Old 10-21-2009, 09:43 AM   #1
thewerxracing
Member#: 141498
Default 2.0 heads on a 2.5 block- what else?
I figured this was asked frequently...
I just got several 08wrx long blocks. I want to use a bottom end from one in my bugeye.
Would I need a new ecu and everythin or will the rest of my motor bolt on?
thewerxracing is offline   Reply With Quote
Old 10-21-2009, 02:25 PM   #2
thewerxracing
Member#: 141498
Really? No one knows if you can retain the Stock ECU and just tune it?
Old 10-21-2009, 02:27 PM   #3
Agkelos
Member#: 58163
2002 Stage 2 WRX
World Rally Blue
Which parts are you wanting to swap into your car? Sorry I was confused.
Agkelos is offline   Reply With Quote
Old 10-21-2009, 02:37 PM   #4
Byzantium
Member#: 207826
85k 2002 WRX
Correct Fitment Crew #034
ECU is determined by the heads.
Byzantium is offline   Reply With Quote
Old 10-21-2009, 03:47 PM   #5
thewerxracing
Member#: 141498
Nice. So I'm sure it will needed to be tuned, but that's about it.
Old 10-21-2009, 05:02 PM   #6
the suicidal eggroll
Member#: 51961
2005 STi
2012 WRX
Right, 2.0 to 2.5 hybrid setup requires no change in the ECU, just a new tune.
Old 10-21-2009, 05:06 PM   #7
snowcrzy
Member#: 110895
better head gasket.
snowcrzy is offline   Reply With Quote
Old 10-22-2009, 12:34 PM   #8
rckcrawler
Member#: 217590
I am glad you asked this question. I have the same setup sitting at my sisters house. So if I was reading this right I need the wiring harness for the 2.0 and the ecu, correct? Also the DOHC heads take coil packs right?
rckcrawler is offline   Reply With Quote
STI cams in 2.0 heads on 2.0 block? OUScooby Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 02-06-2010 10:05 PM
2.0 heads on sti block crpwrx Subaru Conversions 8 09-28-2008 07:55 PM
USDM 2.0 heads on a USDM STi Block? NicktheBrit Built Motor Discussion 5 03-06-2008 04:11 PM
2.0 utec on a 2.5 swap KillerBumbleBee UTEC 13 01-26-2007 03:02 PM
Can I put a 2.0 head on a 1.8 block? NewbyScooby Normally Aspirated Powertrain 11 11-18-2003 07:10 AM
