Welcome to the North American Subaru Impreza Owners Club Friday December 2, 2016
Alaskan Impreza Club
Old 10-20-2009, 04:46 PM   #1
06gtleg
Member#: 197928
95 Outback
Green
Default Exhaust question
I have a 3" dp and need something that will connect to my stock cat back. It's not connecting all the way and has an exhaust leak. Or do I need to get a cat back?
06gtleg is offline   Reply With Quote
Old 10-20-2009, 04:48 PM   #2
06gtleg
Member#: 197928
95 Outback
Green
Thanks lol
Old 10-20-2009, 04:51 PM   #3
Kiwi Fella
Modest Mouse
Member#: 27323
2000 RSTi
No worries..
What downpipe do you have?
Kiwi Fella is offline   Reply With Quote
Old 10-20-2009, 05:03 PM   #4
TurboSetch
Member#: 192358
MANY P3 Import Auto
907 355 6655
Some of the turboxs downpipes need an adaptor to connect to stock or other aftermarket systems.
Anything past the downpipe is called "Cat-back" , there is another split before the axle which is know as "Axle-back". And of course the whole system including downpipe would be calle "Turbo-back".
TurboSetch is offline   Reply With Quote
Old 10-20-2009, 05:20 PM   #5
06gtleg
Member#: 197928
95 Outback
Green
I have aklgt's dp. Dale made it
Old 10-20-2009, 05:42 PM   #6
retrac
Member#: 217208
2001 Porsche 911
LSx Twin Turbo
Adapter time.
http://www.rallysportdirect.com/shop...er-p-3911.html
Don't forget to tune for it!
retrac is offline   Reply With Quote
Old 10-20-2009, 05:57 PM   #7
06gtleg
Member#: 197928
95 Outback
Green
Is anyone in town that has this until I get a cat back?
Old 10-20-2009, 06:10 PM   #8
TurboSetch
Member#: 192358
MANY P3 Import Auto
907 355 6655
I have a full 3in catback system. Not sure if it fits a legacy though.
FYI, nothing to tune unless you have boost issues after the swap. Once you have eliminated the cat or rear O2 sensor you need to have those check engine light codes turned off.
Old 10-20-2009, 06:18 PM   #9
retrac
Member#: 217208
2001 Porsche 911
LSx Twin Turbo
Exactly. Kill the codes. Therefore, don't be lazy and tune!
Old 10-20-2009, 06:54 PM   #10
tribalwrx
Member#: 32993
vf39 Best trap 110
Best ET 12.51 Dale tuned
your exhaust turbosetch will not fit a lgt, there model specific
tribalwrx is offline   Reply With Quote
Old 10-20-2009, 07:28 PM   #11
TurboSetch
Member#: 192358
MANY P3 Import Auto
907 355 6655
Figured different bends and what not.
Old 10-20-2009, 08:04 PM   #12
tribalwrx
Member#: 32993
vf39 Best trap 110
well i'm sure with a mig welder anything can be made to fit
Old 10-20-2009, 08:37 PM   #13
06gtleg
Member#: 197928
95 Outback
Green
I heard something about an extender for the sensor on the dp, that it would make that ce disappear? Anyone know about that?
Old 10-20-2009, 08:46 PM   #14
tribalwrx
Member#: 32993
vf39 Best trap 110
rear o2 sensor delete, search it in the forums lots of different ways of doing it
Old 10-20-2009, 08:53 PM   #15
Brando5185
Member#: 189926
2006 GC 5.7L
I have an o2 spacer that was on when i had just a dp. Im not using it right now.
Brando5185 is offline   Reply With Quote
Old 10-20-2009, 09:04 PM   #16
06gtleg
Member#: 197928
95 Outback
Green
can i have it?
Old 10-20-2009, 09:11 PM   #17
Brando5185
Member#: 189926
2006 GC 5.7L
I think i can let you borrow it till you have a catback and a tune. Which then you wont need it. However long that is lol.
Old 10-20-2009, 09:17 PM   #18
06gtleg
Member#: 197928
95 Outback
Green
it shouldnt be that long lol. still didnt recieve my pfd. damnit for not doing it early lol
Old 10-20-2009, 09:18 PM   #19
06gtleg
Member#: 197928
95 Outback
Green
when could i get it?
Old 10-20-2009, 10:36 PM   #20
AKLGT
Member#: 85199
2012 turbo rollersk8
EvolvedAK's hood ornament
all you need is the donut gasket and tighten that bad boy down. that's what I did on the STI before I got the exhaust, no leaks and worked fine.
AKLGT is offline   Reply With Quote
Old 10-21-2009, 02:55 AM   #21
Racer Dubya
some old guy
Member#: 112225
1985 78 HP of Rage!
The snow will rip it apart... moisture.
I speak from experience.
Racer Dubya is offline   Reply With Quote
Old 10-21-2009, 03:13 AM   #22
Mavrik
Member#: 90347
2013 BRZ & Imp 2.5RS
Yamaha FZ8
use a flat flange exhaust gasket with orange gasket sealer. Thats what Dale and I used on Hope's car with that DP. worked just fine and she had no leaks. It also didn't tear apart in the winter. Also don't use your spring bolts to hold it in place. Not enough pressure. use normal bolts.
Mavrik is offline   Reply With Quote
Old 10-21-2009, 04:00 AM   #23
pumpkin head
Member#: 197239
1989 JUSTY!
Just run Open DP
pumpkin head is offline   Reply With Quote
08 STI exhaust on 08 WRX Exhaust Questions J-Rod 555 Newbies & FAQs 6 06-08-2009 04:58 PM
Exhaust Question for a QUIET Exhaust.. The Blue Pilot Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 29 01-20-2008 12:54 AM
Full OBX Exhaust? General exhaust questions. stoney98 Normally Aspirated Powertrain 12 06-18-2007 12:39 PM
Aftermarket exhaust question. The older the exhaust gets, the raspier? 2005wrbluesti Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 4 12-12-2006 11:16 PM
Aftermarket exhaust question. The older the exhaust gets, the raspier? 2005wrbluesti Normally Aspirated with bolt-on Forced Induction Powertrain 0 12-12-2006 04:52 PM
