Old 10-21-2009, 08:47 PM   #1
pittsburghscoobie
Member#: 221812
2003 WRX
MBP
Default Replacing Oil Pump Seal?
so got my o2 sensor replaced at the dealer but the seal for the oil pump is leaking and its not covered under warranty.
the dealer wants, like 250 bucks to replace a 12 dollar seal?
no way, jose'
how hard would this be to do?
They said something about I might have to pull my exhaust off?
I am going to be getting a new upipe and downpipe soon anyway, so I might just wait.
anyone?
pittsburghscoobie is offline   Reply With Quote
Old 10-21-2009, 09:24 PM   #2
03SubyWRX
Member#: 200767
2003 WRX 2.5 Hybrid
97 OBS schwagon
I'd be wary of them if they said they'd have to pull the exhaust to do it. You don't have to.
It's all labor really. You have to pull the timing cover and belt as it is located behind them. It's just getting to it that's a pain. Also, just be careful to seal up the oil pump itself when you reinstall it.
03SubyWRX is offline   Reply With Quote
Old 10-21-2009, 09:30 PM   #3
Meatbawl
Member#: 175878
Won't have anything to do with your exhaust at all. You will need to remove the following:
Radiator
Accessory belts
Crank pulley
Timing belt covers (all 3)
Timing belt
Crank sprocket
Oil Pump
I have a writeup that covers doing almost all of this procedure until it comes time to remove the oil pump. It's pretty simple after you get everything removed, take out all the bolts to the oil pump (about 10 10mm bolts), and smack it loose with a rubber hammer. Tap out the oil seal from the rear side of the oil pump by using a flat screwdriver and hammer and going around the perimeter of the inside of the crank seal. Once it falls out, flip the oil pump over and lightly tap the new one in with the hammer. Clean off the mating surface of both the oil pump and block, apply thin coat of Subaru threebond (or permetex ultra grey) and reinstall. Be sure to align the oil pump bearing to the crankshaft "square" to get it on. Tighten it down nice and firmly and follow the timing belt change guide to reinstall the rest
Meatbawl is offline   Reply With Quote
Old 10-21-2009, 09:30 PM   #4
pittsburghscoobie
Member#: 221812
2003 WRX
MBP
so i have to pull my timing belt off?
****ttt, i wonder if i can find a diagram or something online?
idk how to put a timing belt back on....
Old 10-21-2009, 09:36 PM   #5
pittsburghscoobie
Member#: 221812
2003 WRX
MBP
Radiator
Accessory belts
Crank pulley
Timing belt
Crank sprocket
Oil Pump
could i maybe see this write up?
hahaha thanks
Old 10-21-2009, 09:48 PM   #6
Meatbawl
Member#: 175878
http://forums.nasioc.com/forums/show....php?t=1794043
It will get you all the way down to where all you have to do is remove the crank sprocket (it just pulls off) and the oil pump.
Old 10-21-2009, 09:57 PM   #7
03SubyWRX
Member#: 200767
2003 WRX 2.5 Hybrid
97 OBS schwagon
Good info!
Old 10-21-2009, 10:18 PM   #8
Meatbawl
Member#: 175878
^Thanks
Oh, before I forget.. also remove the crank sensor (just 1 10mm bolt holds it in place on the top of the oil pump). And don't forget to put it back in place when you're all done.. not installing it means the car won't even start
Old 10-21-2009, 10:22 PM   #9
pittsburghscoobie
Member#: 221812
2003 WRX
MBP
damn, that looks pretty intense ha.
ill see what i can do, thanks for the info though
i love this place
FS: ej25 water pump/cam seals/oil pump seals/timing belt cover gaskets sti charles Engine/Power/Exhaust 24 11-02-2008 03:10 PM
Help oil pump seal DelawareLGT 'Old School' Subaru Forum 13 12-17-2006 02:09 AM
Replacing Oil Pump on 1.8L - Advice Needed speedblind Service & Maintenance 10 06-06-2005 11:08 PM
'00 2.5 RS oil pump seal cml182 Normally Aspirated Powertrain 4 03-09-2004 10:51 PM
Oil pump seal walnats Service & Maintenance 5 05-01-2002 11:41 PM
