ some forged pistons but they are pretty expensive. like $140 each from weisco. and also wondering about rrfpr's. i have a fpr that came with my kit but not sure if it's working properly b/c when i get on it, it seems to have some dead spots then is fine. i cannot control timing with the EM but have 2 extra injectors to add more fuel across the rpm band and boost range. also my boost guage fluctuates at times when i'm cruising at part throttle. any ideas on why this might happen? any info is helpful. thanks
turbo01gc8 is offline   Reply With Quote
Old 10-21-2009, 05:18 PM   #2
benham84GL
Member#: 174081
Default 2.2L options
I'm put a 1999 2.2L N/A in my 1985 GL wagon. Now that I've got it running properly I was looking into turbo options and was told that:
1) The open-deck block is only good for ~5-6 psi
2) The non-forged internals are good for ~300 hp.
benham84GL is offline   Reply With Quote
Old 10-21-2009, 05:19 PM   #3
benham84GL
Member#: 174081
I do know that the stock 2.2L phase 2 compression is 10:1.
Old 10-22-2009, 02:58 AM   #4
legacydreamz
Member#: 92423
2007 Honda CRV
and dolphins and s**t
soo, where did you "hear" that from?
legacydreamz is offline   Reply With Quote
Old 10-22-2009, 05:27 PM   #5
Abest10
Member#: 190962
00 STM RS
04 FXT
That is a load of crap. I myself have hit and held 15 psi on my ej22e open deck block for over 4 months with no knock or anything. Sure closed deck would be better for high boost but is not nessecary. Hell a na 2.5(ej251, ej25D) open deck can handle 5-6psi. The 1.8 and 2.2 decks are a budget boost block that can handle some boost.
Abest10 is offline   Reply With Quote
Old 10-22-2009, 08:53 PM   #6
mikebdubsuby
Member#: 209195
2004 Impreza
SRR
Aren't the N/A 2.2's and turbo 2.2's the same bottom end?
mikebdubsuby is offline   Reply With Quote
Old 10-22-2009, 10:42 PM   #7
Abest10
Member#: 190962
00 STM RS
04 FXT
Nope the ej22t's bottom end is a closed deck application and is lower compression, whereas the ej22e has a higher compression ratio and open deck. But overall 2.2's are great for boost.
Old 10-24-2009, 11:56 PM   #8
turbo01gc8
Member#: 217973
acadia green
anyone have info and results for different heads on these things? better flow? parts needed to make swap? how about pistons? do i get just pistons or are rods really necessary too?
does anyone know why it feels like i have a dead spot on take off then is fine? my boost guage fluctuation???
Old 10-26-2009, 05:50 AM   #9
subasurf
Member#: 192883
1995 E36
Red
Have you considered lowering the CR by installing thicker head gaskets?
subasurf is offline   Reply With Quote
Old 11-03-2009, 02:18 AM   #10
turbo01gc8
Member#: 217973
acadia green
how much would that really lower the comp ratio? and is it worth it? time and $$$?
Old 11-03-2009, 02:28 AM   #11
PhilSine
Member#: 130489
02 WRX Wagon (WRB)
98 OBS-T, 91 Legacy SS
Your engine can easily handle 10 psi of boost. I was running a mere 7.5 psi of boost for over a year tuned to 12:1 AFR's and that engine ran great. I'm currently installing it into a 2.5RS where I'll confidently run 10 psi of boost.
Good engine management is the key.
PhilSine is offline   Reply With Quote
Old 11-03-2009, 05:43 PM   #12
turbo01gc8
Member#: 217973
acadia green
it's completely stock with 164k on it. i can hit 4-5psi with no ignition tuning but i am probably running rich as hell cause i got 2 extra injectors i can control. i'm not sure how to program them either across the rpm and boost ranges. i'm looking into the pp6 EM from rallitek and new pistons when i save enough $$$
Old 11-05-2009, 04:18 PM   #13
Portly
Member#: 1197
1997 Impreza Wagon
Mystic Blue Pearl
FWIW, the installation of thicker-than-stock head gaskets will result in the cam timing being slightly different between the 2 banks of cylinders. I really don't know if a couple degrees of difference is that big of a deal, but it seems worth mentioning.
_Jeff
Portly is offline   Reply With Quote
Old 11-05-2009, 04:46 PM   #14
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
Put some DOHC Ej25 heads on there from an 1996-1999 Legacy, Outback or Forester. They will drop your CR to 8.6:1 with stock HG's. They flow about 20% more than your stock heads. They are also already drilled and ready to be tapped for oil and coolant.
Old 11-05-2009, 05:40 PM   #15
turbo01gc8
Member#: 217973
acadia green
wow they drop the CR that much? so if i pick up these heads, what kind of ecu do i need? what else is needed for the swap besides a timing belt, stock HG, and ARP studs? trying for more hp but kinda on a budget. are the 2.5 SOHC heads any better so i don't need an ecu?
what do you mean by drilled and ready to be tapped for oil and coolant? i have my coolant for the turbo tapped into the heater core hoses and my oil tapped from the factory sending unit off the block.
Old 11-05-2009, 05:59 PM   #16
Matt Monson
Member#: 832
99 2.5RS, '85 911
How is 8.6:1 too low? That's higher than a stock WRX.
You'll want some sort of piggyback, but your stock ECU will run them. Don't waste your money on ARPs. Unless you are making 30psi you don't need them. Just reuse stock bolts.
If you've already got a coolant solution don't worry about it. But if you wanted to, you could copy the factory set up with the fitting coming right out of the head.
Old 11-05-2009, 07:28 PM   #17
turbo01gc8
Member#: 217973
acadia green
i didn't mean that CR was bad it's kinda what i was aiming for so i can safely run a little more boost. by running some sort of piggyback do you mean engine management? so not to ask the same question again, but i got SOHC heads and you are saying the DOHC will bolt right up? all sensors, intake manifold, etc?
WTB: EJ22 2.2L SOHC single port ac30treb Private 'Wanted' Classifieds 1 12-17-2011 07:22 PM
2.2l SOHC Timing belt covers stirex Private 'Wanted' Classifieds 3 09-12-2006 01:16 PM
2.5 injectors in a 2.2l SOHC OBS? cams for 2.2l? kaisersouse Normally Aspirated Powertrain 3 04-02-2006 10:10 PM
Turbo Legacy project - 2.2L SOHC heads, EJ257 shortblock, WRX turbo, S-AFC jey Normally Aspirated with bolt-on Forced Induction Powertrain 10 01-19-2005 06:46 PM
FS..Honda F22A1 2.2l SOHC phantom North West Impreza Club Forum -- NWIC 0 06-28-2002 04:53 PM
