Old 10-25-2009, 09:02 PM   #1
TougeAdict
Member#: 76965
2011 WRX Hatch
2002 Silver WRX
Default White Smoke and Plastic Burning Smell.. What is the problem?
Hello fellow Subaru oweners!
I'm have been searching this issue on the forums and most of the posts didn't really have a answer for me.
Here is one:
http://forums.nasioc.com/forums/show...+Plastic+Smell
2002 Subaru WRX
Mileage: 174,---
ANYWAYS! I drove to Skyline Drive in Virginia. For me to get there I did a about a hour drive. Regular driving no racing or high speeds on the way there. Once I got there pulled off one of the overlooks and turned off my car. I got back in started it up and notice a wierd plastic burning smell?? I thought it was a little weird even though I have had the FAMOUS gas smell for years. So I drove a couple miles more down Skyline Drive. The smell started getting worse and stuck around. So I pulled over looked in the engine bay and noticed the smell around the front part of the engine near the passenger side. No Smoke though (yet). Drove back home a 2 hour drive still with the smell not as bad as before.
Got home and the car sat in my driveway for about 2-3 hours. Started it back up to go to the store. As soon as I start up I noticed a puff of smoke come out of my hood scoop. Then I look at the back of the car and White Smoke is pouring out of my exhaust that has the smell of burning plastic. Drove up the street, shut it off for about 20 minutes and started it again. Did the same thing. Puff of smoke through hood scoop and pouring white smoke out of the exhaust. Now the smoke tones down as I drive. During all this I am still smelling the burning plastic inside the car.
The way I have been reading on the boards here, I have heard that it could be a head gasket or turbo seal? Someone please help. Thank You guys! You guys have been GREAT help before.
SIDE NOTE: The engine has no modifications.
Sorry for the very long explanation.
TougeAdict is offline   Reply With Quote
Old 10-25-2009, 09:12 PM   #2
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
was it rubber or plastic??
Old 10-25-2009, 09:15 PM   #3
TougeAdict
Member#: 76965
2011 WRX Hatch
2002 Silver WRX
kind of a mix of both at the beginning then move to more of a plastic smell...
Old 10-25-2009, 09:26 PM   #4
Uncle Scotty
Member#: 16200
OK buy Nates beans
belt....???
Old 10-25-2009, 09:36 PM   #5
TougeAdict
Member#: 76965
2011 WRX Hatch
2002 Silver WRX
Here is one:
2002 Subaru WRX
Mileage: 174,---
I forgot to mention that the puff of smoke would come from the passenger side of the hood scoop
Old 10-25-2009, 11:00 PM   #6
z&cobb
Member#: 12344
2002 2JC
blue
Overfill the transmission recently? The dipstick has vents in the guide/plug?
Or, a small tear in the inner axle boot on the passenger side?
Are you sure it is not the smell of engine oil?
z&cobb is offline   Reply With Quote
Old 10-25-2009, 11:18 PM   #7
TougeAdict
Member#: 76965
2011 WRX Hatch
2002 Silver WRX
There is no oil smell and the transmission was serviced a couple hundred miles ago. So I would figure if it had been overfilled it would have burned off by now? No? What about this "turbo seal" that I hear about?
Now I parked the car about a couple hours ago and looked under the hood after it was sitting for about 20 minutes. I could hear a quiet boiling or melting noise from the area of the turbo. Not the usual cool down pop noise when you turn off your car normally.
Old 10-26-2009, 07:11 AM   #8
ricerocket123
Member#: 126879
2004 WRX
JBP
White smoke + smell of burned plastic sounds like engine oil to me. Probably engine oil go into exhaust? Can you check your engine oil to see if you are losing them?
ricerocket123 is offline   Reply With Quote
Old 10-26-2009, 07:14 AM   #9
C89ZX7R
Member#: 119154
2004 White
STi
Check the A/C Drip Hose
C89ZX7R is offline   Reply With Quote
Old 10-26-2009, 07:59 AM   #10
garface
Member#: 1581
MY00 RS/STi7
MY01 RS Both Silverthorne
It's weird that you have smoke coming from the exhaust AND under the hood. Can you open your hood and have someone turn on the car to see where it's coming from?
garface is offline   Reply With Quote
Old 10-26-2009, 10:41 PM   #11
Rikshaman
Member#: 90817
check your axle boot on the passenger side. you probably ripped it and its throwing axle grease onto your downpipe. hence smoke is coming out your hoodscoop. once the dp heats up, it burns the grease which smells like burning plastic. check it!
Rik
Rikshaman is offline   Reply With Quote
Old 10-27-2009, 12:10 AM   #12
ralliboi
Member#: 174924
2001 impreza rs
blue
this may sound crazy, but check the exhaust flange between the cats and the midpipe, i had the same problem and thats where it was coming from. It comes from having bad cats from whatever reasons(clogged or whatever) i had blown 3 motors inside of 2 months on the same exhaust and somewhere in there oil/gas/coolant got into the exhaust and ruined my cats. Hopefully not the case but i had the same thing with the smell and all
ralliboi is offline   Reply With Quote
Old 10-27-2009, 07:40 AM   #13
garface
Member#: 1581
MY00 RS/STi7
Rik
How would that shoot smoke OUT of his exhaust? I like the cat idea, but wouldn't he have a CEL?
Old 10-27-2009, 02:13 PM   #14
z&cobb
Member#: 12344
2002 2JC
blue
Except for the white smoke from the exhaust, I would have said to check the oil pressure relief valve area. On second thought the following might help someone else, so here it is.
Stand in front of the vehicle and use a bright LED flashlight to illuminate the front of the lower left hand side of the head. There is a spring loaded oil pressure relief valve down there. You will see the drain for the radiator down near that region to check if you are looking in the right place. Look for signs of engine oil under that area on the plastic.
Only a few drops of oil falling onto the hot pipe down there can give you a lot of smoke under the right (wrong!) combinations of conditions. You may not even notice a drop in the dipstick level for several thousand miles if you don't own one of the engines that routinely "burn" or consume massive quantities of engine oil.
Or it could be something much more expensive to fix. Remote diagnosis is a crapshoot here.
White Smoke and maple syrup smell commin from engine, HELP Walkerf16 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 18 05-16-2009 01:01 AM
Burning smell - what is it? balub Service & Maintenance 5 03-08-2008 10:00 AM
symptoms... what is the problem? legacy2003 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 49 10-22-2006 07:13 PM
What is the problem with my A/C? Carbine308 Service & Maintenance 2 06-04-2005 09:20 PM
what is the problem? DP1112 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 02-14-2005 11:17 AM
