Old 04-12-2001, 05:25 AM   #1
Briggs
Member#: 1417
Post Lessening power stearing
Hello, I'm looking for a way to lessen the effect of power stearing. I have a friend that drained the fluid from his Jetta, and removed the pump, but i've heard that is very hard on the rack. After driving his car, i fell in love with the connected feeling it had, but i don't want to lose the tighter ratio by putting in a manual rack. I was wondering if using a more compressable fluid would help? For that matter are there any real down sides to simplly draining the original fluid? Anyway, thanks for the help.
Oh, by the way, i drive a NEON. Sorry if this is inapropriate.
Briggs is offline   Reply With Quote
Old 04-12-2001, 05:44 AM   #2
tmat3
Member#: 2817
2001 Impreza 2.5RS
BRP
Post
You can't just drain the fluid. It will blow up the pump. The best bet is to do what your friend did; drain fluid and take the pump away.
Or, how about this? Is there a power steering belt? I mean, is the belt attached only to the power steering pump? For example, a 92 Mitsubishi Mirage has a belt which only drives the power steering pump. If so, get rid of the belt. That will give you an instant non-power steering vehicle.
tmat3 is offline   Reply With Quote
Old 04-12-2001, 05:45 AM   #3
tmat3
Member#: 2817
2001 Impreza 2.5RS
BRP
Post
And you shouldn't post the same stuff twice with 2 different titles.
Old 04-12-2001, 05:39 PM   #4
Briggs
Member#: 1417
Post
I'm sorry about the double post, but i didn't think the first one sent, and i couldn't find it when i went looking for it, but i guess it hadn't yet refreshed, so i made a new one.
Before low power, now, no start.. POSSIBLY SOLVED cronus1987 Normally Aspirated Powertrain 15 06-01-2010 07:29 PM
Power stearing question darkcrave Factory 2.0L Turbo Powertrain 4 04-09-2009 04:46 AM
MAJOR problem on my 02 WRX - Power Stearing and Alt nick robinson Factory 2.0L Turbo Powertrain 8 01-08-2007 08:52 PM
power stearing leak... p0171 ?? TopKatz Factory 2.0L Turbo Powertrain 15 09-25-2005 09:50 PM
Power stearing leak... dangerous? TopKatz Brakes, Steering & Suspension 5 08-10-2005 07:44 PM
Message Board Statistics All times are GMT -4. The time now is 09:26 PM.
