Welcome to the North American Subaru Impreza Owners Club Sunday July 31, 2016
Old 05-13-2002, 12:35 AM   #1
yebokmj
Member#: 2213
1995 Impreza w/EJ255
Brilliant Red
Default Which to go with?
I know this is not the place for a clutch question but I think this is were the best people to answer it are. ARG said he is running a Cutchmasters stage I 255 hp @ 8 PSI supercharged. I was thinking of a Stage II. I felt that the stage III was to exstreme for my goals. But based on ARG I might be fine with Stage I. My project car is going to be a 2.2L I am going to be running the Legacy turbo and I don't plan on exceding 9psi do to the price restraints of exceeding such levels. What is the proper clutch for such a setup?
yebokmj is offline   Reply With Quote
Old 05-13-2002, 12:49 AM   #2
GregUnd
Baaleted
Member#: 11800
What do you mean a 2.2L in an RS? Are you putting a bored out WRX motor in it? Or are the legacy motors also 2.2L, don't know crap about anything but the WRX and RS, no legacy's and stuff.
GregUnd is offline   Reply With Quote
Old 05-13-2002, 12:52 AM   #3
yebokmj
Member#: 2213
Brilliant Red
Default 2.2L Impreza
I am doing up an Impreza L which is a 2.2L NA off the top my head stock it's 137hp and 145 torque for my model year engine.
Joshua
Old 05-13-2002, 01:11 AM   #4
GregUnd
Baaleted
Member#: 11800
Hmmmm...... never heard of an Impreza L. But since its N/A from the start then I would say 9psi maybe a little too much without better pistons and heads. I would try 5 or 6 psi until then. The stage one clutch will do fine. Even 9psi probably wouldn't get you to 255HP but it might. Also keep in mind about your tranny.... are you auto or manual?
Old 05-13-2002, 01:34 AM   #5
Marcin
Member#: 2874
2005 CGM WRX WGN
Jorge Tunned BattleWagon
Actually I think 9psi should get you enough to smoke some REXes out there. Also with 2.2L engine you already have a lower compresion than you would on a 2.5L.
My best advice would be, get the stage 1 cluch. You want to be the clutch to be a weak link not the tranny.
Marcin is offline   Reply With Quote
Old 05-13-2002, 01:59 AM   #6
GregUnd
Baaleted
Member#: 11800
Yeah, 9psi would get you up there with stock and close to stock wrx's BUT, your engine would not last long at 9psi. THose heads and pistions are not even really meant for a turbo. 5-7psi would be what I would run. I wouldn't go above 5.5psi for a daily driving
vehical. At 9psi and high RPM's I honestly believe that all you would do is detonate and eventualy blow her up. About the clutch, I agree totaly, just like i said before. You want a little slip in the clutch, just to take some of the abuse off of the tranny. I wouldn't get any more than the stage one clutch, you won't need it. If you pushing so much HP that your stage one just doesn't grab, then you should consider new clutch and gear sets, but thats a long ways down the road and don't worry about that now. Would you consider going with a different turbo? A better and more efficent turbo will allow you to run higher levels of boost safer. I would really think about the stock WRX turbo.... you can get'em used for like $200-$300 with low mileage.
Old 05-13-2002, 03:06 AM   #7
Charge
Member#: 3313
Greg, I don't think you understand what he's saying. He's NOT turbo'ing an EJ25. It'll be an EJ22(can't remember the letter for this model, g or t?). I'm assumimg you're getting one of the turbo legacy blocks? I'm not sure how different they are from the NA EJ22's, but I don't recall people really using them much, especially when those 2.2's can be purchased so cheap, even new.
If he's referring to the EJ22 turbo, he'll have no problems running it at those parameters. A number have done it. You face similar fuel issues, to the EJ25, but everything else is a little easier to deal with, it seems.
Neil
Charge is offline   Reply With Quote
Old 05-13-2002, 11:24 AM   #8
yebokmj
Member#: 2213
Brilliant Red
Default Help!
Guys most of you are missing the boat. Greg, the car is a Manual that's why I am asking about a clutch. The block I am going to do is a 2.2 NA block as metioned above. I know 9psi pushing it but like I said that's the tops I would run. Wac is running that on the same engine and I believe with about 200 hp and torque at the crank. So the general thought is stage one?
Joshua
Old 05-13-2002, 11:39 AM   #9
Ethan
Member#: 246
whats the price difference? if its not much just go for stage 2, and then if you ever decied to go for more power you clutch is already ready to handle it.
Ethan is offline   Reply With Quote
Old 05-13-2002, 11:44 AM   #10
Really_Soaked
Member#: 4992
2000 Impreza 2.5 RS
Blue Ridge Pearl
So, without debating the existance of the Impreza L...
Has anyone ever compiled a list of clutches available to us with tq ratings?
Really_Soaked is offline   Reply With Quote
Old 05-13-2002, 12:32 PM   #11
yebokmj
Member#: 2213
Brilliant Red
After more research on the subject it appears the only differance between Stage I and Stage II is that Stage II is Extra long life street system other than that they both have same holding power.
Joshua
I'm going to start suspension upgrades...Which manufacturer to go with? wrx182 Brakes, Steering & Suspension 31 10-31-2012 08:51 PM
Want to upgrade buffer, which one to go with? stirob Car Care & Detailing 24 04-09-2010 11:06 AM
Falken or BFG' tires...which to go with in the high country? rcostia South West Impreza Club Forum -- SWIC 3 12-19-2007 05:31 PM
Help me to decide which brakes to go with vicdeng Brakes, Steering & Suspension 22 02-07-2007 08:37 AM
upgraded t04 or vf22 ???which to go with Imprezzed22 Mid West Subaru Owners Club Forum -- MWSOC 9 06-19-2003 09:26 PM
