Welcome to the North American Subaru Impreza Owners Club Monday February 8, 2016
Old 10-20-2009, 02:18 PM   #1
DuCash
Member#: 198714
04' JDM STi EJ207
437whp/357wtrq Dom3 24psi
Default Sreet Tune, Dyno Results: JDM STi EJ207 Blouch Dom3, dyno video too
NOT MY CAR...but he's a Good Friends...
Pic of the Machine:
Event:
Street tuned and went to the dyno right after
Ambient Temp: hot as hell, it's the tropics
Elevation: 500ft
Weather: sunny
Car: 05' JDM STi Stock EJ207
Tuner:Ian Galibreth aka Swiffy
Dyno Info: Dyno Jet
Peak HP at RPM: 447whp @ 6,500 rpm
Peak Torque at RPM: 367wtrq @ 4,900 rpm
Baseline hp/tq for a stock on same dyno: 230whp
Target Boost: 26 psi
Target AFR: 10.9-11.2
Fuel: 90 Oct w/ 100% Meth
Engine/Power Modifications: mods:
FMIC
CAI
exhaust
bigger inectors
walbro fuel pump
electronic boost controller
stock block
stock pistons
stock rods
stock cams
blouch dom 3 2.4" inlet, 8cm hotside
swif tune
Driveline Modifications: STOCK
Suspension Modifications: STOCK
Other Modifications: NONE
While on the dyno the MAF sensor maxed out so it started to dump fuel. From 6,500 up the AFR's went from 11.0 to 10.0...
We would like to think there's more power left in the same tune, but until we make a bigger intake for the car we can't find out...
The signal cable was having some issues also so the trq didn't start to read right until 54mph...i just connected the low points just for reference
Video of the Machine:
Dyno Graph:
DuCash is offline   Reply With Quote
Old 10-20-2009, 02:28 PM   #2
Thran
Member#: 63612
2004 dom 2.5 wrx
Rally Blue
dude, i am soo going to get a dom 3 on my built ej207 now : P
how far did they go for redline???
Thran is offline   Reply With Quote
Old 10-20-2009, 03:20 PM   #3
Slimsti
Member#: 155696
2007 BLK STI Dom3XTR
415/405 Precision Tuning
nice numbers man i really like the the power the dom 3's put out, while maintaining good spool and daily driveability.
Slimsti is offline   Reply With Quote
Old 10-20-2009, 03:27 PM   #4
godforbid67
Member#: 137168
06 Built SGM WRX
35r, PPG, 280's, PSS9.
Where is all the torque?
godforbid67 is offline   Reply With Quote
Old 10-20-2009, 03:29 PM   #5
subaruNV
Member#: 154549
2006 DOM 3 Powered
WHITE/ EQ Tuned 350Whp
^^^^ej20..not much of a torque engine compaired to the 25
subaruNV is offline   Reply With Quote
Old 10-20-2009, 06:56 PM   #6
Phatron
Member#: 36033
CEO PhatBottiTuning
2006 STi GTX3582 + Meth
pass the dutchie to da left hand side
that power drop is pretty bad.
any boost or AFR plots?
And you can get around the maxed MAF going rich by leaning it out.......i mean if you're running 10.9 before that......take it out to 11.3-11.5 and then you'll only drop to 10.5 at redline.
Old 10-20-2009, 11:25 PM   #7
DuCash
Member#: 198714
04' JDM STi EJ207
7,800 rpm...
good turbo's...
I passed it but you weren't there...
The drop off towards redline is real bad, and sorry there no boost or afr plots...the drop-off is directly related the MAF maxing out and the ecu dumping fuel...
We can lean it out but don't forget one thing in Jamaica the highest Octane fuel is 90 Oct, we call it "piss water"...but it's what we have to work with...
Old 10-21-2009, 12:34 AM   #8
godforbid67
Member#: 137168
06 Built SGM WRX
Indeed, I just realized that. Nice numbers!
Old 10-21-2009, 02:02 PM   #9
dug-e-fresh
Member#: 4568
10.7 @ 136, '02 WRX
13.4 @ 103, '09 spec.B
Gotta love the EJ207... always warms my heart to see it not forgotten
def
dug-e-fresh is offline   Reply With Quote
Old 10-21-2009, 03:03 PM   #10
GARFIELD
Member#: 78516
2003 WRX
Rally Blue
Thanks for posting up the figures and the vid Ducash. Yeah, the fall off in power up top is due to the MAF maxing out and the ECU flooding the engine with fuel. Since then, my tuner has scaled the MAF and it hasn't been maxing out on the street, so I intend to put it back on the dyno to see what the curve is really like up top as well as to get a clean torque curve.
360-370 lb/ft of torque is about what you would expect from a Dom 3 at 26 psi on a EJ207.
GARFIELD is offline   Reply With Quote
Old 10-21-2009, 04:41 PM   #11
swiffy
Member#: 214656
hey ducash i found a way to get the rpm read out on the dyno chart. i did a little calculation and found that in 4th gear every 13.333 mph gives us 1000rpm. so i started from 40mph which is 3000rpm and just did my maths from there. so with a little fine tuning on microsoft paint, i got us an rpm readout. voila!!!
we have atleast another 50whp to get after 7000rpm when we get the MAF CEL fix, maybe even 500whp on the fully stock motor and 32psi, what do you say garfield??
swiffy is offline   Reply With Quote
Old 10-21-2009, 05:15 PM   #12
GARFIELD
Member#: 78516
2003 WRX
Rally Blue
As long as it's on race gas I'm cool with that . For now, I'm happy with my 447 whp .
