South West Impreza Club
Go Back   NASIOC > NASIOC Chapters > South West Impreza Club Forum -- SWIC
Old 10-21-2009, 02:16 AM   #1
explosivo
Member#: 175579
2006 WRX TR
Default Perrin Lightweight Pulley Dyno Results
Finally got my lightweight crank pulley in, and took it down to Goodspeed today. I did a few runs on the dyno pre pulley install and layed down the
following:
287.1WHP
318.7 Torque
With the car still strapped down on the dyno, I had goodspeed swap the pulley and do two more runs:
The first run while the engine was cold, showed the following:
297.6 WHP
316.6 Torque
The second run immediately following showed:
296.2 WHP
323.4 Torque
The dyno chart pre and post is pretty awesome. In the lower RPM band, I gained a max of about 8hp and 10 torque. In the higher RPM band, I gained 9HP and 7 torque at peak, but the real gains are after 5k RPMS when my HP/Torque started to fall off, but after the pulley install, my HP was anywhere from 15-18HP higher, and my torque was 15-20 higher on the tail off.
Initial driving impressions are pretty awesome as well. I noticed that it helped with lag between gear shifts, and my overall powerband feels smoother. I would say, this mod is definitely worth 100 bucks.
I have the video, but the damn thing is 75 megs, gotta shrink it down a bit.
http://i159.photobucket.com/albums/t...ypewp/Dyno.png
explosivo is offline   Reply With Quote
Old 10-21-2009, 02:36 AM   #2
bObby
Member#: 66959
04 STi and E46
M3
what are your mods besides the pulley?
bObby is offline   Reply With Quote
Old 10-21-2009, 02:52 AM   #3
kpluiten
Member#: 120273
06 WRBWRXWGN
Now with 100% more Spec-C
Hmmm... maybe I should rip the perrin light weight pulley off my GC and throw it on my wagon...
Old 10-21-2009, 09:42 AM   #4
racingfish
Member#: 60976
1969 LGT
FATURBO
vf39 and sti top mount prob exhaust and intake too.
racingfish is offline   Reply With Quote
Old 10-21-2009, 11:04 AM   #5
fastnoypi
Member#: 6886
MY01 EJ207 HTA35r
AVCS ON!
how much lighter is the Perrin pulley vs stock? Is it underdriven?
fastnoypi is offline   Reply With Quote
Old 10-21-2009, 11:16 AM   #6
The Satch
Member#: 149174
that 's cool. i
have a goldfish.
its not underdriven, i think its 3 pounds lighter, nice piece though, dont clean it with engine solvent or it turns purple.
The Satch is online now   Reply With Quote
Old 10-21-2009, 11:31 AM   #7
blkscooby
Member#: 44422
2009 G8 GT
Cammed, sprayed, stalled
I agree that the pulley makes drivability and throttle response feel better. However a pulley cannot add horsepower per se. What it will do is get your RPM up faster, which gets you to a higher torque sooner, and therefore increases the HP at a given RPM. It cannot add to peak torque or HP. All you are doing in reducing the rotational inertia of the engine's rotating assembly.
So in that regards, this thread is hugely misleading and incorrect.
However, I'm glad you took the time to do before and after dyno plots and that you like the results.
blkscooby is offline   Reply With Quote
Old 10-21-2009, 12:34 PM   #8
kpluiten
Member#: 120273
06 WRBWRXWGN
Mines purple. I thought it came that way?
Also, blkscooby makes a good point.
Old 10-21-2009, 12:41 PM   #9
DSM Nexus
Member#: 196985
2004 EVO VIII
*edit* reading comprehension ftl
DSM Nexus is offline   Reply With Quote
Old 10-21-2009, 01:37 PM   #10
Mechie3
Member#: 120152
It can't make more HP at the crank, but as measured at the wheels, the car has more (usable) power. Thus, in real world applications it "adds" power (since we car about power hitting the ground and propelling a car...not power wasted in burnouts or power to actually turn the engine itself).
Mechie3 is offline   Reply With Quote
Old 10-21-2009, 01:43 PM   #11
explosivo
Member#: 175579
2006 WRX TR
well, I wouldn't say misleading.... it does add HP/Torque by freeing up existing HP previously taken up by rotating a heavier mass. By lowing the inertia, you are able to put more of your already existing horsepower to the wheels, so in a sense it is like adding more HP/Torque. Anyway you want to put it, I saw gains across the board, which makes the car more enjoyable to drive with a little extra power.
Old 10-21-2009, 01:47 PM   #12
explosivo
Member#: 175579
2006 WRX TR
Its actually 4lbs lighter. The stock pulley is 5lbs and the perrin is 1lb. They claim its like removing 100lbs from your car. If anyone is thinking about getting one, stick with the Perrin, Joe at goodspeed said they installed an agency power one and the fitment was poor and it wasn't as well engineered as the Perrin one.
