Old 05-13-2002, 02:59 PM   #1
Mr. Rogers
Member#: 17028
2002 2.5 TS wagon
Default Goal of 200 HP at the wheels is realistic ?
Didn't know where this goes so I fgure it seem general to me ?
"I am currently planning out my mods for next year and am exploring options here to see if this is realistic. My requirement is that it must be a daily driver so civility is key here. As civil as possible. I will be basing my budget while am planning so I'll see about that later."
- I also posted this on Cobb's website
Any opinions, options ? flames?
Mr. Rogers is offline   Reply With Quote
Old 05-13-2002, 03:03 PM   #2
Mr. Rogers
Member#: 17028
2002 2.5 TS wagon
uurrghh I forgot to say I driving an 02 TS wagon. Just in case you didn't see it in my mini profile.
Old 05-13-2002, 03:34 PM   #3
Silver_SportTrac
Member#: 15052
Do u have to ask?
totally possibe d00d.
But for a more technical explination, go over to the "Aftermarket Forced Induction" forum. That's where most of the RS, and other non-turbo models go for info on how to turbo their car's.
It'll most likely cost you a bit of cash to get your RS to 200Whp, but it's possible. Hell anything is possible, you just gotta have the cash.
-SST
Silver_SportTrac is offline   Reply With Quote
Old 05-13-2002, 04:08 PM   #4
Mr. Rogers
Member#: 17028
2002 2.5 TS wagon
I need technical advice..How can I move this to the Aftermarket Forced Induction forum ?
Old 05-13-2002, 04:38 PM   #5
romoranger
Member#: 14701
94 camaro
big cam/heads/slicks
you can get it no problem.
i think moderators have to move it. either pm one or wait for them to move it for you.
romoranger is offline   Reply With Quote
Old 05-13-2002, 04:50 PM   #6
kastle
Frank Army
Member#: 1457
1999 Outback Sport
Steel Blue Mica
200hp @ the wheels, without some engine "adjustment", is a little high for a N/A motor...
Figure that you'd be around 190 engine hp if you do the following mods:
Intake
full catback, 2 1/4" pipes
Borla headers
Unorthodox pulley
TEC-II will get you close to that number. So will Cobb cams or some of his other goodies.... But it is going to be a little more expensive to go that route vs. getting a smaller stage I turbo setup... That should be good for 225ish.
just my wacky .02
kastle is offline   Reply With Quote
Old 05-13-2002, 05:02 PM   #7
Mr. Rogers
Member#: 17028
2002 2.5 TS wagon
Would it be more "efficient" in terms of cost, maintenance, drivability etc.. to go with a Turbo or SC setup ?
Old 05-13-2002, 05:09 PM   #8
Dan_E
Member#: 673
1999 2.5RS-T <RIP>
2000 RS-TURBO'D
Not too many proven superchargers are available for us. Turbo's have been proven practically everywhere. I commute in traffic with my 300hp subaru every day with no issues. I spent the extra cash on a TEC-II so I have full control to tune the car as smooth or rough as I want it. There are hundreds of modded WRX's that do the same I'm sure. It IS possible to have a turbo daily driver. Do it, you wont regret it
103k miles and still boostin,
-Dan
Dan_E is offline   Reply With Quote
Old 05-13-2002, 09:31 PM   #9
Mr. Rogers
Member#: 17028
2002 2.5 TS wagon
Thanks..I will look into a turbo for next summer. I have a year to see whats out and how they hold up. In the meantime I'll work on my exhaust, CAI and the pulley.
Kastle - those mods would get me to ~190 whp ? or is that at the crank ?
I went nitrous in my previous car (now thats a rush) but I'm an idiot and couldn't remember how much was in the tank. I prefer a turbo this time around so I can compare the two
Old 05-13-2002, 11:26 PM   #10
Poppa smurf
Member#: 8257
2004 STI
Silver\Silver
Heads
Cam
full exhast
intake
maybe an S-AFC
and that is being optomistic. for a turbo its far cheaper http://ludespeedperformance.tripod.c...ts/stage1.html
Poppa smurf is offline   Reply With Quote
Old 05-14-2002, 04:33 AM   #11
Andrew
Member#: 1170
2005 STi
if you are looking to build up your engine, im selling some JE pistons
Andrew is offline   Reply With Quote
Old 05-14-2002, 08:39 AM   #12
Mr. Rogers
Member#: 17028
2002 2.5 TS wagon
It appears that 5psi is about what I want to run ( am not greedy for power LOL) but I didn't see a kit for 02 impreza ? guess I'll do some more searching in the forums. I'll just do my exhaust work first (and of course brakes and some minor suspension work) then wait to see what around.
Old 05-14-2002, 09:39 AM   #13
rupteur7000
Member#: 11585
02 2.5RS
i am also not a p****
pretty much any kit for the pre 02 will fit on the 02, there are only a few mods to it. the main problem is the lack of scoop for the I/C. get a kit without the I/C and then try and find a front mount, that is what i am planning.
contact Elliot, he has an MY02 Rs-T.
take your time and do it right, i have been doing research on going FI for almost a year and i am still learning everyday.
i am going for about the goal as you are, but i drive like a ****ing retard so i have to be more careful with the mods i do.
rupteur7000 is offline   Reply With Quote
Old 05-14-2002, 01:17 PM   #14
Mr. Rogers
Member#: 17028
2002 2.5 TS wagon
FMIC is a good idea. I was doing some board hopping and I saw that some peopl in the rs25.com forum are working on a SC. It would be interesting to see how it turns out.
Old 05-14-2002, 01:20 PM   #15
rupteur7000
Member#: 11585
02 2.5RS
definitely, but on the other hand a s/c will produce crazy amoutns of torque, hard to handle for the tranny. since my car has plenty of torque i think more power in the top end should be fun.
just my .02
Old 05-14-2002, 07:18 PM   #16
Jack
Add Lightness
Member#: 13699
2004 Outback, 13 XV
(From General)
Turbos are the present solution, but require engine management system and potentially some tranny strengthening or serious upgrades. When a supercharger solution comes back (Rimmer was there, but had some business dealing problems), it should be a good alternative. The S/C has been on my short list of mods, with only the lack of a system stopping me. With a low enough boost, engine management can be done by the stock computer and air is brought in linearly with RPM, from what I've gathered, making it much easier on the tranny. It's pretty much a simple bolt on. No exhaust stuff, no computer stuff. If only it was available now.....
jack
Old 05-15-2002, 07:15 AM   #17
Mr. Rogers
Member#: 17028
2002 2.5 TS wagon
I hear of so many new kits coming out and as I learned the hardway with previous cars I'll wait a year to see what comes out and how it works. Till then I'll start with the a full exhaust system. Still debating whether or not to shell out big bucks for something from Cobb or brullen or just go to my local meineke shop and have something custom made. I want the performance but without the alarm setting off noise, been there done that and drew lots of unwanted attention in bronx.LOL.
Is loss of HP at the wheels a straight loss or is it a proportional loss? SC WRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 07-09-2003 09:28 PM
Looking for 200+hp at the crank... Spenk Normally Aspirated Powertrain 7 07-07-2002 12:17 PM
200 hp to the wheels CarbonWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 16 04-22-2002 06:04 PM
13+ hp at the wheels by the XS cold air intake? Wrx0R Newbies & FAQs 21 11-18-2001 10:07 PM