Old 10-21-2009, 05:18 PM   #13
V6TurboTA
Member#: 9090
09 Forester Gump
02WRX->04STi->09Gump
sTreet.... sWeet?
V6TurboTA is offline   Reply With Quote
Old 10-22-2009, 02:03 PM   #14
pooster.online
Member#: 120461
2004 WRX STi JBP
just out of curiousity, what kind of headers are you running on this car?
JDM twinscroll headers to a Dom 3? did you have a special 2-1 uppipe also 1.5 scroll fabricated?
pooster.online is offline   Reply With Quote
Old 10-22-2009, 02:33 PM   #15
Beetspeed
Member#: 166264
1974 VW 2.2ltr 7670
402 WHP @ 30psi
Thumbs up
Very well done!!
Nice sounding video as well. And all that on a 2 liter engine!!
Beetspeed is offline   Reply With Quote
Old 10-22-2009, 02:39 PM   #16
GARFIELD
Member#: 78516
2003 WRX
Rally Blue
GT Spec unequal length headers.
Old 10-22-2009, 02:46 PM   #17
GARFIELD
Member#: 78516
2003 WRX
Rally Blue
Thanks. Swiffy (my tuner) has done some fantastic things with Subarus here in Jamaica. Here is a link to some of his work on our local Subaru Owners Club website:
http://www.socojforum.org/forum/inde...pic,393.0.html
Old 10-22-2009, 04:41 PM   #18
paul_p1
Member#: 77372
2005 Spec C
WR Blue
I thought maxing out the MAF meant a lean condition as the ECU can't meter the excess air?
paul_p1 is offline   Reply With Quote
Old 10-22-2009, 05:18 PM   #19
Phatron
Member#: 36033
CEO PhatBottiTuning
^^ interesting. i never really thought about that....
But my HTA Green'd WRX max'd out the MAF and i went wayyyy rich too....down to 9.5:1 with 11.5:1 targets.....
But both this car and my car are running meth.....maybe that has something to do with it
Old 10-22-2009, 05:27 PM   #20
GARFIELD
Member#: 78516
2003 WRX
Rally Blue
Prior to putting the car on the dyno, I had no idea what effect maxing out the MAF would have on the car. But while the car was on the dyno, I watched my wideband (I'm the bald-headed person in the vid), and as soon as the CEL came on the ratios went from 11.1 -11.2 to 9's.
Old 10-22-2009, 05:40 PM   #21
paul_p1
Member#: 77372
2005 Spec C
WR Blue
I don't disbeleive it, it's just the opposite of how I thought it would be. I.e. if it maxes at 400g/s and it's really getting 420,430 etc then the ECU won't know how much additional fuel to inject, causing it to go lean.
Old 10-22-2009, 05:43 PM   #22
Phatron
Member#: 36033
CEO PhatBottiTuning
well, if the CEL came on and you went into limp mode....then you switched to the failsafe fueling map.....which is very rich, unless you changed it.
Old 10-22-2009, 06:49 PM   #23
dug-e-fresh
Member#: 4568
10.7 @ 136, '02 WRX
When the ecu "realizes" it doesn't know what is going on, it plays it safe and dumps fuel... normal response.
def
Old 10-23-2009, 10:17 AM   #24
DuCash
Member#: 198714
04' JDM STi EJ207
def
Because we get mostly JDM cars here, there's more 2.0L STi's than 2.5L...We've got a couple more cars that should have some good results...so there's more to come...
No prob, Bro...
There's someone here who has custom made a 2-1 uppipe so they could keep the twin-scroll headers...
Every JDM Sti since 04' comes with the twin-scroll set-up, i got 360+ wft/lbs by 4,500rpm on a 2.0L with the stock set-up...
def
Thats why we think there's more left in this 26psi tune...
Old 10-23-2009, 11:29 AM   #25
dug-e-fresh
Member#: 4568
10.7 @ 136, '02 WRX
I see your running a VF37, I had a VF36... I miss that turbo.
I should have my 207 back up and running soon. Looking to do better than before... we'll see I guess.
def
05 STI w/ Blouch DOM3.0, FMIC, Catted TBE Equilibrium Tuning Proven Power Bragging 77 10-28-2008 07:47 PM
Latest dyno results: 145hp, 144ft-lb on Mustang dyno Patrick Olsen Normally Aspirated Powertrain 39 08-27-2008 04:19 AM
fs jdm sti ej207 block and greedy profec 2 bc 02subbysnack Engine/Power/Exhaust 18 05-20-2008 08:30 PM
Perrin pulley a good idea for a JDM STI EJ207? underground-mpyre Subaru Conversions 10 03-26-2006 02:27 PM
FL: ver8 JDM STI EJ207 block! LIQUIDSK8S Private 'For Sale' Classifieds 14 01-25-2006 11:01 AM