Old 10-21-2009, 01:52 PM   #13
explosivo
Member#: 175579
2006 WRX TR
VF39 / STI top mount
Maddad v2 headers & Up pipe
HKS Downpipe
Greddy Evo2 Exhaust
Perrin Silicon Turbo inlet
Treefrog Tune
Still running the stock airbox, don't think I'm going to change it unless I
go with a new turbo setup.
Old 10-21-2009, 04:21 PM   #14
kpluiten
Member#: 120273
06 WRBWRXWGN
You know what would make some real power? A tune.
EDIT: Missed that. Nevermind.
Old 10-21-2009, 04:26 PM   #15
THE ONE
Member#: 43918
2002 Scooby Wagon
Nice numbers and thanks for the post. I did this mod to my first WRX and honestly didn't feel a difference. Was that because it was a 2003 MY?
THE ONE is offline   Reply With Quote
Old 10-21-2009, 05:36 PM   #16
SaabaruMike
Member#: 113342
2014 WRX
SaabaruMike is offline   Reply With Quote
Old 10-21-2009, 05:43 PM   #17
Poweredbysnail
Member#: 74753
2003 Wrx 2.5Lw/gt30r
Team Snail
Sweet man glad to see the car is running well. Nice gains with the Pulley
Poweredbysnail is offline   Reply With Quote
Old 10-21-2009, 06:12 PM   #18
KP
Member#: 147637
HJ's Ask
Hobbs. He knows.
Did you drive the car all the way to BFE, boosting it whenever you can, then strap it down to the dyno and take your base run. Then let it sit, get it nice and cool, change out the pully, ice the IC, and then do your 2 runs?
KP is offline   Reply With Quote
Old 10-21-2009, 08:39 PM   #19
explosivo
Member#: 175579
2006 WRX TR
I work in Tempe, so its just a drive down the street to goodspeed. Went to goodspeed, they strapped it down and did a few baseline runs to dial in the dyno and set the load/traction and all that stuff. Then let it sit for about 15 minutes, sprayed the intercooler with a little water to cool it down and strapped on the fan.
Did two back to back runs, to get my baseline numbers
Left car on the dyno with the same settings, and swapped out the pulley.
Started the car again to make sure everything was cool with the pulley and
did a mild run. Let it sit for about 10 minutes, sprayed down the intercooler again and did the final 2 runs to get my last set of numbers.
Old 10-21-2009, 09:10 PM   #20
Poweredbysnail
Member#: 74753
Team Snail
Not bad
Old 10-22-2009, 01:19 AM   #21
DerickRyoung
Member#: 178050
02 hybrid-wrx
psm
I have a perrin pulley and I am happy w/ it. My tuner disagreed w/ it and said I shouldve kept a stock one, he said these arent made w/ a harmonic balance? I kept it anyways, but anyone heard of this?
DerickRyoung is offline   Reply With Quote
Old 10-22-2009, 02:30 AM   #22
5.0Ranger
Member#: 93546
08 wrx
pearl white
hes right, but i'm pretty sure that our motors are internal balanced, so untill you get way up in the rpm's you dont really need it. but if you run your motor way up high in the rpm's, i would keep the stock one. i have the perrin one and i like it. it was great fitment and it had the shaved outer lip, for the easer install on the 08 and up strech a/c belt.
5.0Ranger is offline   Reply With Quote
Old 10-23-2009, 02:44 PM   #23
WgnWheel
Member#: 63605
04 Wrx Wgn TimeAtk
10 Golf TDI, 08 Stang GT
yeah these arent great for high rpm running. my s202 motor doesn't have the internal balancing like the usdm motors, and i couldnt run an aftermarket pulley unless it was dampened.
WgnWheel is offline   Reply With Quote
Old 10-23-2009, 11:32 PM   #24
fastnoypi
Member#: 6886
MY01 EJ207 HTA35r
AVCS ON!
what pulley did you try on your s202 motor and what did you notice at high rpm?
Old 10-23-2009, 11:47 PM   #25
WgnWheel
Member#: 63605
04 Wrx Wgn TimeAtk
i didn't try anything other than stock! i was advised when it was purchased to specifically not run any lightweight pulley on it. ATI has a nice dampened pulley i thought of trying.
i had a cobb on the stock motor and it did as expected, with good results.
Perrin lightweight pulley VS Cobb pulley? Fab's STI Newbies & FAQs 29 09-25-2007 02:15 PM
02 perrin lightweight pulley needed ASAP! skate enjoi Private 'Wanted' Classifieds 5 11-01-2006 05:44 PM
HSPN TV Releases How-To Video Installation of Perrin Lightweight Pulley hspn Engine Management & Tuning 0 09-20-2006 04:19 PM
Perrin lightweight pulley BURTONRIDR Normally Aspirated Powertrain 14 09-05-2006 11:08 AM
FS: Perrin Lightweight pulley for 2.5 Reckon Vancouver Impreza Club Forum -- VIC 2 06-01-2006 06:50 PM
