Go Back   NASIOC > NASIOC General > Motorsports > Autocross
Old 10-19-2009, 12:07 AM   #1
waktasz
Member#: 86356
2015 s1000r
wheelie monster
Default Cold weather autocross - Tire pressure up or down?
Using Hoosier a6...in general, if the temps are going to be 40 or 50 degrees or less, should I aim to go higher or lower than normal on air pressure, or stay the same?
waktasz is offline   Reply With Quote
Old 10-19-2009, 07:00 PM   #2
BugeyeBoomer
Member#: 148253
2003 Subaru
since your checking your pressure while its colder the tires will be lower than when heated up. Id say stay the same but if your really concerned about reaching the max on the tire, then lower it a few psi, not much though. IMO
BugeyeBoomer is offline   Reply With Quote
Old 10-20-2009, 10:15 PM   #3
waktasz
Member#: 86356
2015 s1000r
wheelie monster
I have no idea what you are saying.
I'm asking should I start lower, which might allow the rubber to warm up faster because of tire flex, or go higher to start, since I might not really gain much pressure in such cold temps on a short course.
Old 10-21-2009, 07:10 AM   #4
KC
Member#: 442
16 SS
00 S2000
---kC
KC is offline   Reply With Quote
Old 10-21-2009, 07:36 AM   #5
Mechie3
Member#: 120152
I found in a 50 deg AX that lowering the rear tires made them barely heat up while the fronts heated up nicely. Made for some interesting drifts around the half circle turn arounds when the fronts grabbed and the rears wanted nothing to do with it.
Mechie3 is offline   Reply With Quote
Old 10-21-2009, 12:32 PM   #6
nhat
Member#: 140163
03 STi
hellaflunctional
what kc said, i'd start higher because you're not going to be able to get much heat in the tires anyways.
Old 10-22-2009, 10:52 PM   #7
ljaviation
Member#: 42270
2003 A&P IA
ww.flyingleafaviation.com
^^^ what he said.
On a colder track, I oticed my tires didn't heat up to optimum pressure for grip. I actually upped my pressure 3 psi on my 032's last weekend.
L J
ljaviation is offline   Reply With Quote
Old 10-26-2009, 04:25 PM   #8
Back Road Runner
Member#: 60082
2004 Forester STI
It's tough in cold weather. You might almost be better off tossing on some all-seasons some times. If it's 40F out, my winter tires(LM-25) have as much grip as my summers(RE01R) do on asphalt, maybe even more. ...and I wish I could say I was joking about that, but I actually think it's true from the few times I've run my summers in colder weather on the same roads.
I do agree with KC. I don't think it'll really matter, and you might just stick to higher just to maintain responsiveness.
Old 10-26-2009, 04:30 PM   #9
waktasz
Member#: 86356
2015 s1000r
wheelie monster
ugh. Weather was ok, but the sealed asphalt + 150 run Hoosiers + super tight course made me grumpy.
Old 10-26-2009, 08:29 PM   #10
Back Road Runner
Member#: 60082
2004 Forester STI
Any auto-x is better then no auto-x.
Old 10-26-2009, 08:32 PM   #11
waktasz
Member#: 86356
2015 s1000r
wheelie monster
Brum brum
Old 10-27-2009, 07:10 AM   #12
KC
Member#: 442
16 SS
00 S2000
Hoosier Dirt Stockers on that bad bird?
Old 10-27-2009, 09:37 AM   #13
CamaroFS34
Member#: 6850
1996 Camaro Z28 1LE
& 2006 IAG WRX (ForSale!)
I generally go down a few psi, on the idea that the colder temps are going to make it harder to get any bite off the line and coming out of turns. Therefore, a slightly lower pressure will allow slightly more sidewall give.
That's the reasoning, at least. I have had good success both with the Subaru and the Camaro doing so.
CamaroFS34 is offline   Reply With Quote
boost up or down in the cold winter? gungaslow General Community 109 03-23-2010 07:58 PM
Cold weather TGV delete start up sense of nature Mid West Subaru Owners Club Forum -- MWSOC 3 12-23-2007 03:43 PM
Rear tire pressure up or down to increase oversteer? boxerT Brakes, Steering & Suspension 10 07-02-2004 01:49 PM
Autocross tire pressures F&R? yebokmj Brakes, Steering & Suspension 3 06-16-2001 12:03 AM
Attn: Autocrossers - Tire Pressure Calculator Opie Motorsports 10 04-04-2001 07:45 AM
